Hello:
I’m using Xbox tuner with tvheadend (CoreELEC 20.2 ng; S905X3 generic tvbox; tvheadend server 4.3 addon).
Well… I have scanned the DTT muxes (Spain) with no problems, I have added the services, I have added the channels.
More or less all is working OK except 1 single channel of this mux:
In this mux I have two channels:
TVE UHD
and
TVE UHD-2
Well… when I play the channel “TVE UHD” with tvheadend htsp client (CoreELEC) or even using Kodi (Windows) it takes some seconds to play, but it does.
However, when I try to play "TVE UHD-2 " (same mux) using tvheadend HTSP client (with CoreELEC or with Kodi - Windows), it never plays that channel.
BUT:
- If I create a .m3u playlist file with these channels, like:
#EXTM3U
#EXTINF:-1 logo=“http://user:password@192.168.1.40:9981/imagecache/15368” tvg-id=“973bd508af625e2dafdf62ba14479400” tvg-chno=“7100”,TVE UHD
http://user:password@192.168.1.40:9981/stream/channelid/285192115?profile=htsp
#EXTINF:-1 logo=“http://user:password@192.168.1.40:9981/imagecache/15369” tvg-id=“5d8ab207d9e587c0893d78bd2c858d18” tvg-chno=“7101”,TVE UHD-2
http://user:password@192.168.1.40:9981/stream/channelid/457141358?profile=htsp
Both channels (including “TVE UHD-2”) are played using VLC player (Windows), and even, with this .m3u format, are played (including “TVE UHD-2”) with CoreELEC or Kodi (Windows).
If I try (again) play “TVE UHD-2” using tvheadend HTSP client (with CoreELEC or with Kodi - Windows) → NOT working.
Does anyone have any idea why this might be so? Any solution to be able to use the tvheadend HTSP client with “TVE UHD-2”?
Any “strange” way to be able to add “TVE UHD-2” (playable) through tvheadend HTSP client?
Data:
Resumen
TVE-UHD-2 (NOT working with tvheadend HTSP using Kodi / CoreELEC):
General
Complete name : \192.168.1.40\Recordings-TVE UHD-22023-08-2616-09.ts
Format : MPEG-TS
File size : 107 MiB
Duration : 59 s 469 ms
Overall bit rate mode : Variable
Overall bit rate : 15.0 Mb/s
Frame rate : 50.000 FPS
Original network name : Astra Satellite Network 19,2’E
Video
Menu ID : 1 (0x1)
Format : HEVC
Format profile : Main 10@L5.1@Main
Codec ID : 36
Duration : 59 s 320 ms
Bit rate : 13.9 Mb/s
Maximum bit rate : 14.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.033
Stream size : 98.0 MiB (91%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : BT.2020 (10-bit)
Matrix coefficients : BT.2020 non-constant
Audio
Menu ID : 1 (0x1)
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : 6
Duration : 59 s 520 ms
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : -1 s 96 ms
Stream size : 2.72 MiB (3%)
Language : Spanish
Service kind : Complete Main
Menu
Menu ID : 1 (0x1)
Format : HEVC / E-AC-3
List : 512 (0x200) (HEVC) / 513 (0x201) (E-AC-3, Spanish)
Language : / Spanish
Service name : TVE UHD-2
Service provider : CELLNEX
Service type : MPEG-2 HD digital television
