Put the .tar file for your box, from the links below/above, in the .update Folder on your boxes file structure . Maybe you must activate “show hidden files” if you are connecting from a Computer. Then restart and the update (downgrade) should start.
I did that too but the same problem. After rebooting I get the Khadas Logo and the SBC turns off.
Can anyone else confirm that the screensaver ‘Turn Off’ will not turn off the TV via CEC if a movie is playing, but will work fine if it is just idle in the Kodi menu?
I have two a905x boxes, on two different TVs, that are showing this behavior. They had worked in the past, and CEC is clearly working as the screensaver starts as long as a movie is not paused.
I do have ‘Use dim if paused’ unchecked.
Hi! I’ve seen this question been already asked here, but no answer was given yet - how to reenable nightly updates?
After update to 9.2.2 Coreelec became stable and stopped getting nightly updates.
Is it possible to switch to nightly again over GUI or ssh? Or do I have to manually put latest nightly into .update folder?
Yes, thats the way
Thanks, I’ll update this way then.
could someone kindly explain what “USB power” in CE-settings does? I just bought an Odroid C4 and my wifi dongle isn’t working, like if it’s not getting any power (it was working on the C2)
I think that it does nothing when Kodi is running. It turns USB power off/on when C4 goes to sleep/suspend.
Btw, which WiFi dongle, which chipset, are you talking about, and report your problem on this topic.
It does nothing in the X96 Air, so its impact is highly variable from device to device.
Correct, it’s only for suspend/power off. Default is to power off USB when device is off. With enable this option the USB power remain on even in power off.
It’s device (hardware) dependend if this option is supported or not.
Thank you, I didn’t see the topic about WiFi issues…
BTW it’s a TP-Link Archer T2U, should use a MediaTek MT7610U chipset
Can anyone provide this firmware: VIM3L.COREELEC.9.2.0.emmc.kresq?
Hi, anyone can tell me what Vesa display is made for?
Thx in advance.
For the VESA video modes (resolutions that different from the tv resolutions)
Vesa display resolutions use usually many computer monitors, so this mode is mainly for them.
Thank You. I almost thought its for VESA mounting standard.
Ironically, also seen as native resolution on some (usually <= 32’) TV’s.
Yes, but VESA does not stand only for picture format/resolution. It also defines multiple horizontal/vertical frequencies which differ from standard tv frequencies (for old tvs 50/60Hz, and for new tvs 24, 25, 30, 50, 60…)
See VESA mode table
Downgrading will not fix or identify an issue with an addon.
Have you at least tried the Nightly ??
Krescue CoreELEC versions are not supported as there are unresolved issues.
You should have opened a thread in the add-ons category in the hope the Devs can identify your issues and along with Logs it can be fixed.
I have been experiencing the exact same issues with the Zattoo PVR addon. Have tried 9.2.1 and 9.2.2 and finally went back to 9.2.0. Teleboy PVR and Zattoo PVR come from the same developer. So there may be some coincidence here if other PVR are not showing the same behaviour.
