Amlogic Color Space / Depth information addon
…post under…
Thanks for the script.
Is there a similar DialogPlayerProcessInfo.xml for default Estuary skin ?
Sorry, I never use that skin, but its possible to made similar.
Can you make it ? You’d surely have many customers :wink:
Modded the original coreelec estuary skin PlayerProcessInfo dialog… :smiley:
Just tried it, works great - thank you very much for your effort :clap:
gputemp=cputemp on Amlogic devices
Sorry for the stupid question. Where this file should be copied?
If you are using default skin than it’s not for you.
I have a copy of files from original Estuary skin (a bit modified and renamed) in
storage/.kodi/addons/skin.estuaryV1 folder. There you can change what ever you like…
This file goes to (in my case) storage/.kodi/addons/skin.estuaryV1/xml folder.
Original Estuary skin files are in root/usr/share/kodi/addons/skin.estuary folder.
I will merge that. Thx.
Maybe you can add GPU speed under CPU speed, it will be even more informative and better looking filling the empty space under Pixel format.
There is no label for that in Kodi systemInfoLabels
SoC temperature instead CPU GPU temperature would be better.
The temp and pixel format should be swapped.
CPU Speed:
SoC temp:
System FPS:
And I’m not sure why pixel format is duplicated.
There is 2 pixel format : Player.Process(deintmethod) , and the second under display mode: amlogic.hdmitx.colourdepth, normally ColourDepth …
Yep, there is an issue on the original CE repo estuary lang file : en_stings.po
msgctxt “#31169”
msgid “Pixel format”
msgstr “”
Need change to Colour format :slight_smile:
you can add a lot of info, some time ago I did various (own) corrections in skins, but estuary is one of the least interesting skins
Can’t you make it from: cat /sys/class/mpgpu/cur_freq ?
But it’s the only official skin guarantied to have all options working…
possible but i don’t like estuary
