I want to switch to a new device, but I can’t. I want to upgrade to an image with a new kernel, but it doesn’t work.
Because the 2 TBS Tuners I have are not working.
One is 5980 and the other is 5990.
When these work, I will use the new kernel and image.
Or I will continue like this until the device I am currently using breaks down.
I am sad…
Best regards…
I prepared drivers for the rest of the newer TBS USB tuners - 5930, 5930 lite, 5530, 5230. This is it for now.
@smp thanks to the whole CE team and to you,we can buy TBS5530 for my friend now
Best regards…
So further to my last post (which was never answered…), can anyone explain why you would run -no on a device running -ng or -ne that is happily chugging along? Is it purely just for people obsessed with running a newer Linux kernel? Any benefits to playback?
Struggling to understand the point of it right now.
NO is in Testing and Development stage.
There is no advantage over ng or ne
Truthfully you are probably at a disadvantage
As was posted in read me
There is a good chance wifi/Bluetooth drivers have not been added/implemented in new Kernel
If one is happy with current CoreELEC version
NG NE
If it is not broke
Do not fix it.
However this is the future or path/direction
CoreELEC is heading
Considering it starts with S905X2
The Future looks good :+1:
Other versions are/will not be used/needed
More explanation in read me
Happy Testing
Ok - I ran tests on the latest nightly (installed on a microSD card - I have the NG version installed in the emc memory). Kodi clean, only hyperion settings restored from the copy. On Disney+ - the lights work. On Netflix - no. No image preview. What’s interesting - on the hyperion website it doesn’t show me the Kodi desktop preview or the highlight in the Kodi menu
Kodi menu - no backlight/no preview
Netflix - no backlight/no preview
Disney - backlight/preview
Everything works fine on the latest version of nightly NG:
Kodi menu - backlight/preview
Maybe you bring issue with it - why not try completelly fresh?
Ok, I turned off Kodi, deleted hyperion data, restarted coreelec, re-entered the LED/Ambilight settings, etc. manually. The effect is exactly the same - there is no highlighting or preview in the Kodi and Netflix menus
Hello friend,
I have TBS 5980 and TBS 5990 models. I would be very happy if you could add these too.
And is information/documentation required?
If necessary, which ones are required?
I would like to help.
TBS5980 QBOX CI DVB-S2 TV Tuner USB -External TV Tuner Box for Laptop and PC .
TBS5990 QBOX CI DVB-S2 TV Tuner USB -External TV Tuner Box for Laptop and PC .
Thanks in advance…
Kind regards…
5990 is not that easy to add, so probably no.
Why?
But for me, 5980 is enough if it works.
Best regards…
If you have a problem with our Tuner (Sundtek) maybe you can sign on in the sundtek forum or join the chat explain your problem and wait some time until someone of our Team will see it so we can have a look at what’s wrong with your system.
oastra, please post dmesg from SSH console from latest nightly build
dmesg | paste
I do have two (old) Sundtek devices.
First one is SkyTV Ultimate II which works.
Sundtek DVB-S/S2 #0 : DVB-S #0
Universal LNB only
But the second one MediaTV Pro II is not working - there is some kernel issue it seems.
[   21.177898@3]  mediasrv[1040]: unhandled exception: 11 DABT (lower EL), ESR 0x92000044, level 1 translation fault in libc.so.6[7f9fef0000+168000]
[   21.177926@3]  vma for 7f9ff83d9c:
[   21.177931@3]  7f9fef0000-7fa0058000 r-xp 00000000 07:00 2860
[   21.177935@3]  /usr/lib/libc.so.6
[   21.177938@3]
[   21.177942@3]  vma for 4422a4:
[   21.177946@3]  00400000-00670000 r-xp 00000000 08:02 3833888
[   21.177951@3]  /storage/.kodi/addons/driver.dvb.sundtek-mediatv/bin/mediasrv
[   21.177954@3]
[   21.177958@3]  can't find vma for ffffffffffffffff
[   21.177962@3]  PC : 0000007f9ff83d9c  U
[   21.177965@3]  SP : 0000007f9f6de160  U
[   21.177970@3]  FAR : ffffffffffffffff, PFN:***** V
[   21.177973@3]  R0  : ffffffffffffffff, PFN:***** V
[   21.177976@3]  R3  : fffffffffffffff0, PFN:***** V
[   21.177983@3]  CPU: 3 PID: 1040 Comm: mediasrv Tainted: P           O      5.4.210 #1
[   21.177986@3]  Hardware name: sc2_s905x4_ah212-id6 (DT)
[   21.177991@3]  pstate: 20001000 (nzCv daif -PAN -UAO)
[   21.177994@3]  pc : 0000007f9ff83d9c
[   21.177997@3]  lr : 00000000004422a4
[   21.178000@3]  sp : 0000007f9f6de160
[   21.178002@3]  x29: 0000007f9f6de170 x28: 0000000000000001
[   21.178007@3]  x27: 0000007f9f6df180 x26: 0000007fa01a6000
[   21.178011@3]  x25: 0000000000000000 x24: 0000000000000002
[   21.178015@3]  x23: 0000007fa019eb80 x22: 0000000000000020
[   21.178020@3]  x21: 0000007fdf87c228 x20: 0000007f9f6df180
[   21.178024@3]  x19: 0000000000001000 x18: 00000000000007e7
[   21.178028@3]  x17: 0000007f9ff83d00 x16: 0000000000670488
[   21.178032@3]  x15: 0000000000416b9a x14: 0000000000000000
[   21.178036@3]  x13: 0000000000000000 x12: 0000007fa01a7340
[   21.178040@3]  x11: 00000000ffffffd0 x10: 0000000000000000
[   21.178044@3]  x9 : 0000000000668160 x8 : 0000007f9f6dde4c
[   21.178048@3]  x7 : 0000000000000004 x6 : 0000000000000000
[   21.178052@3]  x5 : 0000000000000000 x4 : 00000000000e57e0
[   21.178056@3]  x3 : fffffffffffffff0 x2 : 00000000000e57e1
[   21.178061@3]  x1 : 0000000000000000 x0 : ffffffffffffffff
[   21.178066@3]
[   21.178066@3]  PC: 0x7f9ff83d1c:
[   21.178069@3]  3d1c  4e083c01 361800a2 f9000001 f81f8081 d65f03c0 d503201f 36100082 b9000001
[   21.178077@3]  3d3c  b81fc081 d65f03c0 b4000082 39000001 36080042 781fe081 d65f03c0 3d800000
[   21.178085@3]  3d5c  37300122 3c9f0080 36280062 3d800400 3c9e0080 d65f03c0 d503201f d503201f
[   21.178093@3]  3d7c  d503201f 3d800400 ad010000 ad3f0080 d65f03c0 d503201f 12001c21 927cec03
[   21.178100@3]  3d9c  3d800000 f104005f 7a402820 54000160 cb030082 d1004063 d1014042 ad010060
[   21.178108@3]  3dbc  ad820060 f1010042 54ffffa8 ad3e0080 ad3f0080 d65f03c0 d503201f d53b00e5
[   21.178115@3]  3ddc  3727fe85 12000ca5 710010bf 54000281 3d800460 ad010060 927ae463 ad020060
[   21.178123@3]  3dfc  ad030060 cb030082 d1040042 91020063 d503201f d50b7423 91010063 f1010042
[   21.178131@3]
[   21.178131@3]  LR: 0x442224:
[   21.178134@3]  2224  9100c3a1 f9400000 f9400021 d2800002 b94497a3 52800404 94044c3a aa0003e1
[   21.178141@3]  2244  f9425fa0 f907ac01 9100e3a0 9100c3a1 f9400000 f9400021 d2800002 528afc23
[   21.178149@3]  2264  72a001c3 52800204 94044c2e aa0003e1 f9425fa0 f907b001 f9425fa1 528afc20
[   21.178157@3]  2284  72a001c0 b90f7820 f9425fa0 f947b000 52800001 d28afc22 f2a001c2 97ff0b00
[   21.178164@3]  22a4  9100e3a0 f9400000 f940e400 9100c3a1 f9400021 91403023 91046063 90000e41
[   21.178172@3]  22c4  91280021 9103c3a2 94044117 9100e3a0 f9400000 f940e400 9100c3a1 f9400021
[   21.178179@3]  22e4  91403023 91046063 90000e41 91284021 910383a2 9404410c 9100e3a0 f9400000
[   21.178187@3]  2304  f940e400 9100c3a1 f9400021 91403023 91046063 90000e41 9128c021 9103a3a2
[   21.178195@3]
[   21.178195@3]  SP: 0x7f9f6de0e0:
[   21.178198@3]  e0e0  008a6d34 00000000 00000026 00000000 00000010 00000000 00000000 00000000
[   21.178205@3]  e100  00000000 00000000 00000004 00000000 9f6de170 0000007f 00442270 00000000
[   21.178213@3]  e120  00001000 00000000 9f6df180 0000007f 00000010 000e6000 00000000 00000000
[   21.178220@3]  e140  94000b70 0000007f 161319a0 00000000 ffffffff ffffffff 004421d8 ffffffff
[   21.178228@3]  e160  00000000 00000000 00000000 00000000 9f6de690 0000007f 005641b4 00000000
[   21.178236@3]  e180  9400d380 0000007f 00000000 00000000 00000000 00000000 00000000 00000000
[   21.178243@3]  e1a0  94000b70 0000007f 161319a0 00000000 00000000 00000000 00000000 00000000
[   21.178251@3]  e1c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.178259@3]
[   21.178259@3]  r2: 0xe5761:
[   21.178262@3]  5760  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178278@3]  5780  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178288@3]  57a0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178298@3]  57c0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178308@3]  57e0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178318@3]  5800  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178328@3]  5820  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178337@3]  5840  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178347@3]  5860  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178358@3]
[   21.178358@3]  r4: 0xe5760:
[   21.178361@3]  5760  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178371@3]  5780  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178380@3]  57a0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178390@3]  57c0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178400@3]  57e0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178410@3]  5800  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178420@3]  5820  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178430@3]  5840  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178441@3]
[   21.178441@3]  r8: 0x7f9f6dddcc:
[   21.178444@3]  ddcc  0000007f 9f6dde50 0000007f 000000c0 00010005 00000000 00000000 9f6dde4f
[   21.178451@3]  ddec  0000007f 00000000 00000001 9f6dde4f 0000007f 9f6de110 0000007f 00555978
[   21.178459@3]  de0c  00000000 000e57e1 00000000 004577f8 00000000 9f6de018 0000007f 00000000
[   21.178466@3]  de2c  00000000 00000002 00520000 94000b70 0000007f 006647a0 00000000 9400e760
[   21.178474@3]  de4c  00000001 9f6de170 0000007f 004420bc 00000000 9400ef20 0000007f 00000000
[   21.178481@3]  de6c  00000000 9f6ddf90 00000001 9400d630 3000007f 9400ef20 0000007f 9ff3eae4
[   21.178489@3]  de8c  0000007f 0060a9e0 00000000 9f6ddfe0 00000001 9f6ddfb0 0000007f ffffffd0
[   21.178497@3]  deac  ffffff80 00000000 00000000 9400f52a 0000007f 9400f53b 0000007f ffffffff
[   21.178505@3]
[   21.178505@3]  r9: 0x6680e0:
[   21.178508@3]  80e0  4f4e494d 00000052 20495041 73726556 3a6e6f69 2e642520 000a6425 00000000
[   21.178515@3]  8100  69676572 72657473 3a676e69 2f732520 000a6425 00000000 7665642f 6276642f
[   21.178523@3]  8120  2f73252f 6e6f7266 646e6574 00006425 7665642f 6276642f 2f73252f 25727664
[   21.178531@3]  8140  00000064 00000000 7665642f 6276642f 2f73252f 756d6564 00642578 00000000
[   21.178538@3]  8160  7665642f 6276642f 0073252f 00000000 69676572 72657473 76206465 75747269
[   21.178546@3]  8180  203a6c61 000a7325 5f657375 69767674 006f6564 00000000 00006e6f 00000000
[   21.178553@3]  81a0  69767674 006f6564 65646976 0000006f 7665642f 0073252f 62616e55 7420656c
[   21.178565@3]  81c0  7263206f 65746165 20732520 2f642528 0a297325 00000000 63627664 00000069
[   21.178573@3]
[   21.178573@3]  r11: 0xffffff50:
[   21.178575@3]  ff50  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178587@3]  ff70  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178597@3]  ff90  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178607@3]  ffb0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178617@3]  ffd0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178627@3]  fff0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178637@3]  0010  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178647@3]  0030  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178658@3]
[   21.178658@3]  r12: 0x7fa01a72c0:
[   21.178661@3]  72c0  00400190 00000000 a01a72f0 0000007f 00000000 00000000 00000000 00000000
[   21.178668@3]  72e0  00000000 00000000 00000000 00000000 a016690d 0000007f 00000000 00000000
[   21.178676@3]  7300  00000001 00000000 16130000 00000000 00000002 00000000 00000000 00000000
[   21.178683@3]  7320  00000000 00000000 00000000 00000000 00000000 00000000 df87caf8 0000007f
[   21.178690@3]  7340  00000000 00000000 a01a7928 0000007f 00670018 00000000 a01a7930 0000007f
[   21.178698@3]  7360  00000000 00000000 a01a7340 0000007f 00000000 00000000 a01a7910 0000007f
[   21.178705@3]  7380  00000000 00000000 00670048 00000000 00670128 00000000 00670118 00000000
[   21.178713@3]  73a0  006700b8 00000000 006700c8 00000000 006700d8 00000000 00670158 00000000
[   21.178721@3]
[   21.178721@3]  r15: 0x416b1a:
[   21.178724@3]  6b18  d37df000 8b000020 f9400000 f9400000 97ffb972 f94103a0 f947bc01 b9820fa0
[   21.178732@3]  6b38  d37df000 8b000020 f9400000 97ffb96b f94103a0 f947bc01 b9820fa0 d37df000
[   21.178739@3]  6b58  8b000020 f900001f b9420fa0 11000400 b9020fa0 f94103a0 91400400 9100c400
[   21.178747@3]  6b78  39400000 2a0003e1 b9420fa0 6b00003f 54fff42c f94103a0 91400400 9100d000
[   21.178755@3]  6b98  39400000 6b1f001f 540002e0 910083a0 52800001 d2803c02 97ffb8bc 910063a0
[   21.178762@3]  6bb8  f9400000 b9400000 2a0003e1 910083a0 b9000001 910063a0 f9400000 91403000
[   21.178770@3]  6bd8  91030000 f9400000 910083a2 528000c1 94058f83 f94103a0 91400400 9100d000
[   21.178778@3]  6bf8  3900001f 52800000 a8c17bfd 910803ff d65f03c0 a9bd7bfd 910003fd f9000fa0
[   21.178786@3]  6c18  f90017bf f9400fa0 f9403c00 940548ba a8c37bfd d65f03c0 d10903ff a9bf7bfd
[   21.178794@3]
[   21.178794@3]  r16: 0x670408:
[   21.178797@3]  0408  00404a30 00000000 00404a30 00000000 00404a30 00000000 00404a30 00000000
[   21.178805@3]  0428  00404a30 00000000 9ff660a0 0000007f 9ffc2300 0000007f 9ffc26a0 0000007f
[   21.178813@3]  0448  00404a30 00000000 9ff68610 0000007f 9ff7f2e4 0000007f 00404a30 00000000
[   21.178820@3]  0468  9ff17430 0000007f 00404a30 00000000 00404a30 00000000 00404a30 00000000
[   21.178828@3]  0488  9ff83d00 0000007f a01a3440 0000007f 00404a30 00000000 00404a30 00000000
[   21.178836@3]  04a8  9ffcd740 0000007f 00404a30 00000000 00404a30 00000000 00404a30 00000000
[   21.178844@3]  04c8  9ff79350 0000007f 00404a30 00000000 9ff9b690 0000007f 9ff78da0 0000007f
[   21.178852@3]  04e8  00404a30 00000000 00404a30 00000000 9ff7e780 0000007f 9ff9b450 0000007f
[   21.178860@3]
[   21.178860@3]  r17: 0x7f9ff83c80:
[   21.178863@3]  3c80  f1010042 54ffffa8 ad3e0080 ad3f0080 d65f03c0 d503201f d503201f d503201f
[   21.178870@3]  3ca0  3d800460 ad010060 927ae463 ad020060 ad030060 cb030082 d1040042 91020063
[   21.178878@3]  3cc0  d50b7423 91010063 f1010042 54ffffa8 ad000060 ad010060 ad3e0080 ad3f0080
[   21.178886@3]  3ce0  d65f03c0 d503201f d503201f d503201f d503201f d503201f d503201f d503201f
[   21.178893@3]  3d00  d503201f 4e010c20 8b020004 f101805f 54000428 f100405f 54000202 4e083c01
[   21.178901@3]  3d20  361800a2 f9000001 f81f8081 d65f03c0 d503201f 36100082 b9000001 b81fc081
[   21.178908@3]  3d40  d65f03c0 b4000082 39000001 36080042 781fe081 d65f03c0 3d800000 37300122
[   21.178916@3]  3d60  3c9f0080 36280062 3d800400 3c9e0080 d65f03c0 d503201f d503201f d503201f
[   21.178924@3]
[   21.178924@3]  r18: 0x767:
[   21.178927@3]  0764  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178937@3]  0784  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178947@3]  07a4  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178957@3]  07c4  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178966@3]  07e4  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178977@3]  0804  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178987@3]  0824  ******** ******** ******** ******** ******** ******** ******** ********
[   21.178996@3]  0844  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179006@3]  0864  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179017@3]
[   21.179017@3]  r19: 0xf80:
[   21.179020@3]  0f80  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179030@3]  0fa0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179040@3]  0fc0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179049@3]  0fe0  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179059@3]  1000  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179069@3]  1020  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179079@3]  1040  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179089@3]  1060  ******** ******** ******** ******** ******** ******** ******** ********
[   21.179099@3]
[   21.179099@3]  r20: 0x7f9f6df100:
[   21.179102@3]  f100  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179110@3]  f120  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179117@3]  f140  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179125@3]  f160  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179132@3]  f180  00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179140@3]  f1a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179147@3]  f1c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179155@3]  f1e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179162@3]
[   21.179162@3]  r21: 0x7fdf87c1a8:
[   21.179165@3]  c1a8  00000000 00000000 00000001 0000007f a01a7340 0000007f a01a7340 0000007f
[   21.179235@3]  c1c8  000006d8 00000000 006704a8 00000000 a019eb80 0000007f df87caf8 0000007f
[   21.179245@3]  c1e8  00404260 00000000 a019e440 0000007f a01a6000 0000007f 00000000 00000000
[   21.179253@3]  c208  00000000 00000000 a0173d80 0000007f 00000000 00000000 00000000 00000000
[   21.179260@3]  c228  df87c278 0000007f 00000000 00000000 a01a76f0 0000007f a01a6000 0000007f
[   21.179268@3]  c248  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179293@3]  c268  00000000 00000000 00000000 00000000 06799c74 00000000 9ff03ff0 0000007f
[   21.179301@3]  c288  a01a1150 0000007f 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179310@3]
[   21.179310@3]  r23: 0x7fa019eb00:
[   21.179313@3]  eb00  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179320@3]  eb20  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179328@3]  eb40  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179335@3]  eb60  00000001 00000001 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179342@3]  eb80  a019f2d0 0000007f 00000000 00000000 a00d1350 0000007f a00d8568 0000007f
[   21.179350@3]  eba0  00000002 00000000 a000fb50 0000007f a0010150 0000007f a0010a50 0000007f
[   21.179357@3]  ebc0  00000000 00000000 00000000 00000000 00000000 00000000 a00d0a50 0000007f
[   21.179365@3]  ebe0  16130010 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179373@3]
[   21.179373@3]  r26: 0x7fa01a5f80:
[   21.179376@3]  5f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179383@3]  5fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179391@3]  5fc0  a01755a0 0000007f 0003fe28 00000000 a01a5b80 0000007f a01a7338 0000007f
[   21.179400@3]  5fe0  a01a4d80 0000007f a0175a08 0000007f a0175a80 0000007f a01a4d88 0000007f
[   21.179413@3]  6000  a01a7340 0000007f 00000007 00000000 a01a7648 0000007f 00000000 00000000
[   21.179420@3]  6020  a01a1150 0000007f 00000000 00000000 00000000 00000000 00000001 00000000
[   21.179428@3]  6040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179436@3]  6060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179443@3]
[   21.179443@3]  r27: 0x7f9f6df100:
[   21.179446@3]  f100  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179453@3]  f120  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179461@3]  f140  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179468@3]  f160  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179476@3]  f180  00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179483@3]  f1a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179491@3]  f1c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179498@3]  f1e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.179505@3]
[   21.179509@3]  reg              value       pfn  reg              value       pfn
[   21.179514@3]  r0 :  ffffffffffffffff  --------  r1 :  0000000000000000  --------
[   21.179518@3]  r2 :  00000000000e57e1  --------  r3 :  fffffffffffffff0  --------
[   21.179523@3]  r4 :  00000000000e57e0  --------  r5 :  0000000000000000  --------
[   21.179527@3]  r6 :  0000000000000000  --------  r7 :  0000000000000004  --------
[   21.179532@3]  r8 :  0000007f9f6dde4c     d14fa  r9 :  0000000000668160     943f7
[   21.179537@3]  r10:  0000000000000000  --------  r11:  00000000ffffffd0  --------
[   21.179542@3]  r12:  0000007fa01a7340     93fa0  r13:  0000000000000000  --------
[   21.179546@3]  r14:  0000000000000000  --------  r15:  0000000000416b9a     94193
[   21.179551@3]  r16:  0000000000670488     93fad  r17:  0000007f9ff83d00      2b55
[   21.179556@3]  r18:  00000000000007e7  --------  r19:  0000000000001000  --------
[   21.179561@3]  r20:  0000007f9f6df180     d14f5  r21:  0000007fdf87c228     93fab
[   21.179566@3]  r22:  0000000000000020  --------  r23:  0000007fa019eb80     93f9d
[   21.179570@3]  r24:  0000000000000002  --------  r25:  0000000000000000  --------
[   21.179575@3]  r26:  0000007fa01a6000     93f9f  r27:  0000007f9f6df180     d14f5
[   21.179579@3]  r28:  0000000000000001  --------  r29:  0000007f9f6de170     d1721
[   21.179584@3]  r30:  00000000004422a4     93d2a
[   21.179588@3]  pc :  0000007f9ff83d9c      2b55
[   21.179591@3]  sp :  0000007f9f6de160     d1721
[   21.179594@3]  unused :  000000000000107c  --------
[   21.179598@3]  offset :  0000000000000000
I tried to fix this issue some time back without success. Any help would be appreciated.
Whole dmesg: https://paste.coreelec.org/iabxYI
Compile errors that I was not able to solve. This is my effort to add 5990 if anyone else want to try.
I use the Sundtek Tuner Dual S2 and MediaTV Pro III
Addon Sundtek Media TV is installed
The Dual S2 Tuner was found by the Sundtek Addon but dont work with Tvheadend
The MediaTV Pro III Tuner was not found in Media TV
https://paste.coreelec.org/tyVmHT
5990 compile errors solved but I’m not sure if I would PR this. Too many untested changes to the existing cx231xx driver and it may introduce breakage.
Will look into 5980 later.
if you could provide a remote shell to that system I might have a look at it.
How can I do this in Coreelec ?
Can you send an email to kontakt at sundtek de - I’m off for today so I can continue via email when I’m back
So, what’s the situation for the 5980?
Is there hope?
