Ok thanks, hope that e Ken help
@zambu : I run NE standard Nexus CoreELEC-Amlogic-ne.arm-20.2-Nexus-Generic.img (from eMMC) on Vontar X4 with 4GB RAM and 1Gbps Ethernet with dtb.img sc2_s905x4_vontar_x4.dtb built on CE 20.2 git tag from own brew source in earlier post: Vontar X4 (S905X4): install to eMMC? - #28 by tasinofan
Analog audio works (3.5mm jack).
sc2_s905x4_vontar_x4.dtb (66.0 KB)
CE Audio output device is set to ‘ALSA:Default (AML-AUGESOUND Analog), PCM’.
aarch64 Omega images such as 21.0 NO and 21.0 NE I have not tried and built dtb for yet.
ok its working as was using sound from hdmi, NO works out box from sound from the hdmi
this db from Analog audio works (3.5mm jack), CE Audio output device is set to ‘ALSA:Default (AML-AUGESOUND Analog), PCM’.
sory i was testing from hdmi, but the NO from hdmi works, but from Analog audio (3.5mm jack) dont work.
Sorry, I’m totaly confused now what is going on and what is needed.
Teste from a clean install
CoreELEC-Amlogic-ne.aarch64-20.3-Nexus_nightly_20240102-Generic.img
whith db sc2_s905x4_vontar_x4.dtb from vpeter
Sound from hdmi - ok
Analog audio (3.5mm jack) ok
CoreELEC-Amlogic-no.aarch64-21.0-Omega_nightly_20240103-Generic.img
whith db sc2_s905x4_4g_1gbit.dts from img
whith db sc2_s905x4_vontar_x4.dtb from tasinofan
So nothing to do at all?
Vontar X4 analog audio does not work on ne.aarch64-20.3-Nexus and ne.arm-20.2-Nexus
with provided sc2_s905x4_4g_1gbit, so on these branches CE team might consider adding a specific sc2_s905x4_vontar_x4.dts as given in Vontar X4 (S905X4): install to eMMC? - #28 by tasinofan
How come it works on no.aarch64-21.0-Omega is also a mystery to me and I should test it.
Keep you informed, but, of course, @zambu already tested
@zambu: please try this dtb for analog and let me know if works or not.
sc2_s905x4_4g_1gbit.dtb (72.0 KB)
yes it is working fine
Thanks so much for having taken care of this sc2 s905x4 analog audio defect.
I noticed the commits on github ![]()