2023-08-06 22:00:00 UTC : es:UHD Spain en SDR / es:Documentales realizados en Tecnología UHD, en SDR, cedidos por socios de UHD-Spain: Canal Sur TV, CARTV, Mediapro, Medina Media, RTVE, Telecom CLM. / / / 23:59:59 /
2023-08-07 22:00:00 UTC : es:UHD Spain en SDR / es:Documentales realizados en Tecnología UHD, en SDR, cedidos por socios de UHD-Spain: Canal Sur TV, CARTV, Mediapro, Medina Media, RTVE, Telecom CLM. / / / 23:59:59 /
2023-08-08 22:00:00 UTC : es:UHD Spain en SDR / es:Documentales realizados en Tecnología UHD, en SDR, cedidos por socios de UHD-Spain: Canal Sur TV, CARTV, Mediapro, Medina Media, RTVE, Telecom CLM. / / / 23:59:59 /
2023-08-26 01:00:00 UTC : es:HOCKEY HIERBA CTO EUROPA MASC Y FEM 2023 / es: / team sports (excluding football) / / 01:30:00 /
2023-08-26 02:30:00 UTC : es:PIRAGUISMO CTO MUNDO SPRINT 2023 / es: / water sport / / 01:30:00 /
2023-08-26 04:00:00 UTC : es:PIRAG¿ISMO / es: / undefined / / 00:30:00 /
2023-08-26 04:30:00 UTC : es:CICLISMO MOUNTAIN BIKE WORLD CUP 2023 / es: / athletics / / 00:20:00 /
2023-08-26 04:50:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 04:00:00 /
2023-08-26 08:50:00 UTC : es:PIRAGUISMO CTO MUNDO SPRINT 2023 / es: / water sport / / 01:55:00 /
2023-08-26 10:45:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 00:25:00 /
2023-08-26 11:10:00 UTC : es:HOCKEY HIERBA CTO EUROPA MASC Y FEM 2023 / es: / team sports (excluding football) / / 01:30:00 /
2023-08-26 12:40:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 00:20:00 /
2023-08-26 13:00:00 UTC : es:GIMNASIA RITMICA CAMPEONATO MUNDO 2023 / es: / athletics / / 02:15:00 / Running
2023-08-26 15:15:00 UTC : es:CICLISMO MOUNTAIN BIKE WORLD CUP 2023 / es: / athletics / / 01:45:00 / Not running
2023-08-26 17:00:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 03:00:00 /
2023-08-26 20:00:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 / es: / team sports (excluding football) / / 01:45:00 /
2023-08-26 21:45:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 - PGM RESUMEN / es: / team sports (excluding football) / / 00:30:00 /
2023-08-26 22:15:00 UTC : es:GIMNASIA RITMICA CAMPEONATO MUNDO 2023 / es: / athletics / / 02:15:00 /
2023-08-27 00:30:00 UTC : es:CICLISMO VUELTA A ESPAÑA 2023 / es: / athletics / / 01:30:00 /
2023-08-27 02:00:00 UTC : es:HOCKEY HIERBA CTO EUROPA MASC Y FEM 2023 / es: / team sports (excluding football) / / 01:30:00 /
2023-08-27 03:30:00 UTC : es:HOCKEY HIERBA CTO EUROPA MASC Y FEM 2023 / es: / team sports (excluding football) / / 00:30:00 /
2023-08-27 04:00:00 UTC : es:HOCKEY HIERBA CTO EUROPA MASC Y FEM 2023 / es: / undefined / / 00:55:00 /
2023-08-27 04:55:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 02:25:00 /
2023-08-27 07:20:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 - PGM RESUMEN / es: / team sports (excluding football) / / 00:30:00 /
2023-08-27 07:50:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 / es: / team sports (excluding football) / / 01:55:00 /
