Thanks, it works now.
\edit void all below; issue was the media
Latest nightly (CoreELEC-Amlogic-no.aarch64-22.0-P_nightly_20240512-Odroid_C4.img) does no respond to any pheripheral input after first boot
With next nightly 20240514 there should be the timezone settings be available again by CE settings: coreelec:ce_addon_system [CoreELEC Wiki]
I had about the same problem, it turned out to be the power adapter going bad, Replaced it
and it is all back to normal.
Turns out it was the sdcard i was using. Replaced it and issue vanished
before I give it a go again, can someone confirm if the stutter is still there, when subtitles are enabled? or whether this issue is now fixed
Thanks!
i have currently two problems with the latest nightly on an Odroid N2+:
A log file /storage/inject_bl301.log is created with following content
/usr/sbin/inject_bl301: /usr/lib/libcurl.so.4: version `CURL_OPENSSL_4' not found (required by /usr/sbin/inject_bl301)
It looks like searching for an update failed, because the journal looks okay, or isnāt?
Apr 24 13:15:03 CoreELEC kernel: bl30_manager: driver probe
Apr 24 13:15:05 CoreELEC systemd[1]: Starting update-bl301.service...
Apr 24 13:15:05 CoreELEC update-bl301[835]: inject_bl301: /usr/lib/libcurl.so.4: version `CURL_OPENSSL_4' not found (required by inject_bl301)
Apr 24 13:15:05 CoreELEC update-bl301[897]: inject_bl301: /usr/lib/libcurl.so.4: version `CURL_OPENSSL_4' not found (required by inject_bl301)
Apr 24 13:15:05 CoreELEC update-bl301[816]: CoreELEC BL301 installed but no update needed
Apr 24 13:15:05 CoreELEC systemd[1]: update-bl301.service: Deactivated successfully.
Apr 24 13:15:05 CoreELEC systemd[1]: Finished update-bl301.service.
May 14 15:50:44 CoreELEC kernel: bl30_manager: Do setup BL30 blob
May 14 15:50:44 CoreELEC kernel: bl30_manager: IR remote wake-up code: 0x23dc4db2
May 14 15:50:44 CoreELEC kernel: bl30_manager: IR remote wake-up code protocol: 0x0
May 14 15:50:44 CoreELEC kernel: bl30_manager: IR remote wake-up code mask: 0xffffffff
May 14 15:50:44 CoreELEC kernel: bl30_manager: enable 5V system power on suspend/power off state: 0
May 14 15:50:44 CoreELEC kernel: bl30_manager: gpiopower: 65535 ()
I try to mount a NFS share, but if i create a systemd unit, itās not always possible to boot the N2+ because of a boot loop.
Mounting the share in an ssh session leads to this output:
/usr/bin/mount -t nfs 192.168.178.9:/share/video /storage/video
May 14 16:05:09 coreelec2 kernel: BUG: Bad page state in process kworker/2:2 pfn:22299
May 14 16:05:09 coreelec2 kernel: page:0000000043cdbb4c refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x22299
May 14 16:05:09 coreelec2 kernel: flags: 0x0(zone=0)
May 14 16:05:09 coreelec2 kernel: raw: 0000000000000000 0000000000000000 fffffffe0088a648 0000000000000000
May 14 16:05:09 coreelec2 kernel: raw: 0000000000000000 0000000000000000 00000001ffffffff 0000000000000000
May 14 16:05:09 coreelec2 kernel: page dumped because: nonzero _refcount
May 14 16:05:09 coreelec2 kernel: Modules linked in: 8021q ir_rc6_decoder ir_nec_decoder meson_ir rc_core amvdec_vp9(O) amvdec_av1(O) amvdec_vc1(O) amvdec_mmpeg4(O) amvdec_mmpeg12(O) amvdec_mmjpeg(O) amvdec_h265(O) amvdec_mh264(O) amvdec_h264mvc(O) amvdec_mavs(O) bluetooth amvdec_avs3(O) amvdec_avs2(O) stream_input(O) pts_server(O) decoder_common(O) firmware(O) media_clock(O) nfsd nfs_acl mali_kbase(O) wifi_dummy(O) nfnetlink autofs4
May 14 16:05:09 coreelec2 kernel: CPU: 2 PID: 187 Comm: kworker/2:2 Tainted: G O 5.15.119 #1 6301b719b5030aa6be1c982aa71055b35a9e427a
May 14 16:05:09 coreelec2 kernel: Hardware name: Hardkernel ODROID-N2 (DT)
May 14 16:05:09 coreelec2 kernel: Workqueue: events kfree_rcu_work
May 14 16:05:09 coreelec2 kernel: Call trace:
May 14 16:05:09 coreelec2 kernel: dump_backtrace+0x0/0x1b4
May 14 16:05:09 coreelec2 kernel: show_stack+0x20/0x2c
May 14 16:05:09 coreelec2 kernel: dump_stack_lvl+0x64/0x80
May 14 16:05:09 coreelec2 kernel: dump_stack+0x18/0x34
May 14 16:05:09 coreelec2 kernel: bad_page+0xf0/0x120
May 14 16:05:09 coreelec2 kernel: check_free_page_bad+0x84/0x90
May 14 16:05:09 coreelec2 kernel: __free_pages_ok+0x414/0x490
May 14 16:05:09 coreelec2 kernel: __free_pages+0xe8/0x10c
May 14 16:05:09 coreelec2 kernel: kmem_cache_free_bulk+0x5f8/0x66c
May 14 16:05:09 coreelec2 kernel: kfree_rcu_work+0x1e8/0x230
May 14 16:05:09 coreelec2 kernel: process_one_work+0x1c0/0x510
May 14 16:05:09 coreelec2 kernel: worker_thread+0x74/0x480
May 14 16:05:09 coreelec2 kernel: kthread+0x15c/0x170
May 14 16:05:09 coreelec2 kernel: ret_from_fork+0x10/0x20
May 14 16:05:09 coreelec2 kernel: Disabling lock debugging due to kernel taint
Either immediately or after a short time, the system is restarted without any further actions being carried out.
There was never a need to run inject_bl301 on SBC with unique image.
Yes . After subs enabled vids stutter a little bit. Tried last night.
Lost any pheriphereal (remote,keyboard, anything usb) again overnight . Lsusb shows empty where it did show on startup.
Not asking for a fix, just an observation. A consistent one. Testbox is a C4. Tried different power cables, sdcards and different (C4) boxes.
With VIM4 (latest nightly) there is the same error, about missing CURL OPENSSL 4 and trying to launch inject_bl301 when booting/updating CoreELEC.
I can confirm there is a problem with the C4 and no build.
This is a very intermittent problem it seems sometimes the C4 will boot
and usb works you reboot or turn it off and then back on and it stops.
Try adding this line coreelec=āloglevel=9 nopkmuteā
to the config.ini, this seems to help on reboots and on and offs.
I donāt know why it helps, Maybe a uboot issue?
I donāt have any of the previous builds from before 22.0-P nightly for the C4 to test them but everyone of the 22.0-P seems to have this same iss
No-Dev 05142024 Odroid C4
When the usb stops working there is a failed in the logs
amlogic-new-usb3-v2: probe of ffe09080.usb3phy failed with error -1
[ 1.428777] usbcore: registered new interface driver usbfs
[ 1.428817] usbcore: registered new interface driver hub
[ 1.428847] usbcore: registered new device driver usb
[ 1.573899] usbcore: registered new interface driver uas
[ 1.573954] usbcore: registered new interface driver usb-storage
[ 1.574050] usbcore: registered new interface driver usbserial_generic
[ 1.575105] usbcore: registered new interface driver xpad
[ 1.575995] usbcore: registered new interface driver uvcvideo
[ 1.579966] usbcore: registered new interface driver usbhid
[ 1.579979] usbhid: USB HID core driver
[ 1.581458] usbcore: registered new interface driver snd-usb-audio
[ 2.259358] ### usb_main_init() start
[ 2.259594] call amlogic_new_c2_usb2_v2_driver_init() success
[ 2.259772] call amlogic_new_c2_usb3_v2_driver_init() success
[ 2.260315] call amlogic_new_usb2_v2_driver_init() success
[ 2.260491] call amlogic_new_usb3_v2_driver_init() success
[ 2.260627] call amlogic_usb2_m31_drv_init() success
[ 2.260761] call amlogic_usb3_m31_drv_init() success
[ 2.261176] call amlogic_crg_drd_usb2_drv_init() success
[ 2.261310] call amlogic_crg_drd_usb3_drv_init() success
[ 2.261730] ### usb_main_init() end
[ 2.840156] amlogic-new-usb2-v2 ffe09000.usb2phy: USB2 phy probe:phy_mem:0xffe09000, iomap phy_base:0xffffffc00c36d000
[ 2.840644] amlogic-new-usb3-v2: probe of ffe09080.usb3phy failed with error -1
[ 2.882856] dwc_otg: usb0: type: 2 speed: 0,
[ 5.423985] [usb_power_control] Set WiFi power down
[ 5.759983] [usb_power_control] Set WiFi power on !
[ 5.968068] [usb_power_control] Set WiFi power on !
The same error appears with my Homatics Box R 4K Plus Box. You can see the error message during the update process on screen
My box is running this nightly but is not auto updating or notifying me of updates being available. Is this my install or is auto update not set yet.
I know that timezone settings have been added recently to Coreelec configuration but I canāt get it to work. Timezone country is blank when selected. This action seems to trigger setting Timezone to Europe/Andorra. Subsequently no changes can be made. Soft reset doesnāt change anything other than blanking both fields out again
Good if you live in Andorraš
20240519 nightly on s905x4.
You need to select something from country and then something from timezone.
I started with a fresh install on my Khadas Vim1S , the Timezone can not be changed thought the gui, Even after you try to select what you want it defaults to Europe/Andorra reboot and still you can changed nothing though the gui you can select some other country but it will not stick I selected America it showed it for a moment the reverted back Europe/Andorra.
ssh into the box and change it via the command line works and sticks afterwards but you still canāt change it via the gui
echo āTIMEZONE=America/Chicagoā >/storage/.cache/timezone ; systemctl restart tz-data.service Works
The gui seems broken at this time.
I will check again at home. But few days back it worked as it was intended.
On or about the 13th it worked as intended there must have been another update since then that has broken it.
