9.2.4.2 Discussion
thank you for the instructions, I’ll try that tomorrow.
with over 30°C it is a bit too hot for such things :wink:
and the worst part: already thought about buying a S905X3 box…but the cheap ones are out of stock…
I am always a lucky punk :-/
This type of SoC is not affected by this bug and GXL support is still experimental.
BL301 issues can only be solved by a UART log.
My MXQ Po 4k cant connect to wifi after update. I can see the networks but when i connect all i get is “associating” and “failure”
New 9.2.4.1 builds were uploaded to fix the bl301 injection issue. Please use that.
Installed, in fact updated my S905X box from -ng nightly to -ng 9.2.4 stable and everything works perfect for me. I don’t need nor use bl301 on this box, so should I also update to 9.2.4.1 or can stay on present 9.2.4?
It can’t hurt to update to 9.2.4.1.
But the bl301_inject bug was the only thing that got fixed and your S905X device wasn’t affected by this issue anyway.
Thanks @Portisch, I didn’t have much hope after shorting everything I could find, somehow assuming @skupi’s case would hit me, too, and the eMMC Android would take over.
I’ve now written a guide (it’s under moderation) on how I unbricked my TR99 X2, maybe it helps someone.
I’ve rolled back to 9.2.3 on my N2. I’m finding random but consistent slow downs that require reboots to rectify. When I have time, I may try 9.2.4.1 again as a fresh install. Also CEC doesn’t work on my Panasonic OLED, where 9.2.3 is great. Might be the updated libCEC version I think I saw mentioned above. Anyway, not a big issue, just a preference for me right now.
So nothing about wifi not working on MXQ PRO 4K? I mean like this I cannot really use my box…
Since there always ends up being a libcec issue for somebody when it gets updated, we made it so that you can configure which version of libcec is used. How to configure used libCEC version
So maybe switching to a different version then default may help your situation.
Which specific update is giving you the issue?
I just upgrade to 9.2.4.1 on my N2+. SMB is not working. I cant browse to any of my shares on my freenas server. Kodi works fine on my PC, Nvidia shield and when running 9.31 on my N2+. I did a fresh image install on my 16gb emec.
Anyone else have this issue?
I was able to type the full path and connect so I got it working but Kodi doesnt autofind servers on my network when browsing for the path.
Is this a bug? Never had an issue with 9.3.1
Not sure what 9.3.1 is. N2+ is only supported from 9.2.4 up. Running older versions can lead to hardware failure.
Any chance that the 9.2.4.1 update fixed the extremely slow GUI response?
With 9.2.4 i had slow GUI response, which i fixed by disabling hdmi CEC via config.ini
Are you sure that you have GXL device(S905X)? The update tar file does not work for GXL devices…that’s what I read in download section.
Have you tried this fix ?
You wouldn’t possibly have a Samsung TV ?
There are a couple places we still have to get to updating with information about supporting GXL devices with the ng builds. Unfortunately the initial 9.2.4 release had a couple issue, which distracted the developers from getting more information up about the GXL support with the amlogic-ng builds.
Will hopefully get the updated information about the GXL support in place in the next couple of days.
I thought 4.0.4 was the default libcec version? I’ll try it out when i get home in a couple of hours.
And no it’s not a Samsung. It’s H96 Pro+ > Denon X4300
Sony 4k TV
With 9.2.4.1 I have a purple screen.
First I’d a black screen and updated via ssh and suddenly the coreelec screen came back but with a purple overlay.
Device: Odroid N2
Kodi log can be found here:
http://ix.io/2tLq
System log:
http://ix.io/2tLr
edit: Turning off and on the tv removes the purple overlay :thinking:
