Only opening subtitles offset setting fix problem when offset is open on top of video
Exactly; thatâs why I have mapped a button on my remote to bring up âSubtitle offsetâ overlay directly
I have just downgraded to ng version, all of a sudden kodi started to go to safe mode, since it cant no longer start normal kodi instance.
Try a different dtb or a new install not a downgrade.
Same dtb works just fine on ng version. Good that i have sd card image backup, so that i can resume whare i left with ng when i reformated card to try no version
Is there a Dovi.ko for ugoos XQ4 running new order?
I might have installed the 22.0 nightly by mistake and the addon repos are not even up yet. Any ETA on this or should i just go back?
No, thereâs no dovi.ko for this kernel yet.
Now makes sense
Tested New Order on Kinhank G1
There was on screen prompt
No dovi .ko in kernel
Please update Android boot to ker 5.15.
I believe this will not be device specific, if its affected by Mali library, all devidec with Mali GPU will be affected using NO.
CE NO 22 Working OK on 905x4 (TOX3) but wont play VC-1 at the moment.
Donât understand, why delete builds no-21? I updated my box to 22 and now not working some addons for example Plexkodiconnect. I wanted downgrade to 21, but rhem all deleted from server. At least they left one last oneâŠ
I think that is fairly common with rapidly changing early builds .
I usually keep a âcacheâ of releases internally,but I havenât jumped on the â-noâ wagon yet so I canât dig it up for you âŠ
NO will only be CE-22 from now on and nightly is already available with all the addons.
Keep in mind that Kodi âPâ is so very pre alpha, it doesnât even have a proper name yet.
You can be informed about the progress here:
Thank you.
Exciting new developments, sounds like itâs ready to play with now.
Btw, the announcement page still mentions Omega as a base.
Great work and thanks for everything!
In Kodi 22, the time cannot be set to GMT +3 in regional settings.EPG error occurs because of this.Is this a Kodi bug or CE bug?
Can you also try windows or last Linux nightly?
So if itâs our platform only?
Clock works properly on Kodi 22 windows night version.
Also works well with the Android version. I now did test.
CoreELEC-Amlogic-no.aarch64-22.0-P_nightly_20240511
Timezone is not set anymore in Kodi after this PR. I think now this needs to be set from CE settings or just done automatically. Something to think in next days.
Put this in autostart.sh for temporary workaround:
echo "TIMEZONE=Europe/Istanbul" >/storage/.cache/timezone ; systemctl restart tz-data.service
