Amlogic-no Discussion
A post was merged into an existing topic: Nightly builds (NEW)
All 4 successfully boot my N2 on eMMC:
V1-Log V2-Log V3-Log V4-Log
Hope I got all of them right…
Ok, now here a complete nightly test:
It include now all rev.a like NG did have.
N2, GT King, GS King X, AM6(b)
There is the .tar and img.gz for N2 and Generic available.
Getting no picture on 1280x720p on latest nightly
[ 140.783242] 0: vh264_work_implement, dec_picture->data_flag 16 hw->data_flag 16
[ 140.955231] 0: timeout_process decoder timeout, DPB_STATUS_REG 0xf3
[ 140.955269] 0: vh264_work_implement, decode timeout store in dpb
[ 140.955274] 0: vh264_work_implement, dec_picture->data_flag 16 hw->data_flag 16
[ 141.123247] 0: timeout_process decoder timeout, DPB_STATUS_REG 0xf3
[ 141.123278] 0: vh264_work_implement, decode timeout store in dpb
Kodi log
error : CAMLCodec::GetPicture: time elapsed since last frame: 5712ms (11:Resource temporarily unavailable)
Thanks! Will push it to my rev a first and report back.
1080i/720p isn’t working yet
ā€œ20250109.tarā€ does not update; ā€œ20250109-Odroid_N2.img does not installā€ on eMMC → boot loop logo-black screen: UART Log
Ok, I know this issue. Will fix it.
My attempt ended in a constant bootloop as well.
Updated builds:
I am on the move currently, someone will beat me testing it :slight_smile:
Update with 20250110.tar from 109 to 110 works flawlessly, no glitch or any other problem, on my eMMC installation on my N2 rev-a.
Thank you. Works perfect. :+1:
I’ve updated using the .tar but I’m getting lock ups and can’t run add-ons. I think it’s my setup because the 2GB N2 has been a bit flaky before (you may remember this Portisch). Without UART, I’m happy to toy with this one as it’s a spare. My 2 main N2+'s are running NO very well.
So glad it’s up and running for you @Sholander.
I will check u-boot as there is a diff in getting size of ram memory. Maybe this is the reason.
Yea Thnx :slight_smile:
I also noticed that with this -no version N2 boots much faster than with -ng version once you disable ā€œWait for Network - 10sekā€ which is default setting now, for unknown reason to me…
Don’t know if this helps but the same SD card boots and runs perfectly on one of my N2+'s
This build is ok on AM6+.
https://paste.coreelec.org/TrulyGardner
You have s922x rev.b
All fixes to boot s922x rev.a are included in tomorrow 20250111 nightly.
Update to 0111 went flawless on my 4gb N2 rev a. Nice.