2023-08-27 09:45:00 UTC : es:PIRAGUISMO CTO MUNDO SPRINT 2023 / es: / water sport / / 01:00:00 /
2023-08-27 10:45:00 UTC : es:PIRAGUISMO CTO MUNDO SPRINT 2023 / es: / water sport / / 00:40:00 /
2023-08-27 11:25:00 UTC : es:CICLISMO MOUNTAIN BIKE WORLD CUP 2023 / es: / athletics / / 00:55:00 /
2023-08-27 12:20:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 00:25:00 /
2023-08-27 12:45:00 UTC : es:CICLISMO VUELTA A ESPAÑA 2023 / es: / athletics / / 01:20:00 /
2023-08-27 14:05:00 UTC : es:ATLETISMO / es: / athletics / / 00:40:00 /
2023-08-27 14:45:00 UTC : es:PIRAGUISMO CTO MUNDO SPRINT 2023 / es: / water sport / / 00:45:00 /
2023-08-27 15:30:00 UTC : es:CICLISMO PROGRAMA EL RODILLO 2023 / es: / athletics / / 00:45:00 /
2023-08-27 16:15:00 UTC : es:CICLISMO MOUNTAIN BIKE WORLD CUP 2023 / es: / athletics / / 01:20:00 /
2023-08-27 17:35:00 UTC : es:GIMNASIA RITMICA CAMPEONATO MUNDO 2023 / es: / athletics / / 00:45:00 /
2023-08-27 18:20:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 / es: / team sports (excluding football) / / 01:40:00 /
2023-08-27 20:00:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 - PGM RESUMEN / es: / team sports (excluding football) / / 00:30:00 /
2023-08-27 20:30:00 UTC : es:CICLISMO VUELTA A ESPAÑA 2023 / es: / athletics / / 01:00:00 /
2023-08-27 21:30:00 UTC : es:ESTUDIO ESTADIO 2023-2024 / es: / football/soccer / / 01:30:00 /
2023-08-27 23:00:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 02:00:00 /
2023-08-28 01:00:00 UTC : es:HOCKEY HIERBA CTO EUROPA MASC Y FEM 2023 / es: / team sports (excluding football) / / 01:35:00 /
2023-08-28 02:35:00 UTC : es:PIRAGUISMO CTO MUNDO SPRINT 2023 / es: / water sport / / 01:25:00 /
2023-08-28 04:00:00 UTC : es: PIRAGÜISMO CAMPEONATO DEL MUNDO SPRINT FINALES DESDE DUISBURGO (ALEMANIA / es: / undefined / / 00:35:00 /
2023-08-28 04:35:00 UTC : es:SURF ACONT FED ESPAÑOLA 2023 REPORTAJES / es: / sports / / 00:25:00 /
2023-08-28 05:00:00 UTC : es:CICLISMO MOUNTAIN BIKE WORLD CUP 2023 / es: / athletics / / 01:20:00 /
2023-08-28 06:20:00 UTC : es:GIMNASIA RITMICA CAMPEONATO MUNDO 2023 / es: / athletics / / 00:50:00 /
2023-08-28 07:10:00 UTC : es:GIMNASIA RITMICA CAMPEONATO MUNDO 2023 / es: / athletics / / 00:50:00 /
2023-08-28 08:00:00 UTC : es:CICLISMO VUELTA A ESPAÑA 2023 / es: / athletics / / 01:35:00 /
2023-08-28 09:35:00 UTC : es:ESTUDIO ESTADIO 2023-2024 / es: / football/soccer / / 01:35:00 /
2023-08-28 11:10:00 UTC : es:CONEXION VINTAGE 2023 / es: / sports / / 01:35:00 /
2023-08-28 12:45:00 UTC : es:CICLISMO VUELTA A ESPAÑA 2023 / es: / athletics / / 00:35:00 /
2023-08-28 13:20:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 / es: / team sports (excluding football) / / 02:25:00 /
2023-08-28 15:45:00 UTC : es:VARIOS TELEDEPORTE 2023 / es: / football/soccer / / 00:15:00 /
2023-08-28 16:00:00 UTC : es:VARIOS TELEDEPORTE 2023 / es: / football/soccer / / 00:15:00 /
