CE-22 doesn’t support eMMC speed option.
thank you for clarification. is it planned to be supported in further releases?
If you check the dmesg log the kernel does it automatically if your emmc supports it.
so no further action required for full emmc speed/support?
5 posts were merged into an existing topic: New Order: Looking for users with no working WiFi or BT
Can someone explain why the attached file AV1 DV10 only plays audio and black screen in CE NO last nightly on Ugoos X4Q Extra and Homatics Box R 4K Plus? I have many AV1 DV10 files and they all play very fine on CE NO except this one. Thank you
https://mega.nz/file/UK9iGJQQ#u7mmVFYFwcWDk8ccCEE_hZVCl6FFAS310vYKDAV6874
I have a problem with ce22. My HDD on 2tb does not want to be detected by the system, although there is no such problem on ce21. My Box vontar X4 4/32 S905X4
Hard to tell. But logs could tell something: coreelec:ce_support [CoreELEC Wiki]
Could someone tell me where to download the dovi.ko driver compatible with s905x4-j? I would be very grateful. I want to test DV
I don’t understand: is it really so hard to read forum a little? Like the NO thread. Same thing written again and again.
WIFI working OK on my 2nd Tox3 Box, latest NO. Thank you.This box has “slimboxtv: OS.
My original box has Tox3 OS installed and wifi wont work. I will update the the OS to slimboxtv as well, thanks.
Sample just play fine, AV1 DV, 4k.
Tested again and audio ok but black screen. Could be my TV? Panasonic LZ1500? Played trough Ugoos XAQ extra and Homatics Box R 4K Plus both using the latest NO nightly and directly connected to TV Hdmi ports.Can you pls detail your hardware? Thank you
Looks like a SoC issue, does work well on S5, S928X but not on SC2, S905X4.
No idea yet why…
I’ve tested your sample, no video just audio on my Homatics Box R 4K Plus, also no video on my X88PRO X5M and no video when played back on PC using VLC.
But it does play fine on my Zidoo Z9X.
AV1 DV10 was introduced to CE22 in May. Nobody noticed for 3months that AV1 DV10 wasn’t working on the s905x4 ![]()
Step 1, report the problem (done)
Step 2, wait patiently for the problem to be investigated.
It’s a DV sample, the X88PRO X5M isn’t DV licensed.
I have about 200 AV1 DV10 4K movies and all play fine on my s905x4 boxes running CE No.
The reason i have opened this thread is to let CE team know that maybe something else should be investigated on AV1 DV 4K implementation in CE NO.
Thanks for help @YadaYada
I hope you see the answer above: it works on S5, S928X but not on SC2, S905X4.
I’m sure it will be fixed soon.
Yes, I see Portisch answer above thanks.
