Try with this DTB and post dmesg.
Also all changes (except this minix u22xj sound issue) will be included in tomorrow nightly.
Now really sound is going on Minix u22xj (without max). Dmesg: https://paste.coreelec.org/NattyMookie
Minix u22xj is done. Thank you Team Coreelec.
Hi, i tested last night build 20240811 on Ugoos am6plus and sound is good from hdmi and spdif also. Good job. Also i identified a maybe general small bug for everybody on ce22no: if you install usb joystick (e.g. displacement for sony playstation dualshock, kodi xbox) it is not going to config of device which was ok on ce21ng. Please try.
Now was started again selling of ugoos am6Bplus. It would be maybe usefull ask amlogic for supporting of android 11 on s922xj, which is based on kernel 5.15.
Answer from ugoos:
It depends on Amlogic, we don’t hear from them there is any update till now, so it is impossible for us to update if without their SDK updated, kindly please note, thanks.
I got similar answer from Ugoos, maybe if we contact Amlogic, though they probably ignore us? support@amlogic.com
No wakeup Method is working on the odroid-n2+. I tried WOL and GPIO Wakeup, but both do not work.
It seems that in the DT the new mbox configs are missing as I see in the log the message: “mbox chan is NULL” and other mbox failure message.
I wrote an email to amlogic with argumentation about cybersecurity. Device from 2020+ have adroid from 2018 in year 2024. I asked new SDK for at least android 11 for our device with kernel 5.15 for Ugoos. I am only customer. Never was updated android. Today also is standart 64 bit environment, instead of 32 bit. Note: Indirect some progress would help also for coreelec project and etc.
This is not how a TV box vendor does work.
It’s a sold ready to use SDK. Hardware + Software.
There is no update planed as it’s just to much work to maintain.
When you want to have newest code base use one of the SBC device like from Khadas or buy the newest device available. Like the S905X5 should be the first device with 5.15 kernel available.
Older device will not be updated and stay on their 4.x or 5.x version.
5.15 do support some older SBC but 99.9% will not update to this version as it’s a one time seller.
See like Minix U22X-J, it’s done and not produced anymore - it’s payed off.
S922xj is again in shop: Ugoos AM6B Plus 2021 - Mini PC TV Box Store
I tried last nightly build 20240812 on Ugoos am6plus and always not going to configure joystick (maybe is general issue on all devices with all usb joystick).
xpad 1-2:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
I dont know, maybe it would help my dmesg log: https://paste.coreelec.org/DozedBodega
In case it is helpful information, I have found that after enabling passthrough audio and getting no sound, no sound output will occur at all even after the setting is reverted back to disabled. Need to reboot the device to get non-passthrough audio working again.
Issue still present in 22.0-Piers_nightly_20240812
on s905x3.
Same here on 2 boxes . x3 and x4.
I just leave passthough off.
Sound still seems to work thru all channels using kodi decoders ok.
20240817… dtb issue
Boot loop, X96 (sm1_s905x3_4g.dtb)
Replaced dtb.img with earlier one from 20240624. Works as before.
same bootloop with build 20240817 on Ugoos am6+
Tommorow will be again good build.
Hi @vpeter, I get a PVR plugin incompatibility warning and there is no new version in the repository.
Also the pvr section does not appear in the plugins.AM8 does not recognize usb disks. AM8 does not recognize usb disks with new order
Bootloop was solved with build 20240818, but is always bug with configuration of buttons for joysticks (tested on Ugoos am6+: https://paste.coreelec.org/WeighsPacking
kodi.log (144.7 KB)
ce-debug_info.txt (41.9 KB)
audinfo.txt (3.7 KB)
). Also dtb for minix u22xj without max is missing, although this dtb was finalized here: Amlogic-no Discussion - #775 by vpeter.
Addons needs time to rebuild. Wait or go back to previous release.
Since when? When it was last time working. Update: Works for me.
It was just a test and not final solution.
Thanks @vpeter, I will try again with a clean install.
After a clean install, the usb stick is running on AM8 with 20240818 new order nightly software.
You are probably aware of these problems, but let me write them down anyway.
AM8 Kernel 5.15.119
1- 2.65 codec video and live TV broadcasts do not play and black screen.
2- 2.64 codec plays video and live TV broadcasts but colors are distorted.
3- Plays SD video and live TV broadcasts no problem.
Note:I forgot to write about my TV. Samsung 40J6370
