No problem for me. Just keep waiting for another build
Did you also try to press and hold the reset button when power on? This will restore bootloader environment and maybe itās working then.
When 3.14 is able to boot 4.9 is also to.
Have this below errors that what is mean
5790.573624@0] di:err:de_irq: enter 12c0000
[ 5792.953594@0] di:err:de_irq: enter 12c0000
I found my ceemmc tool problem, I had USB dirs mounted to the /storage - of course these should not be included in the emmc copy process. Perhaps it would be a nice feature for the ceemmc tool to check for and skip sync of mounts in the /storage ?
The tool stats the folder /storage.
So when you mount other stuff into this it will be included into the calculation.
But maybe this can be avoided, yes. I need to check it.
Thanks a lot for your hard work! CE keeps getting better and better.
FWIW I did not experience that problem. Just updated from 9.2.35 to 9.2.4 on my N2 box and āadjust display refresh rateā stayed set to āOn Start / Stopā.
i upload tar ng version on my X96 MAX, all updated fine, first boot, coreelec logo and black screen
my x96 max is dead
cant turn it on what the hell is happening?
I have a K1 Pro (905D) with CE āinstalled to internalā for centuries and all updates were automatic with no problems at all.
Should I be worried this time?
Maybe its not connected with update, just my bad luck. I have CE installed on sd card, but now i cant turn on my device
power adapter its oki
You need to set a remote wake up code in config.ini for wake up
But why android not working, after i remove sd card? AV hidden button dont do anything too
I had this happen to me during testing on a K1 Pro.
Take out the sd card and plug power in after 5 minutes so to see if Android boots.
It should boot eventually.
If it boots. Then insert the sd card whilst android is still running.
@skupi Then reboot. POWER OFF then POWER ON
Hopefully it works.
I have this in my log and i canāt Update.
I have s905x.
2020-08-09 09:47:50.724 T:3011904384 WARNING: ## CoreELEC Addon ## oe::download_file(https://releases.coreelec.org/CoreELEC-Amlogic.arm-9.2.4.tar, /storage/.kodi/temp/update_file) ## ERROR: (UnicodeDecodeError(āasciiā, '\xd0\x98\xd0\xbc\xd1\x8f \xd1\x84\xd0\xb0\xd0\xb9\xd0\xbb\xd0\xb0: ', 0, 1, āordinal not in range(128)ā))
I tried everything. I changed power adapter, use button for 20-50s, wait without power supply whole night
my device is dead looks like, but i have no idea why just after update. As i said update went fine, but after coreelec logo first run all switched off and now is dead
Do you have enough space left on your storage partition?
It could also be a faulty download. What happens, if you manually download the tar file to your /storage/.update/ folder and reboot your box?
Sorry i just read post above the other one you posted.
Mine did not carry out the update.
It rebooted to black screen.
Different symptom.
My update proceeded after the black screen when it booted Android
then powered off and on after that.
You need Amlogic Burning Tool
Burn the Android image for your box.
Only thing you can try.
I have the same problem - t95q
TR99 X2 (S905X2 / 2G) here, also dead after the update⦠Was booting from SD, Android was on eMMC, but itās not going there.
I have two 922 Boxes , everything is ok
But the other two 905 X2 Boxes are dead after update
Arm Burning tool dont work anymore
i think the problem is the bl 301 blob on X2 Boxes
If the bl 301 blob is activated the X2 Boxes crashes
Please be carefull
