Hyperion.NG under CE 9.2.2 breaks TVheadend-HW-acceleration
See Post #36 in this thread - Logs of the shown errors are 2 posts above this on:
Does anyone else use the Turn Off screensaver addon? It no longer seems to work when movies are paused, and I would love it if someone else could confirm it was not working for them also.
Hi, It seems that I have issues (lags) with certain encoded videos. The only common thing I’ve noticed about all lagging videos is that they have 3 Ref Frames.
The issue seems the same for 9.0.0, 9.2.0 and 9.2.2 CE versions.
My Hardware is Transpeed M96 Plus (S912 box)
Can some, please, advice?
Here is debug log: https://pastebin.com/eAfXeEWW
Here’s the sample file: https://www.dropbox.com/s/969vhjo5nfgpzkx/sample.mkv?dl=0
On the MINIX Neo U1 (Amlogic s905 SoC) – the Ethernet stopped working as of 9.2.2.
Prior to 9.2.2, I’ve never had a problem with the Ethernet connection.
I am currently using WiFi as a temporary workaround.
Any ideas for a fix to Ethernet?
Tested CE 9.2.2 stable on Tanix TX5 Plus Deluxe Edition (4/64/S905X3/1G): everything works.
Used sm1_s905x3_4g_1gbit on 16 GB SD Card.
Hi can anyone suggest a usb WiFi adapter that is compatible with 9.2.2 cheaper the better. I’m trying to breathe new life into a old tx3 mini for use in a camper van
I have the same problem. Tomorrow i will try to update android firmware
Edit: Ethernet work fine after updated android firmware
Closing due to 9.2.3 release, further discussion here:
