How to post debug logs
Please follow new CoreELEC Wiki
https://wiki.coreelec.org/coreelec:debuglogs
Before posting a error
Did you try a clean install?
How the error can be reproduced?
If your issue is not solved by a clean install:
Please follow this guide to retrieve a debug log of the system:
Enable debug logging in Kodi settings.
Reboot your device, reproduce your issue and then follow the steps below.
Settings
CoreELEC
System
Upload latest ...
You will get a http://ix.io URL with your debug information of the device.
Please post this URL when requesting support.
Other debug information:
Sometimes other debug information are needed like dmesg.
Open a SSH connection to your device and enter:
dmesg | paste
You will receive a http://ix.io URL as result what you can use to request support.
Where is debug log stored?
Bl301 injection, problems, help,
[S922X] Bee-link GT King
[S922X] X88 King
9.2.0 Discussion
USB DAC support
TVheadend choppy
Khadas VIM3L IR and CE 19.X
Odroid-C4 Power/Wake Button Problem
[s922x] a95x max plus
I'm not getting audio from the 3.5mm jack on my odroid n2
Librespot Amlogic
WakeOnLan not working
Nightly builds
Nightly builds
CEC not working on LG Smart TV
Nightly builds
Nightly builds
CEC: active source switching not working in Kodi
Ghosting despite noise reduction off
Hardkernel Wifi Module 5B not working (Odroid-N2+)
Possible solution boot very slow in internal eMMC
Nightly builds
Wetek Play 2 + DVB-T/C Tuner cannot find channels
Looking for users with no working WiFi or BT
Nightly builds
HDD Randomly powering up
"mounted removable storage" pop up, on Kodi startup
HTTPS Server - No connection
Odroid n2 coreelec power
One more, can't setup remote wakup
[S905X3] X96Air_P3
X96 (S905X), power on by IR remote not working
Vim3l coreelec 9.2.2 buffering
Passthrough not working after update :(
CoreELEC 19.2-Matrix_rc3 Discussion
9.2.4.2 Discussion
NEW Repo for Remote files (Thanks to Betatester)
Strange behaver after Update minix u22-xj
[SOLVED] Sometimes video starts in just 1/4th of the screen
CoreELEC 19 Matrix Discussion (Kodi RC)
9.2.4.2 Discussion
Unfortunely, Launcher has stopped Xoro HST 260 T2/C(Amlogic S905D)
Odroid N2+ IR powering : How to have separate buttons for power on and power off?
Amlogic hardware acceleration
Kodi crashed
Odroid N2 test builds
9.2.5 Discussion
Odroid-N2 Playback Problems with x264 4K @ 50 fps Content
Deleted TVheadend plugin and now only boot to safe mode is possible
[solved] Key code 0x00 always switches to mouse mode
Login problem with Tidal add-on
CoreELEC pausing with C4 or N2 on TCL 43S425 in 4K
9.2.6 Discussion
9.2.6 Discussion
19.0-Matrix Discussion
CoreELEC 19.2-Matrix Discussion
Choppy Playback / Audio Desync
Odroid N2+ .mp4 and .mkv not working with CoreELEC 19.4-Matrix_rc2
CoreELEC 19.2-Matrix_rc2 Discussion
Learning about Dolby Vision and CoreELEC development
No 4k output on s905w
CoreELEC 20.0-Nexus_alpha1 (pre-release)
Odroid N2+ and FANTEC QB-35US3-6G: Restart or Reboot Takes FOREVER or hangs
VIM3L using MCE remote
How to install keymap on CoreELEC?
Change Skin in CoreELEC
CoreELEC 20.1-Nexus Amlogic-ng Discussion
Nightly builds
TV Remote stopped working?
PVR Slow Motion Bug
Nightly builds (thread v1)
Khadas VIM3 testbuilds
MP4 video playback freezes during fast forward
