Thanks for clarification. I have my testsysteem ready so if something needs to be tested/confirmed I can
For now i switch back to clean latest ng 21 nightly build but i still have problems after rescan of my nas that not all of my posters get pick up. I guess ill need to delete all of my .nfoâs and jpeg folders and recreate it from ground up
On my N2 when I was testing first -no versions I had to use any picture overlay to get rid of subtitle stutter. The one I used is âSubtitle offsetâ +/- bar at the top of the screen. With it displayed while playing the video, subtitles did not cause any picture stutter.
You can test this on newest -no versions if it also works for you.
Yes, TK new how much work was/is needed to be done to fix this bug, so they simply never admitted it exists.
I remember some 5-6 years ago that @wrxtasy at Kodi forum found out that using Kodi âDirty Regionsâ in advancedsettings.xml fixed subtitle stutter for S912 SoC.
Also remember that @boot2k3, at that time, made a âdevel.tarâ version that fixed sub stutter without need for advancedsettings.xml line.
Unfortunately this âdirty region fixâ does not work on S922xâŚ
Subtitles & Overlay is horror currently in Kodi code.
Subtitles are add by LibAss with PTS start/stop.
Then one unique overlay with no PTS is added so the render do know itâs something to do. Then the stutter happen because it render a empty frame.
This is why the stutter is gone when actually there is some work to doâŚ
But as already written this is a very old implementation. so it must be reworked from basic.
Shouldnât TK chip in on this or will they just sit content on their fat ass and wait for you to do all heavy work?
TK did rewrite the subtitle renderer in 2021 for Kodi 20 according to this post:
https://forum.kodi.tv/showthread.php?tid=364572
It may still not work correctly, but itâs not from 2011
I hope subtitles are fixed with new nightly 20250115, for CE-22 and CE-21.
CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20250113
S905W2 4GB
This s905w2 has not booted since the New Kernel
below is the uart log from putty
https://paste.kodi.tv/tuwetiyune.kodi
Did the âoldâ CE-NO boot?
If yes please update with Index of /Amlogic-no/CE-22/20241220/ and make a dmesg | paste
Works fine with the older 119 kernels always did
below is the dmesg log from running no-12202024
https://paste.kodi.tv/pixijitadu
@tht please try with newest nightly and this DTB again:
s4_s905w2_4g.dtb (69.4 KB)
Visual static then All I get is a boot loop
Please try again with this and make a log again:
Same thing visual static then boot loop
below is a uart log from putty
https://paste.kodi.tv/kodefopufi.kodi
Please try with this image again:
Still boot loop
uart log below
https://paste.kodi.tv/ehocunavup.kodi
No idea now. VIM1S what is also S4 does also not boot, but with different errorâŚ
CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20250114
g12a_s905y2_4g
Boot Loop
uart log below
https://paste.kodi.tv/ikadalahun.kodi
Thanks for the effort.
