Hello, i have installed on nand memory CoreELEC 9.2.1, i connect USB 3.0 gigabit LANadapter RTL8153B and i have very slow download 1-14MB/s unstable , and dropped packets, but upload is fine 23MB/s and stable no drop packed. Connetion is gigabit.
How Enable Flow Control ? “rx-checksumming: off [fixed]”
“CoreELEC:~ # ethtool -A eth1 rx on tx on
Cannot get device pause settings: Operation not supported”
"Features for eth1:
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: off
tx-scatter-gather: off [fixed]
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: off
tx-tcp-segmentation: off [fixed]
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: off [fixed]
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: off [requested on]
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: off [fixed]
tx-vlan-offload: off [fixed]
ntuple-filters: off [fixed]
receive-hashing: off [fixed]
highdma: off [fixed]
rx-vlan-filter: off [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
Adapter is fine, work on laptop in USB 2.0, speeds ar 30 download and 30MB/s upload, me network, router, cable ar fine, i’m instal older wersion LibreELEC and that same bad slow download transfer. Me BOX TV is X96 on S905X no USB 3.0, WiFi and LAN 100M work fine, max speeds ar 11MB/s.
I tested ipref, and copy file.
Maybe wrong driver ? USB ADAPTER is RTL8153B , and driver RTL8152
It’s show in router gigabit connection but :
"CoreELEC:~ # ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 32
Transceiver: internal
Auto-negotiation: on
Link detected: yes
Link encap:Ethernet HWaddr -------------------------
inet addr:192.168.1.54 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:575753 errors:0 dropped:366 overruns:0 frame:0
TX packets:781514 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:661266638 (630.6 MiB) TX bytes:668717926 (637.7 MiB)
ethtool -i eth1
driver: r8152
version: v1.04.0 (2014/01/15)
firmware-version:
expansion-rom-version:
bus-info: usb-xhci-hcd.0.auto-1
supports-statistics: no
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
Download test :
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 373 KBytes 3.06 Mbits/sec
[ 5] 1.00-2.00 sec 282 KBytes 2.31 Mbits/sec
[ 5] 2.00-3.00 sec 3.58 MBytes 30.0 Mbits/sec
[ 5] 3.00-4.00 sec 11.5 MBytes 96.7 Mbits/sec
[ 5] 4.00-5.00 sec 10.5 MBytes 88.4 Mbits/sec
[ 5] 5.00-6.00 sec 9.91 MBytes 83.1 Mbits/sec
[ 5] 6.00-7.00 sec 6.90 MBytes 57.9 Mbits/sec
[ 5] 7.00-8.00 sec 9.65 MBytes 81.0 Mbits/sec
[ 5] 8.00-9.00 sec 7.69 MBytes 64.5 Mbits/sec
[ 5] 9.00-10.00 sec 8.54 MBytes 71.6 Mbits/sec
[ 5] 10.00-11.00 sec 7.31 MBytes 61.3 Mbits/sec
[ 5] 11.00-12.00 sec 11.8 MBytes 99.2 Mbits/sec
[ 5] 12.00-13.00 sec 8.32 MBytes 69.7 Mbits/sec
[ 5] 13.00-14.00 sec 7.13 MBytes 59.8 Mbits/sec
[ 5] 14.00-15.00 sec 16.5 MBytes 138 Mbits/sec
[ 5] 15.00-16.00 sec 2.84 MBytes 23.9 Mbits/sec
[ 5] 16.00-17.00 sec 9.18 MBytes 77.0 Mbits/sec
[ 5] 17.00-18.00 sec 8.81 MBytes 73.9 Mbits/sec
[ 5] 18.00-19.00 sec 8.98 MBytes 75.3 Mbits/sec
[ 5] 19.00-20.00 sec 4.48 MBytes 37.5 Mbits/sec
[ 5] 20.00-21.00 sec 8.03 MBytes 67.4 Mbits/sec
[ 5] 21.00-22.00 sec 4.81 MBytes 40.3 Mbits/sec
[ 5] 22.00-23.00 sec 7.42 MBytes 62.3 Mbits/sec
[ 5] 23.00-24.00 sec 6.86 MBytes 57.6 Mbits/sec
[ 5] 24.00-25.00 sec 3.94 MBytes 33.0 Mbits/sec
[ 5] 25.00-26.00 sec 5.27 MBytes 44.2 Mbits/sec
[ 5] 26.00-27.00 sec 6.32 MBytes 53.0 Mbits/sec
[ 5] 27.00-28.00 sec 9.02 MBytes 75.7 Mbits/sec
[ 5] 28.00-29.00 sec 6.21 MBytes 52.1 Mbits/sec
[ 5] 29.00-30.00 sec 2.84 MBytes 23.9 Mbits/sec
[ 5] 0.00-30.00 sec 215 MBytes 60.1 Mbits/sec
Upload :
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 20.8 MBytes 174 Mbits/sec
[ 5] 1.00-2.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 2.00-3.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 3.00-4.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 4.00-5.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 5.00-6.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 6.00-7.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 7.00-8.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 8.00-9.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 9.00-10.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 10.00-11.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 11.00-12.00 sec 22.0 MBytes 185 Mbits/sec
[ 5] 12.00-13.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 13.00-14.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 14.00-15.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 15.00-16.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 16.00-17.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 17.00-18.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 18.00-19.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 19.00-20.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 20.00-21.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 21.00-22.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 22.00-23.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 23.00-24.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 24.00-25.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 25.00-26.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 26.00-27.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 27.00-28.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 28.00-29.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 29.00-30.00 sec 22.1 MBytes 185 Mbits/sec
[ 5] 30.00-30.06 sec 1.42 MBytes 184 Mbits/sec
[ 5] 0.00-30.06 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-30.06 sec 663 MBytes 185 Mbits/sec receiver"