2023-08-28 16:15:00 UTC : es:FESTIVAL DEPORTES URBANOS O MARISQUIÑO 2023 / es: / sports / / 00:20:00 /
2023-08-28 16:35:00 UTC : es:ATLETISMO CTO. MUNDO AL AIRE LIBRE 2023 / es: / athletics / / 02:10:00 /
2023-08-28 18:45:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 / es: / team sports (excluding football) / / 01:45:00 /
2023-08-28 20:30:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 - PGM RESUMEN / es: / team sports (excluding football) / / 00:30:00 /
2023-08-28 21:00:00 UTC : es:CICLISMO VUELTA A ESPAÑA 2023 / es: / athletics / / 01:45:00 /
2023-08-28 22:45:00 UTC : es:CONEXION VINTAGE 2023 / es: / sports / / 01:35:00 /
2023-08-29 00:20:00 UTC : es:BALONCESTO CTO. MUNDO MASCULINO 2023 - PGM RESUMEN / es: / team sports (excluding football) / / 00:30:00 /
2023-08-29 00:50:00 UTC : es:CICLISMO MOUNTAIN BIKE WORLD CUP 2023 / es: / athletics / / 01:45:00 /
2023-08-29 02:35:00 UTC : es:HOCKEY HIERBA CTO EUROPA MASC Y FEM 2023 / es: / team sports (excluding football) / / 01:25:00 /
TVE UHD (Works using tvheadend HTSP client with Kodi / CoreELEC):
General
Complete name : \192.168.1.40\Recordings-TVE UHD2023-08-2616-14.ts
Format : MPEG-TS
File size : 113 MiB
Duration : 59 s 521 ms
Overall bit rate : 15.9 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Duration : 59 s 440 ms
Bit rate : 13.7 Mb/s
Maximum bit rate : 14.4 Mb/s
Active Format Description : Full frame 16:9 image
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Time code of first frame : 00:12:44:02
Stream size : 97.3 MiB (86%)
Transfer characteristics : HLG / BT.2020 (10-bit)
Audio #1
Menu ID : 1 (0x1)
Format : E-AC-3
Codec ID : 6
Bit rate : 640 kb/s
Maximum bit rate : 705 kb/s
Delay relative to video : -1 s 342 ms
Stream size : 4.54 MiB (4%)
Language : Spanish
Audio #2
Menu ID : 1 (0x1)
Format : E-AC-3
Codec ID : 6
Bit rate : 640 kb/s
Language : Spanish
Audio #3
Menu ID : 1 (0x1)
Format : E-AC-3
Codec ID : 6
Bit rate : 64.0 kb/s
Channel(s) : 1 channel
Channel layout : M
Delay relative to video : -1 s 346 ms
Stream size : 465 KiB (0%)
Language : Spanish
Language, more info : Visual impaired commentary
Text
Menu ID : 1 (0x1)
Format : DVB Subtitle
Codec ID : 6
Duration : 50 s 760 ms
Delay relative to video : 9 s 157 ms
Language : Spanish
Menu
Menu ID : 1 (0x1)
Format : HEVC / E-AC-3 / E-AC-3 / E-AC-3 / DVB Subtitle
List : 256 (0x100) (HEVC) / 257 (0x101) (E-AC-3, Spanish) / 260 (0x104) (E-AC-3, Spanish) / 262 (0x106) (E-AC-3, Spanish) / 263 (0x107) (DVB Subtitle, Spanish)
Language : / Spanish / Spanish / Spanish / Spanish
2023-08-26 00:50:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 03:10:00 /
2023-08-26 04:00:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 01:00:00 /
2023-08-26 05:00:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 04:15:00 /
2023-08-26 09:15:00 UTC : es:COMANDO ACTUALIDAD / es: / education/science/factual topics / / 01:00:00 /
2023-08-26 10:15:00 UTC : es:ESPAÑOLES EN EL MUNDO / es: / movie/drama / / 00:51:18 /
2023-08-26 11:06:18 UTC : es:ESPAÑOLES EN EL MUNDO / es: / movie/drama / / 00:53:42 /
2023-08-26 12:00:00 UTC : es:VIAJE AL CENTRO DE LA TELE (EXPRES) / es: / education/science/factual topics / / 00:30:00 /
2023-08-26 12:30:00 UTC : es:CORAZON / es: / education/science/factual topics / / 00:30:00 /
2023-08-26 13:00:00 UTC : es:TELEDIARIO 1 / es: / news/current affairs / / 01:00:00 /
2023-08-26 14:00:00 UTC : es:SESION DE TARDE LA NOVIA DE MI HERMANO / es: / movie/drama / / 01:30:00 / Running
2023-08-26 15:30:00 UTC : es:SESION DE TARDE UN VERANO EN SALAMANCA / es: / movie/drama / / 01:30:00 / Not running
2023-08-26 17:00:00 UTC : es:CINE DE BARRIO / es: / show/game show / / 00:18:58 /
2023-08-26 17:18:58 UTC : es:CINE DE BARRIO LA TIA DE CARLOS / es: / movie/drama / / 01:41:02 /
2023-08-26 19:00:00 UTC : es:TELEDIARIO 2 / es: / news/current affairs / / 00:30:00 /
2023-08-26 19:30:00 UTC : es:INFORME SEMANAL / es: / news magazine / / 00:35:00 /
2023-08-26 20:05:00 UTC : es:CINE CAPRICHOS DEL DESTINO / es: / movie/drama / / 02:05:00 /
2023-08-26 22:10:00 UTC : es:CINE LA ESTAFA / es: / movie/drama / / 01:35:00 /
2023-08-26 23:45:00 UTC : es:DOWNTON ABBEY / es: / serious/classical/religious/historical movie/drama / / 00:47:26 /
2023-08-27 00:32:26 UTC : es:DOWNTON ABBEY / es: / serious/classical/religious/historical movie/drama / / 00:47:34 /
2023-08-27 01:20:00 UTC : es:CINE UN AMOR DE VERANO / es: / movie/drama / / 01:30:00 /
2023-08-27 02:50:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 01:10:00 /
2023-08-27 04:00:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 01:00:00 /
2023-08-27 05:00:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 04:20:00 /
2023-08-27 09:20:00 UTC : es:COMANDO ACTUALIDAD / es: / education/science/factual topics / / 00:55:00 /
2023-08-27 10:15:00 UTC : es:ESPAÑOLES EN EL MUNDO / es: / movie/drama / / 00:51:18 /
2023-08-27 11:06:18 UTC : es:ESPAÑOLES EN EL MUNDO / es: / movie/drama / / 00:53:42 /
2023-08-27 12:00:00 UTC : es:VIAJE AL CENTRO DE LA TELE (EXPRES) / es: / education/science/factual topics / / 00:30:00 /
2023-08-27 12:30:00 UTC : es:CORAZON / es: / education/science/factual topics / / 00:30:00 /
2023-08-27 13:00:00 UTC : es:TELEDIARIO 1 / es: / news/current affairs / / 01:00:00 /
2023-08-27 14:00:00 UTC : es:CICLISMO VUELTA A ESPAÑA 2023 / es: / athletics / / 01:30:00 /
2023-08-27 15:30:00 UTC : es:SESION DE TARDE EL ULTIMO SAMURAI / es: / movie/drama / / 02:25:00 /
2023-08-27 17:55:00 UTC : es:VIAJE AL CENTRO DE LA TELE / es: / education/science/factual topics / / 00:35:00 /
2023-08-27 18:30:00 UTC : es:AQUI LA TIERRA / es: / news/weather report / / 00:30:00 /
2023-08-27 19:00:00 UTC : es:TELEDIARIO 2 / es: / news/current affairs / / 01:05:00 /
