give sample & logs, & in time they will look, no need to put pressure on them , they’re all incredibly generous helping all so be please be patient & appreciate thank you ![]()
Understand your points, but 3D remains alive in projectors (latest from Hisense, Valerion, NexiGo, and several others). I’ll post logs later today. And, just uploaded this 10 minute sample… playback should stop abruptly within 5 minutes (just let it play from the start).
So every test take 5min? It’s even more waste of time…
Seek doesn’t work?
No, seeking postpones the crashing. For every file (for me) the crash occurs within 3-20 min of continuous runtime, no matter where you start. But for one particular file, it is quite consistent, after how many minutes it crashes.
Hey hdmkv,
I can consistently reproduce the crash on my AM6B+, usually around when this Stonehead-Guy appears or shortly after :-).
One weird thing with your file is, that it seems to be choppy sometimes and there are grey bars left and right, where is seems something is wrong with the video file? Doesn’t matter for the crashing issue at hand and it is quite a good sample file, as it crashes very quickly compared to most of my videos. Do you also have these grey bars? Seems like one of the eyes is missing there, which I have not seen before in my own files. You only really notice the grey bars with glasses off.
Hmm, don’t know… it was a straight rip from the Japanese 3D Blu-ray, but w/ATMOS muxed in from the U.S. UHD. All I did was grab 10 mins using MKVMerge. How about this alternate 12-minute sample?
General
Unique ID : 43423067619885647336934049003625743423 (0x20AAFA86E1AC8D1F197851C75E8B843F)
Complete name : E:\3d-mvc-sample2.3D.MVC.ATMOS.mkv
Format : Matroska
Format version : Version 4
File size : 3.30 GiB
Duration : 12 min 0 s
Overall bit rate mode : Variable
Overall bit rate : 39.3 Mb/s
Frame rate : 23.976 FPS
Movie name : Movie Name (2023)
Encoded date : 2025-01-23 23:46:43 UTC
Writing application : mkvmerge v88.0 ('All I Know') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Stereo High@L4.1 / High@L4.1
MultiView_Layout : Both Eyes laced in one block (left eye first)
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, Slice count : 6 slices per frame
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 35.5 Mb/s
Maximum bit rate : 30.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.714
Stream size : 2.98 GiB (90%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Original source medium : Blu-ray
Audio
ID in the original source medium : 4353 (0x1101)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate : 3 724 kb/s
Maximum bit rate : 5 628 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 320 MiB (9%)
Title : Dolby ATMOS
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Menu
00:00:00.000 : en:Chapter 10
00:01:10.945 : en:Chapter 11
00:03:58.196 : en:Chapter 12
00:05:41.382 : en:Chapter 13
00:09:12.134 : en:Chapter 14
00:11:46.580 : en:Chapter 15
Tested 21.2 & nightlies on kinhank G1, it plays fine via nas/nfs but crashes played via USB plugged in. How are you playing your files & why not revert to last build that worked for you until they look into the logs.
With @Xenothar , can you also provide fresh logs for 21.2, is a really bizarre bcuz yours never worked from beginning even though we have similar tv-my c6 vs is e6.
Sure can do.
2nd run with debug turned on (Crash Log failed to upload, because it seems to be too big, so uploaded to Kodi pastebin directly):
I used the 12 minute sample from hdmkv (ducks).
Setup as usual: Ugoos AM6B+ with direct HDMI connection to LG E6 passive 4k 3D TV.
File was played from internal storage this time, but the behavior is the same as from SMB Share.
CE freshly updated to 21.2, no addons. Please check post 476 in this thread for a more comprehensive overview of what I tested so far.
@xmlcom: My suspicion is something between Kodi/CE and this particular Ugoos model, as I have two with the same issue and hdmkv also sees this issues, I don’t think its a hardware fault for that reason.
The Kinhank G1 is a quite different device. Different chipset, different Android base (if that matters) and so on. I also have only seen problems with the Ugoos AM6B(+) in this thead and others. Which is sad, as this box is pretty much perfect for DV FEL and so on.
Have Homatics & generic TOX3 S905X4 boxes ordered to test, so good to hear it’s working Kinhank G1 as it likely will on those. To @Xenothar’s point however, the AM6B+ was the best/perfect do-it-all local media player until this 3D issue.
3D is not dead in home cinema. 3D projectors have been around for years, but its current and future state is with VR. Not just because of Apple, but that did give it a much needed boost. But while VR works very well, it doesn’t help with CoreElec. So I hope there are some on here who can provide samples you need to help with troubleshooting.
It works flawlessly on Homatics R Plus (V14 1782), no issue whatsoever with that one ![]()
Yep @Enet, I’ve been hearing 3D is dead for several years now, yet it lives on… several projectors, Apple VR as you noted, and titles released in Japan and more coming from Turbine in Germany. Turbine’s ‘Mission: Impossible - Fallout’ is so good, especially the IMAX scenes in 3D, you won’t watch it any other way once you experience it (it’s a guarantee
:D), even easily besting 4K w/DV.
Guardians of the Galaxy 3 (Japan), Bumblebee, Rise of the Beasts, MI Fallout are just a few of the 3D movies released this year ![]()
All this moaning around do nothing when nobody actually do really debug and/or try to fix it…
Any PR is welcome.
Any good 3D is easily besting anything in 2D DV ![]()
Not of you don’t have “stereo” vision.
We are not cyclops, so we all do have “stereo” vision ![]()
my right eye is not in good shape…
Hi @Portisch , latest nightlies now crash on rocktek g2. Thanks för your help.
paste.coreelec.org/RaptureFleas
paste.coreelec.org/PavedListing
