I have a Nexbox A9X and I have been using the supplied remote using a remote.conf and the instructions here:
I want to try and get a Xbox Media Remote working instead since the supplied remote isn’t very good so I have followed the instructions in the same thread but keep getting the following:
CoreELEC:~ # ir-keytable -t
No devices found
I think amremote may still be active as although I have deleted the remote.conf as per the instructions to return to using meson-ir (and rebooted) the old remote still works.
Ok, ir-keytable is now detecting events from my Xbox remote which is good.
Will have a go at configuring it as per the instructions.
Edit: Got it working surprising easily with the xbox_360 config included with Coreelec. Only issue, which is box specific, is that I can’t power it on my the Xbox remote, only the included one. Is there any way of changing what IR code the box looks for to power on?
To fully replace a TV box’s original remote with another then the new remote needs to also have at least one button with a IR learning ability (to learn the power-on from the original remote)
Compiling my own uboot sounds somewhat outside my ability and sounds like a sure fire way for me to brick the box…
I can live with powering on with the old remote.
I have my eye on the Odroid N2 following the comments on this board and may well treat myself when they are available, so this may just be short term anyway.
