9.2.2 Discussion
Try to disable Spotify and reboot, if that works and is enough for “succession”, then enable it when you need it.
Did you try with some video or i need to share some clip?
My N2 4GB freezes pretty often (Once every 1-3 hours playback) I cant see anything in the event log other than what happened after boot. It seems to happen both on 4k hdr mkv files and also a simple 400mb avi file tv episode.
First thing i think of is temp.
Does the N2 feel hot when this happens ?
Will check next time
Hi guys! I have a problem with my s905x2 since updating to 9.2.2…hdr2sdr doesn’t work… any solution to this?
Try reading about this topic HERE
No it just freezes, its warm, but not hot at all.
And this freeze was playing a 40min avi file at 400MB, so dont seem to be due to resources
pixel format: yuv420p
video decoder: ff-mpeg4 (sw)
deinterlaced method unknown
Displaymode: 3840x2160p24hz
pixel format: 10-bit, YUV444
EOTF and gamut: SDR BT.709
But it its random, so not sure what causes it, after a hard reboot I just continue from where it crashed
Odroid N2 4GB running on eMMC
Do you run from sdcard or emmc?
It might be a faulty card.
Shame it doesn’t leave something useful in the log. Unfortunately just a guessing game …
Look carefully at the last line in his post :wink:
Oh yeah, missed that …
Hi, I have issues with transfer speed using samba.
I’m using Odroid N2 4GB, booting from SD. I have several USB3 HDDs connected. Two of them are connected directly to N2 USB ports, three others are connected using USB3 hub. All NTFS. I tried ext4 but no change with that. No matter which drive I use, I can copy files to it via samba with a speed about 80MB per second. Which is ok. But I can read data only about 25MB per seconds, which is really slow. I have gigabit ethernet connection between devices, clients are Windows 7 or Windows 10. If I use Ubuntu image directly from Odroid, the speed is 90/90MB per second. So it looks like there is something wrong in Coreelec image. Do you have similar experience? Can I do something to get better speed? Thank you!
When I’ve stopped a movie and later resuming the playback crashes and kodi restarts. Not sure if this is embycon or corelec tho.
Https://paste.kodi.tv/amatonugam
edit:
Here is a crash log kodi_crashlog_20200501095052.log (167.1 KB)
Hi
I have a coreelec problem on the mini x3 box, I chose files similar to sm1_905x3_2g and sm1_905x3_4g files to create dtb.img but I couldn’t boot, the screen is black.
my box configuration is 905x3 ram 4gb, thanks.
You should not go posting the same issue you have already posted HERE
There are 3 of you with this hardware who failed to boot CE.
I’ve pinged another member who apparently booted this box .
Exactly. Double postings are bad and do not help the community. I also made this mistake when I joined here.
I have consulted the link you sent, but failed to complete
Coming here posting the same problem is not going to result in a faster response or a MAGIC Fix. You have been advised to research and try to boot to recovery using an Android APK but you haven’t tried or responded.
I’m also seeing the freeze issue with one UHD movie. I already tried remuxing but no help.
The “good” thing is that the freeze seems to always occur at the exact same points so it’s easily reproducable.
How should I proceed to help debug it?
Best is to provide a sample which it can be reproduced in.
