Also make sure to get rid of 9.2.4 on SD card otherwise it might brick again. I’m already building 9.2.4.1. Hopefully it will fix the issue
The only problem that I had with the update was that I couldn’t start from internal after executing the ceemmc tool till I placed a nightly tar in the sd’s update folder. Right after the sd’s coreelec was replaced for the nightly it allowed to boot from internal.
I’ll provide any requested log if it happens again repeating the process with the patch that will be released.
But I first wanted to see if anyone knew what could have been.
I put again the same sd card and coreelec work fine
Ahh right it is now uninjected. Can you please add a step by step instructions for other users. Thanks.
In the meantime I am preparing a 9.2.4.1 emergency update. With bl301_injection bump reverted.
After the automatic update today to 9.2.4 armlogic on my 905W i cannot connect through wifi.
Thank you.
What file/s did you have on the SD card?
Was the SD card formatted to FAT32 or other format?
I have located the pins - thanks for the image - but have had no success so far.
A step-by-step guide would be appreciated, thanks.
@skupi I have a new official build with bl301_inject reverted. Do you feel lucky to test an update from an 9.2.3 injected X96Max?
My KIII Pro s912 still not having a smooth playback on HD channels. It is freezing 1sec each 3sec
I don’t use sd card, I have Android on internal nand. I don’t enter recovery but just get correct boot to Android. I did Android update and after that my box start correctly.
I connect USB cable for burning tool to USB 3.0, connect power adapter and short those pin suddenly I saw boot on display. I found on freaktab that other pin someone suggest I will upload it later. I will be at home.
sd card was not inside box.
I tried get recovery but I can’t, only boot to Android.
Iam not sure. Cause I am luckly achieve only boot to Android not to recovery. And Android update help me.
damn, my TX5 Pro is dead too
just after the update was installed. not even android is booting either, completely fubar
ordered a usb-a to usb-a cable to try the burning too.
or anyone got another great idea?
first time that an update was that bad…but it happens
installed kodi on my TV (yuk) so my dauther won’t bite me
Here’s the top and bottom of my TR99 X2, any idea which pins I am looking to short? Any pointers on what to look for?
Solution:
Look on freaktab
Try to get into recovery. But probably you will need to short pins.
Just auto updated on x3 max 96 plus 2. & so slow!!!
Never had this before after an update!
It’s ok until RSS feed begins to scroll.
thank you! but it seems I am the only one with this board?!?
there two pins next to the NAND are too easy?!?
not even the recovery is loading
still looking for confirmation for the two pins
Everyone who downloaded 9.2.4 already and didn’t perform a update please DO NOT!
Just delete the tar file in /storage/.update if already downloaded!
inject_bl301 has a error with G12A (S905X2) if BL301 got injected before update.
So only this constellation get bricked. Others are save like if another SoC type or BL301 is not injected.
It’s already fixed and a new release image will be published soon.
Sorry for that
@Saviq you see the lines left and right of the Samsung eMMC?
You need to try to find the pins by shorten every time only 2 when until it works.
I do it like DC power off, shorten two pins, DC power on, release the short after ~5 seconds.
If no recover is seen on screen: DC power off again and try next 2 pins. Same procedure again.
@1of16 this pins looks like it’s for this action. Also there are a lot others under the chip. Just do the same procedure as above to find the correct pins.
When you shorten pins and the LEDs stay off release immediately the shorten pins!
Remember: when performing a eMMC short out a micro SD card created by Burncardmaker have to be insert. Then the device will boot from this micro SD card instead of eMMC.
I have also bricked a Beelink W95 S905W box. After inject with BL301, the box didn’t start anymore i must also shorten two pins for the recovery mode. Now the Box runs with 9.2.3.95.
My Nexbox runs very will with the inject.
