19.0-Matrix Discussion
I dont find device tree for WP2. I guess there is no support for this device anymore.
Wetek Play 2 has a S905H chip, S905 and S912 (gxm) not supported anymore. S905X,D,W,X2,X3 still supported.
works fine for me on n2+ 2gb over smb on a philips tv via a sony avr at 4k hdr on ce19
Just found out that if I disable the h264 acceleration by setting it to ā€œneverā€ then the videos don’t stutter any more. Downside of this is now that the IPTVR Addon now plays TV channels only with half speed as if the framerate is cut by 50%.
Return all decoding settings to default state, update to nightly build and check.
If still stutters then upload full logs from nightly build
Sorry if this is not the right place, could i get a steer if it isn’t?
I have a Minix Neo U22-XJ, i have installed Ugoos AM6 plus firmware on it for Dolby Vision support.
I would like to also install Corelec, either as dual boot or from USB.
I can’t find how to do this with the Patched Ugoos Firmware on the U22-XJ.
Is it possible please?
Just played a video and enabled some debug log and video compinent logging. Hope you can find something:
Please collect full log, but don’t enable debug… to check your config
You have AAC audio in this file, so you should to use HDMI Multi Ch PCM and 7.1 channels in audio settings or HDMI and 2.0 channels
Ok, this is what I got as link for log and the Audio is HDMI and 2.0 set:
http://ix.io/2TCm
Could you try to set default resolution to 1080p and try to play video again?
Also did you have no issue on 9.2 -NG or non-NG build?
Hi boot2k3,
I had no issues on 9.2 where I was using the non-NG builds. Did a complete clean install of CE19 but the only thing that doesn’t seem to work is the video playback as it simply stutters… ALready tried setting different resolutions but the only thing that helps is disabling the acceleration for h264 which again breaks IPTV Simple Addon in cutting framerate by around 50%
Did you try with cemmc tool ?
Hello everyone. Well I gave up. I issued it with a sick-note sd onto a card the
CoreELEC-Amlogic-ng.arm-19.0-Matrix-Generic.img
goes from a card but when I installed it and I withdrew it did not start then. More punctually until 5 seconds blue lamp then as if I relaxed it there would be red led
Did you also copied correct dtb file (gxl_p212_2g.dtb)?
yes rename dtb.img
And did you copied file to root folder (where kernel.img and SYSTEM files are)?
yes. rufus burn. and booting sd card.
Then repeat all the steps and be sure you are doing correctly.
let me lay it first back up the factory software? or I may install it immediately the libreelec after 8.2.3.1 immediately?
recovery x96s905x factory software and install coreelec 19 matrix…:
CoreELEC (official): 19.0-Matrix (Amlogic-ng.arm)
CoreELEC:~ # ceemmc -x
Starting CoreELEC eMMC installation tool...
System is not supported: gxl_p212_2g!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: y
eMMC size: 0x0003ab400000 [16GB]
No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
  Use CoreELEC data from
Install in single boot mode, only CoreELEC on eMMC
    [3] current used SD or USB device
    [4] existing backup on current used SD or USB device
Please choose one option? [1/2/3/4]: 3
Free space of 'partition CE_FLASH': 512MB
Warning: Could not find 'dtbo' partition!
Warning: Could not find 'dto' partition!
Free space of 'partition CE_STORAGE': 14352MB
Used space of '/flash': 225MB
Used space of '/storage': 2MB
There is enough free space on eMMC for installation!
Install CoreELEC on eMMC.
Continue? [y]: y
Moved 'env' from offset 0x000027400000, size 0x000000800000 to offset 0x000000400000
Moved 'misc' from offset 0x000031c00000, size 0x000002000000 to offset 0x000006400000
Moved 'logo' from offset 0x000028400000, size 0x000002000000 to offset 0x000008400000
Starting to format the new 'CE_STORAGE' partition...
mke2fs 1.45.6 (20-Mar-2020)
/dev/mmcblk0 is apparently in use by the system; will not make a filesystem here!
Starting to format the new 'CE_FLASH' partition...
mkfs.fat 4.1 (2017-01-24)
mount: mounting /dev/loop3 on /media/CE_STORAGE failed: Invalid argument
Stopping Kodi before start of copy process!
Starting copying of data to the eMMC!
Please do NOT interrupt this progress till it's finished!
Copy all data from '/flash' to '/media/CE_FLASH'
        225.01M 100%   23.13MB/s    0:00:09 (xfr#61, to-chk=0/63)
Syncthing, please wait...
Copy all data from '/storage' to '/media/CE_STORAGE/coreelec_storage'
          2.82M  99%   12.50MB/s    0:00:00 (xfr#223, to-chk=0/439)
Start Kodi again to have a user interface!
Success!
You can now power off the device, remove the used boot media (SD or USB) and
power on again to boot the device from eMMC!
CoreELEC:~ #
Error screen:
Error mount storage: mount_common could not mount /dev/ce_storage ***
