Just to double check if other users experience same:
A recent update of libwidevinecdm.so to 13816.64.0 gives
Unable to load widevine shared library
OpenDRMSystem failed
Reverting back to 13729.56.0 (hard link from userdata/addon_data/script.module.inputstreamhelper/backup/13729.56.0/libwidevinecdm.so to cdm/libwidevinecdm.so) solves issue.
Can’t play netflix so I think I’m encountered the same problem
From where do you get these version numbers?
Info from “InputStream Helper Information” => Widevine CDM version 4.10.1679.0 as the latest version, and Netflix and HBO_Go streams play without any problem…
13816.64.0, is a Chrome OS platform version. May 2021.
https://chromereleases.googleblog.com/2021/05/stable-channel-update-for-chrome-os.html?m=1
They also are the names of the backup directories held in /storage/.kodi/userdata/addon_data/script.module.inputstreamhelper/backup/
/storage/.kodi/cdm/libwidevinecdm.so itself is a hard link to the most recent one there.
I reverted that link to second most recent one on my setup in order to tmp fix issue.
Use InputStream Helper to switch between different Widevine versions, upgrade/downgrade or backup and restore them, as well as to install Widevine. It will show version numbers also without having to use the shell.
Also:
Please consider this topic closed.
It works now. Go to addons, update addons. Then go to InputStream Helper and reinstall Widevine
@nfm886
Did you reboot after reinstall?
Can you give md5sum of /storage/.kodi/cdm/libwidevinecdm.so and give output of
ls /storage/.kodi/userdata/addon_data/script.module.inputstreamhelper/backup
mine is
13505.111.0 13729.56.0 13816.64.0
and 13816.64.0 does not work after reinstall and reboot.
Also, InputStreamHelper v0.5.3 update does not fix problem for me.
No. I just reinstalled and it worked.
3144866613a7f691b8cb07df6bbc4d80 libwidevinecdm.so
give output of
mine is
that’s 13729.56.0 (size 7297324)
