What media player do you own?
Was hoping to find something with giga and could do vp9 but the C2 seems like its still the best bet i’ll just stick with that. Thanks.
Another Odroid C2 user here. Only use it for 1080p in the bedroom, and a Nvidia Shield for the home theatre room.
Odroid C2 does what it needs to do, and can provide a nice and smooth UI experience.
Rock64 in my living room acting as media player and a samba server, and a Nexbox A95x (S905) in my bedroom. The A95x is way more stable.
I have Khadas vim2 with DTV extension and old Mx3-G (S812)
I have an Minix NEO X8-H Plus (Amlogic)
Which Coreelec with Kodi 18.1 can I use and which dtb.img?
Minix NEO X8-H PLUS
Chipset**|Amlogic S812|
CPU**|Quad-core Cortex A9r4|
|GPU|ARM MALI-450 Octa-core|
|RAM|2GB DDR3|
|ROM|16GB eMMC|
|SD slot|1x max.32GB|
|Ethernet|Gigabit Ethernet|
WiFi 802.11 b/g/n/ac 2x2 MIMO|
Bluetooth 4.0|
USB**|3x USB2.0|
1x micro-USB OTG|
IR**|1x Receiver|
HDMI**|1,4 up to 4K @30fps (4k K.265/ HEVC Hardware decoding)|
Support HDMI-CEC|
Optical OutS/PDIF
CE only supports the S900 series of Amlogic chips, the S812 is not supported.
  • MINIX Neo U1 (CoreELEC installed on eMMC and working flawlessly)
  • Amazon Firestick 2
  • Xiaomi Mi Box S
I’am using now a Minix NEO U9-H with
Amlogic S912-H
Octa-core ARM cortex A53-Processor @ till 2GHz (64bit)
ARM Mali-820MP3
2GB DDR3 (32 bit)
16GB eMMC 5,0 Storage (MLC)
1x max.64GB
Gigabit Ethernet
Bluetooth 4.1
3x USB2.0
1x micro-USB OTG
1x Receiver
2.0 up to 4K @ 60Hz with CEC, HDCP 2.2 en HDR / HDR10 support
Support HDMI-CEC
S/PDIF
With only Android not perfect. With CoreELEc almost perfect.
Mini M8S II (Amlogic S905X)
2GB RAM / 16 GB eMMC flash
Was using Android, then tried LibreElec for a while, then returned to Android (custom rom) and after Kodi Leia was released (and was running with huge playback issues on Android) I resorted to CoreElec (so I have dual boot: Android custom rom with Kodi 17.6 on NAND and CoreElec on SD).
Never been so smooth as it is now with CoreElec :slightly_smiling_face:
Thanks to the devs and mods for their great work and support.
I’ve got 3 Nexbox A1 (original versions) here.
2 were for family as gifts to have access to my NAS.
I’ve been ready to throw them out for the last year until CE saved the day. They are now running better than they ever did. Not perfect, but far far better than out of the box.
