Other than DV it plays OK on my S905x4
Plays as HDR10
I know the X5M doesn’t support DV, but the sample has HDR10 fallback that doesn’t play.
I have in sum now two samples, with your last one.
So best would be to share a working sample as well. So it’s much easier to hunt the reason…
I tested the linked file on the X96 M300, and playback is flawless, 4K HDR10, and AV1. Sound and picture are okay.
Here is a working test file:
Testing on G1 Box S905X4-j
Same results non working, green screen with Audio working
Working, is Excellent!!, Anthony Quinn, big Fan of
Just watched Barrabus with Anthony Quinn
I suggest Lawrence of Arabia, but am sure you know it.
Yes is Excellent choice, often think of Peter Otoole,Omar Sharif first then Anthony
The Shoes of the Fisherman
Guns of Navarone
The working sample(working test.mkv) has DV Profile string ā€œdav1.10.08ā€. I also have files with the same profile string, and all of them play back fine. But the one that is not working and giving a blank screen has ā€œdav1.10.06ā€. It might be a cause, which can be confirmed if there are more test files with the same profile string.
The same non-working file(Test.mkv) plays fine in fallback HDR10 mode after disabling DV in System settings. Tested on my G1 S905X4-J.
I will post a sample from a different movie that has got the same problem and does not play.
I did your same observations regarding the DV profile string but, of course, I know nothing about DV10 profile so……………
EDIT: with today NO Alpha 1 this and the previous file play perfectly. Thanks CE Team
Here is test2
Just as a general warning, it was already announced here that the rules for the forum also apply to DMs. All the posts are flagged the same way.
Sorry Vasco what DMs means?
DMs or PMs , discourse treats all as posts, even messages between users.
Hi
How do I get aā€pull requestā€ done?
Apols if I’m not using the right terminology or asking for the wrong thing but I had some issues with the CE set up process not being colour-blind friendly. The short answer is emveepee found out what the issue was with the radio buttons (texture images) and suggested what the changes needed to be and I verified that they worked.
So what is the process for those changes to be checked etc. and added to the next release? I asked in my original thread but no one answered so I figured I’d ask here. I’m still happy to test anything.
Background:
This is same as first sample non working from original post.
What is the latest status of Dolby Vision development for -no?
If I get it right from the posts here, DV is in general working but not FEL decoding at all, even for the Ugoos AM6B+. And it will probably never work due to the not correct dovi.ko file for this kernel. Is this correct?
If yes and if we want full FEL decode we need to stay with the -ng version?
As far as I know, Amlogic has removed FEL support from kernels newer than 4.9.xxx, so yes, if you want FEL, use CE-NG.
That’s a bummer we will never enjoy CE22 with working FEL. But thanks for the answer.
What additional enjoyment does CE22 bring, comparing to CE21.2?
Coreelec team dont have enough developer. For me is also CE21ng better choice due to issues at CE22no. But at CE21NG is missing better cpu frequance management which was implemtwd only at CE22no. My 922xj know use 500 mhz as minimum only at CE22no, and at CE21ng is the lest frequance of same cpu at 677 mhz as minimum. Device is AM6PLUS. Also is missing better maintance at CE21NG compare to CE22no due to not enough developer of CE.
