2nd Test clean install on S5 X96X10 PRO S928X-J 8/64 version
Ethernet
Bluetooth
VFD
Remote config
No wifi
Now that i have the correct dovi installed (Human error 1st test)
Dolby Vision Working!!!
TV LED and Player LED
Thx Team CoreELEC!!!
Ethernet
Bluetooth
VFD
Remote config
No wifi
First quick test with DoVi on my AM8 Pro and LG G3 TV. The DoVi FEL test clip works fine. My own test encode (bhcop.mkv - Google Drive) didnāt work with TV led enabled, the TV switches to DoVi mode but thereās only a black screen. Switching to Player led, it works.
EDIT: the player debug output was not correct for TV led DoVi. It showed YUV444 IIRC, not RGB 8-bit at least.
Hereās the debug log from the black screen situation.
https://paste.coreelec.org/PitchedPresent
The one linked a bit earlier in this thread. I think itās the only one known so far.
Could you please write how to solve this? I have the same error on AM8 Pro.
On any nightly after 12/09 inputstream ffmpeg direct is still broken. Canāt repro on any other platform. Is there something that still needs to be updated in the CE repo ā¦?
When DV is black only and/or update from older build ensure dv compatibility mode is enabled in player settings.
On older am6plus not started system CE with new installation and also with proces upgrading from previous nigthly release CE22NO.
Maybe dtb file is wrong.
init-previous.log (1.9 KB)
fs-resize.log (509 Bytes)
Is that available only on certain devices? I donāt see it at all. Then again, the FEL test clip is P7 and plays back normally (discarding FEL) so I suppose it already falls back to 8.x.
I had the similar issue with the bhcop.mkv clip already in CE21-ne earlier but it was fixed by some commit.
Working here without any issue.
But TV-Led mode looks broken.
Itās only SDR. So use Player-led mode for now.
Where is this settings
In System/Settings/Player/Playback
I see
Adjust display HDR mod
is enabled by default.
Is this what you mean by compatible mode?
In homatics atv14, the player led mode broken, just the tv=led working.
Player led fallback to sdr.
edit. after switched in android side the always Dolby Vision, in CE no both mode working.
edit2. Back to android enable player led mode only there, boot to CE, both dv mode working again⦠![]()
On a working clip, itās definitely DoVi on the TV (checked the VRR info and itās super bright) but the output display in the player shows SDR BT.709.
The clips that just show up as black, also DoVi in the VRR info the same way. They just donāt play at all.
Player-led shows normal DV-LL BT.2020 for both.
@Portisch will 3d in next update? And is fel is converted to 8.1 like @quietvoid code?
Thanks.
Am6plus run with CE22NO 20241220 based on kernel 5.15.119., but old issues are there Amlogic-no Discussion - #926 by atirage21
So bug with not started CE22NO from mega.nz is only with newer kernel due to driver of sd card reader or wrong dtb for am6plus without āBā?
20241222 shows now correct info under player process info for TV-Led.
Try latest nightly
bhcop plays back in 8 bit RGB Dv .
Using TV LED Setting
On the X96X10 PRO S928X-J
Seems its fixed!!
Iāve tried out the latest nightly on my X96X10 PRO S928X-J.
Dolby Vision works for me.
I found only one issue: Kodi keeps crashing when I watch an mpeg4 file and I try to select a video scaling method Spline36 (optimized) or Lanczos2 (optimized).
Hmmmmmm
Where are these settings in CoreELEC?
In Player Processing Render Method
By default
Accelerate MPEG4 is set as HD and up
Change to Never
Maybe will help
Yeah, I set it to 'never. ā
Thatās why I have that option available.
Itās when you play the video, in OSD, Video Settings.
And sorry to bother you guys again, but two more issues. They have both been mentioned before.
I attached the debug log where I experienced this loss of HDMI signal when playing a Dolby Vision file.
kodi.log (3.7 MB)
But the funny thing is, when I enable debug logging, the frame skipping issue disappears.
