Thank you, but was failed again with your dtb. Log is not finished compare to other case (same output from last nightly build 20240802 and build 20240624).
fs-resize.log (171 Bytes)
Try CE-22 NO with this dtb.
hallelujah, it works with old sd card samsung pro and with last dtb from vpeter /Minix u22xj was successful started and even it have all audio output in setting of CE22no/. Thx vpeter, also thx rho-bot.
fs-resize.log (509 Bytes).
audinfo.txt (3.6 KB)
Dmesg: https://paste.coreelec.org/CarpetPlans
ce-debug_info.txt (43.0 KB)
Small note from past: my Minix u22xj havent support hs400. It is not safe, bacause not start after set to hs400 (for intalled CE21ng on emmc).
Also thx for push to ordering new sd card. Now are sd cards with better performance for running application as optimalization A2 from linux 5.15. - so optimal for CE22no Linux Supports A2 SDcards now! - ODROID
Tried also last and this build 20240624 on Ugoos am6plus on CE22no, but i have also here the an issue of only bluetooth audiu output. Ugooos am6+ maybe have longer time a issue with audio output. https://paste.coreelec.org/PlotsAsylum and https://paste.coreelec.org/StavrosSoftly and https://paste.coreelec.org/UnhookVillage
audinfo.txt (2.3 KB)
ce-debug_info.txt (42.7 KB)
So Minix issue is solved now for you, right?
For Ugoos, please provide dmesg of the latest build. Thanks!
Yes, for this time is a good state for future users of minix device on CE22no. My Ugoos am6+ have this dmesg logs: https://paste.coreelec.org/StaturePension
Try this image.
Thank you. Now are possible more outputs and sound is going on Ugoos am6+ (tested with headphones). Ugoos AM6+ is done. Dmesg: https://paste.coreelec.org/HersheyAwakened
Big sorry. Please again check minix u22xj, for sure i checked dmesg after succesful run of CE22no. Now i connected headphones and really not going sound although are presented all audio outputs in settings. There is error: es8316 3-0010: ASoC: error at soc_component_read_no_lock on.
https://paste.coreelec.org/ServersRegular
https://paste.coreelec.org/HookersConey
https://paste.coreelec.org/ServersRegularNoddingLibel
Iām sorry but this is impossible to follow. Different issues, different devices, ā¦
Plase provide DTB from android and dmesg from CE-21 (NG?) where is working and CE-22 NO from start (not just the end where only errors are seen).
Minix u22xj have this dtb from android 9
dtb.img.gz (205.0 KB).
Dmesg from CE21ng: https://paste.coreelec.org/GunnerBelize
Now is installed last dtb to CE22no from you with succesful start: Amlogic-no Discussion - #756 by vpeter
Please add full dmesg for CE22 NO, too
From ce22no from last build i add here everything what was possible: Amlogic-no Discussion - #764 by atirage21 Exist other form of command dmesg | paste
Another try for minix:
use Testimage from here, together with new minix test dtb:
CE22-NO_g12b_s922x_minix_u22xj_deleted-avout_mute-gpios.dtb (71,9 KB)
Note: Generally it would be better clean install and not update tar. Filesystem was corrupted on minix (tar for ugoos rewroted dtb), but after second try i rewrite dtb. Sound is not going.
https://paste.coreelec.org/RiledNewman
https://paste.coreelec.org/SkinsExploit
https://paste.coreelec.org/CarnivalInfierno
You minix is just u22xj without max? Because on CE-21 we have 2 DTB but on CE-22 is only one. Will prepare one new DTB.
without max
At present, Corelec22 version no, the SoC s905x4 kernel is not the latest. Is there a dovi.ko suitable for NO22 version?
How many times this was answered ā¦
