I have a X96Max (S905X3) device: https://es.aliexpress.com/item/32928180453.html
I installed OpenVFD addon and download and rename this file to /storage/.conf/vfd.conf: https://github.com/arthur-liberman/vfd-configurations/blob/master/x96-max-1gbit-vfd.conf
After reboot the display, it doesn’t turn on. Need I configure something else?
Best regards.
Bat123
#2
you have to change DTB for the modified one by TheCoolest
solution here
Thanks!
This works for me:
mount -o remount,rw /flash
cp /usr/share/bootloader/device_trees/sm1_s905x3_2g.dtb /flash/dtb.img
reboot
Regards.