2023-08-27 20:05:00 UTC : es:LA PELICULA DE LA SEMANA SPIDER MAN. NO WAY HOME / es: / movie/drama / / 02:10:00 /
2023-08-27 22:15:00 UTC : es:CINE ANIMALES FANTASTICOS Y DONDE ENCONTRARLOS / es: / movie/drama / / 02:05:00 /
2023-08-28 00:20:00 UTC : es:CINE LA LLORONA / es: / movie/drama / / 01:30:00 /
2023-08-28 01:50:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 02:10:00 /
2023-08-28 04:00:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 02:50:00 /
2023-08-28 06:50:00 UTC : es:LA HORA DE LA 1 / es: / education/science/factual topics / / 02:40:00 /
2023-08-28 09:30:00 UTC : es:HABLANDO CLARO / es: / education/science/factual topics / / 02:29:00 /
2023-08-28 11:59:00 UTC : es:INFORMATIVO TERRITORIAL 1 / es: / undefined / / 00:11:00 /
2023-08-28 12:10:00 UTC : es:AHORA O NUNCA / es: / news magazine / / 00:50:00 /
2023-08-28 13:00:00 UTC : es:TELEDIARIO 1 / es: / news/current affairs / / 00:50:00 /
2023-08-28 13:50:00 UTC : es:INFORMATIVO TERRITORIAL 2 / es: / undefined / / 00:25:00 /
2023-08-28 14:15:00 UTC : es:EL TIEMPO / es: / news/weather report / / 00:10:00 /
2023-08-28 14:25:00 UTC : es:LA PROMESA / es: / movie/drama / / 01:05:00 /
2023-08-28 15:30:00 UTC : es:LA SEÑORA / es: / serious/classical/religious/historical movie/drama / / 00:55:00 /
2023-08-28 16:25:00 UTC : es:EL COMODIN DE LA 1 / es: / game show/quiz/contest / / 01:00:00 /
2023-08-28 17:25:00 UTC : es:EL CAZADOR / es: / game show/quiz/contest / / 01:05:00 /
2023-08-28 18:30:00 UTC : es:AQUI LA TIERRA / es: / news/weather report / / 00:30:00 /
2023-08-28 19:00:00 UTC : es:TELEDIARIO 2 / es: / news/current affairs / / 00:50:00 /
2023-08-28 19:50:00 UTC : es:4 ESTRELLAS / es: / comedy / / 00:45:00 /
2023-08-28 20:35:00 UTC : es:GRAND PRIX / es: / game show/quiz/contest / / 02:15:00 /
2023-08-28 22:50:00 UTC : es:VIAJE AL CENTRO DE LA TELE / es: / education/science/factual topics / / 02:00:00 /
2023-08-29 00:50:00 UTC : es:NOTICIAS 24 H / es: / news/current affairs / / 03:10:00 /
tvheadend log for TVE UHD-2:
2023-08-26 17:50:52.442 mpegts: 570MHz in TDT - tuning on Panasonic MN88472 #0 : DVB-T #0
2023-08-26 17:50:52.442 subscription: 00D0: “192.168.1.40 [ user | Kodi Media Center ]” subscribing on channel “TVE UHD-2”, weight: 100, adapter: “Panasonic MN88472 #0 : DVB-T #0”, network: “TDT”, mux: “570MHz”, provider: “CELLNEX”, service: “TVE UHD-2”, profile=“htsp”, hostname=“192.168.1.40”, username=“user”, client=“Kodi Media Center”
2023-08-26 17:50:53.714 TS: TDT/570MHz/TVE UHD-2: HEVC @ #512 Continuity counter error (total 1)
2023-08-26 17:50:53.714 TS: TDT/570MHz/TVE UHD-2: EAC3 @ #513 Continuity counter error (total 1)
2023-08-26 17:50:54.454 TS: TDT/570MHz/TVE UHD-2 Transport error indicator (total 1)
2023-08-26 17:50:54.938 TS: TDT/570MHz/TVE UHD-2: EAC3 @ #513: Invalid start code 79:c8:86
2023-08-26 17:50:54.938 TS: TDT/570MHz/TVE UHD-2: HEVC @ #512: Invalid start code 8e:53:70
Kind regards
