Looks like the addon do crash:
/storage/.kodi/addons/driver.dvb.sundtek-mediatv/bin/mediasrv
So you will need to check with the addon author what’s wrong. Did you reinstall the fresh addon?
Because when it’s from a backup it’s wrong arm architecture. Amlogic-no is aarch64 and Amlogic-ng was arm before.
Its a fresh installation from coreelec repo version 21.0.0
The bin file is different from the ng Version
If I disable the addon and then I enable it ,coreelec crashes and I have to
power off the device
@Portisch Do you have a preview in hyperion when using the menu in kodi (not watching videos) Amlogic-no Discussion - #168 by tomasiek
Yes works here normal:
But I am not sure and maybe use a “newer” version.
Make a backup of your Hyperion and then remove it completely. Then try to install this one:
I am not 100% sure if it’s compatible as it’s two months ago build.
The screenshot you showed is from playback, not from the Kodi menu. I’ll check in a moment.
//edit:
Well, unfortunately - still no effect. I reinstall, reconfigured hyperion and restarted kodi. Still no backlight both in the Kodi menu (without playback) and when playing Netflix. Disney, local files - work
Ah, yes. It’s nothing visible.
I did not realize as I have a minimum led brightness adjusted. So it’s something about the fb_grabber.
Will add it to the open items list…
The issue which affects the sundtek tuners has been found in coreelec the kernel is missing SYSV-IPC, CoreELEC will be updated and the tuners should work again.
Great. So the error with no backlight in Netflix may also be related to this.
Amlogic-ne images were build today, Amlogic-no will be tomorrow.
Has “NO” supporting 64GB uSD Card’s yet? No matter how many times I try, the deployment stops on resizing the storage partition.
With the new kernel I was able to test an external bluetooth adapter connected to the VIM4. The Homatics bluetooth remote auto reconnects to it.
https://www.amazon.com/gp/product/B09MZ8715D/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Thats`s not a matter of the size. I have with a 32 GB card the same problem. Reboot requires a power off/on. (S905X3)
Could you try this image with 5980 and 5990?
The Sundtek tuner are working well now
Thanks and a happy new year for Coreelec and Sundtek Team
Greetings, happy new year.
I will try it as soon as possible.
Thanks a lot.
Kind regards…
I need the disp_cap for my server , because I dont use Hdmi connection on it
But this dont work for me
Is it possible to activate it ?
No, it’s not since 5.4
Hi buddy,
I tried the image you gave yesterday and the tuners worked, it was great.
Even the CA feature of the tuners worked, and I was very happy about that. Because this feature never worked before. And I got rid of the server on the PC.
But there is a problem with 5980: Some satellite channels (FTA channels) freeze.
After a little research, this problem occurs on channels with high BER values in the Satellite Signal.
There is no such problem in 5990.
In addition, channel transitions are also very satisfactory.
In short: I am very happy and joyful.
Thank you very much…
Best regards…
Probably 5990 has a better tuner?
Maybe, or because the 5980 is an older model.
