Should be fixed for g12b with nightly 20241230.
I tried, but error remains for ugoos am6+.
What error?
My Beelink gt King 922x dont boot with the new nightly
Error:
*** Error in mount_flash: mount_common: Could not mount LABEL=COREELEC ***
Boot from USB or uSD?
From uSD
I made a update to the new nightly
I also try a new istallation on a uSD card , but its the same
Please make a dmesg | paste and cat /proc/cpuinfo | paste with last working version.
Sorry , i have to go away from my home
I can test it later
Booting from sd cart is not succes. Identocal error as had N2, and now also king 922x. Last time was succes booting biuld from 20.12.202024 with older 5.15 kernel. I dont tried booting from usb.
I recently upgraded to the latest nightly build (CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20241230). Based on my understanding, there should be a newer version of the Inputstream.adaptive addon (22.1.11) available.
This is mentioned in the changelog from 2024-12-24: archive.coreelec.org. Additionally, the update is noted here:
inputstream.adaptive: update 22.1.10-Piers to 22.1.11-Piers · CoreELEC/CoreELEC@af9bf27.
However, the current version of Inputstream.adaptive in my KODI installation is still 22.1.10.2. Am I misunderstanding something, or how can I update this addon to its latest version?
I posted from this last working build many logs due to other bugs in am6plus.
Hi Portisch, I don’t know if you mean the performance issue, but if so, nightly 20241230 does not fix the performance drop. I get exactly the same measurement results as with previous Nightly.
Logs from last working version of CE22NO (yes it was Linux version 5.15.119):
read forum: Amlogic-no Discussion - #998 by Portisch
Make me a how to I can local check the performance.
Kernel have same CPU settings like CE-21 NE with 5.4.210.
Compare to latest CE-22 NE nightly so to see if it’s Kodi or kernel what makes the difference.
g12b users please try with your DTB again:
i tried, but no boot with last build CE22NO on am6plus.
Here i uploated a build of CE22NO from 20 december 2024 for others users of SOC s922x.
This is way to less info. Did you even used the DTB I uploaded? When yes you need to make UART log or tell does it boot to CE splash? Console? No boot splash?
Always i have error in mount flash with newer kernel. I go try your dtb on old built from 20. december.
