2 posts were split to a new topic: Khadas VIM3, “green” screen and “installtoemmc”
I tried the rpi4 version and it appears to have worked. If it fails I’ll try these. Thanks
copy the libssl.so.1.0.0 and libcrypto.so.1.0.0 files to the “~/.kodi/addons/service.tvheadend43/lib/” folder
lib.zip
quick question, i have all my boxes at 9.0.3 running on internal, I should be able to update to 9.2.0 via .tar right? eventhough it’s not supported.
Yes, it should work fine.
I have installed Corelec 9.2 on Yoka Bb2 (clone of Mecool BB2), wifi e Bluetooth works very well, but not recognize wired connection. On Mecool BB2 pro wired connection works well and hardware is the same, wired 1 gb.
Thanks in advance
Hello, I’m working with Android 9 S905X firmware for my employer.
I see it has 4.9.113 kernel.
I wonder if we can try to run Amlogic-ng CE with new kernel on S905X easily, if not what is needed?
I’m ready to help in porting if time and my skill permits
What is the status of that branch?
I updated from 9.03. I wasn’t aware I had first to disable add-on. Everything works fine but:
- add-ons from kodi add-on repo are slow. Dazn, the one I’m using, is choppy.
- Kodi repo add-on does not work (any download/updated fails)
I then read this thread that suggests to disable all add-on before updating. I disable all my add-ons and re-applied the update. Then I refresh the repo (going into repo and update) and it seems it update. But then going back to enable the add-on the update fails (BTW the add-on does mention the repository, it says unknown).
Can I revert back to 9.03? I there something else I can do?
I have removed my addonsdb file from my user Dir.
Then upgraded and enabled every used add-on. This worked for me
Not clear where this file is located. Could you please be more precise e detail the path?
.Kodi/user data/database/addonsdb27.db
It’s in your Kodi profile folder
Does that reestablish the functionality of the Kodi add-on repositary? Do I loose all the add-on I have disable but not uninstalled?
Could you give compiled ng-build for S912 please? Any bugs?
There is no -ng build for the S912.
Or there any info if any progress is being made for multi channel PCM support?
No sorry, too many other issues that this is at the bottom of the list.
Yes for me all repository’s worked again after I installed them with zip files. The add-ons were only disabled, I enabled all of them again and they kept their settings.
The good news is that the team is working on it right now.
