Yes, it started with 20251224 -20251223.
Working with 20251222
WiFi connecting issue will be fixed with next nightly 20251226.
Piers_nightly_20251226-Generic.img.gz and rebooting, the CoreElec NO screen remained.
N2+ Hangs @ Christmas logo, totally unaccessable after installed
CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20251226-Odroid_N2
I tried doing a clean installation of 20251226. The filesystem gets created, but after the reboot the screen freezes on the CoreELEC Christmas splash screen.
I also tried updating from 20251224 to 20251226. It also freezes on the splash screen and does not boot.
Xiaomi Box S 3rd Gen
Yes, some mariadb-c-connector issue:
/usr/lib/kodi/kodi.bin: error while loading shared libraries: libmariadb.so.3: cannot open shared object file: No such file or directory
dmesg paste
https://paste.coreelec.org/TeamworkEighties
dmesg is useless if kodi fails :frowning:
As written above: issue is known, need to find proper solution.
Amlogic S905X4 Android 11.0 HK1 Box X4 4GB RAM 64GB ROM Dual-WiFi 2.4GHz/5GHz BT Quad Core 64 Bits 3D/8K 1000M
Been using nightlies updating when it downloads, installs and reboots.
Tonight (Chicago time)
CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20251226-Generic.img.gz
Updated and when rebooting stayed at the CoreElec NO Christmas screen.
Downgraded to release and all is well.
IE: I was able to SFTP to build and install release to update directory.
same here.
I have Android TOX3. After updating CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20251226-Generic.img.gz and rebooting, the CoreElec NO screen remained.
Odroid N2+ 4g Ram.
I have the same problem.
For god sake is this alpha2 version? No.
Please read forum a little before posting same posts again and again.
Nightly 20251226 is fixed and was new uploaded now.
Thanks for quickly resolving the problem :slight_smile:
I followed your istructions and put the file in the right place, but it doesn’t work the same.I tried also with a LG remote control that is shown but not paired.I’m using 24/12/2025 nightly.I don’t manage to connect to wifi (it doesn’t ask the password), only ethernet cable with usb hub.
My wifi is also not working.
I made a fresh install with latest nightly and problems remain:
  1. Wifi doesn’t request password so you can’t connect
  2. Bluetooth shows available devices, but doesn’t pair (even Xiaomi remote seen as controller)
  3. with my Lg OLED hdr movies are shown correctly, but with my projector no screen visible only audio playing.
Does anyone read forum? There was issue with CE addon and this issue got fixed with today nighly 20251226.
I’ve just installed nightly 20251226 and I can confirm that now wifi works!Even association with Xiaomi remote control is finally gone well (center button requires an additional configuration posted in xiaomi 3rd gen post).For me remains hdr problem (no video) with my projector.
My device:Xiaomi mi box 3rd gen
