Which only means that your date on devive is wrong? But image is only few days old.
Possibly, but the rest of the log shows the correct date.
In the log you should also see which image exactly you are using. This info is important not date.
Thanks! AV1 works only VC1 does not work. Then that’s all, this can be endured.
0322 nightly all DV files now play back purple and green.
https://paste.coreelec.org/ErnstBrackett
Hi, community! I’ve small question. Why display calibration reset by default after every booting system?
Reboot, play only one file shortly, make new log.
https://paste.coreelec.org/SladeBench
I am on the latest slimboxtv 35.1 for tox3 (ucode 3.49) which uses the stock firmware released for tox3, but there is a firmware that is based on ugoos x4 released at the end of the year based on ugoos firmware 1.2.4. If anyone has ugoos x4 or slimBOXtv 114.22 tell us what ucode it is.
Try with 334.52 MB file on MEGA
That fixes the colors, DV now plays perfectly, thanks :+1:
Setting + player + Videos + amcodec = off AV1 and VC1 videos are played (software)
Gt King ii
Android ucode version: ā€˜3.35’
I updated my X4 yesterday to 1.2.4 and ucode is 3.49.
amcodec on → AV1 no
https://paste.coreelec.org/VaughnSmoothie
amcodec of → AV1 ok
https://paste.coreelec.org/HoserWhatcha
Dune HD Homatics Box R 4K Plus with the newest SEI804HM_firmware.14.8.2463 gives you ucode 4.130
Hey there.
do you know if there is any firmware on gt king II with at least 4.1 ucode? I’m also on the same as you.
So far I have not found such firmware.
Okay, looks like the same issue, the X96Max+ Ultra is running the latest release (X96Max_Plus_Ultra_20221026-0948.img) and the Android ucode is 3.33. So looks like the box is trash, weird thing is, it plays AV1 fine under Android Youtube app, so if CE Kernel requires newer ucode for AV1 playback, then thats that. Looks like ucode 4.x is only available on DolbyVision certified devices such as Dune or Homatics. Every other device seems to be stuck on 3.x and have to live with it
CoreELEC (official): 22.0-Piers_nightly_20250322 (Amlogic-no.aarch64)
      Machine model: Amlogic
     CoreELEC dt-id: sc2_s905x4_4g
      Linux version: 5.15.153 (docker@ea1c9fcf41c2) #1 Sat Mar 22 01:33:29 IST 2025
      Kodi compiled: 2025-03-22 13:38:21 +1300
X96Max:~ # jc -u opentee_linuxdriver
Mar 07 03:38:33 X96Max systemd[1]: Starting opentee_linuxdriver.service...
Mar 07 03:38:34 X96Max tee-loader[533]: run tee from android start
Mar 07 03:38:35 X96Max tee-loader[533]: fw active slot: '_a'
Mar 07 03:38:35 X96Max tee-loader[533]: active slot: '_a'
Mar 07 03:38:36 X96Max tee-loader[533]: Android ucode version: '3.33'
Mar 07 03:38:41 X96Max tee-loader[908]: fw_path = /lib/firmware/video/video_ucode.bin
Mar 07 03:38:41 X96Max tee-loader[908]: tee preload video fw ok
Mar 07 03:38:41 X96Max tee-loader[533]: run tee from android end
Mar 07 03:38:41 X96Max dovi-loader[910]: run dovi 'start'
Mar 07 03:38:41 X96Max dovi-loader[924]: umount: /android/vendor: target is busy.
Mar 07 03:38:41 X96Max systemd[1]: Finished opentee_linuxdriver.service.
Just our two cents.
It’s not a decision by CoreELEC to get such issues.
It’s Amlogic introduced a new security update in bootloader and firmware. New and old firmware is just not compatible anymore. This is since SoC SC2, T7 and S5. SoC before don’t use TEE at all so aren’t affected.
There is no issue for Android as they get delivered compatible, bootloader and firmware.
So if you got a device not compatible with the new security system it’s best to stay on old CoreELEC version what is still compatible with it.
It’s mostly CE-NE.
If you don’t care about AV1 or VC-1 you just can skip this fact. Other decoders are implemented long enough to still work fully with old firmware as well.
Never blamed the CE Team, Amlogic is to blame as they only care about the Android side. Case in point, they dont even release a linux driver for their own Wifi+BT chip AML-W1. Thanks to CE team atleast WiFI works on the X96Max+ Ultra.
CE-NE would have been a viable option, but you yourself have mentioned that CE22 would be NO only and S905X4 devices must use NO only
So stuck between a rock and a hardplace. Kodi 20 was pure garbage and should have never been released, Kodi 21 is bearable at best and Kodi 22 is chef’s kiss. It would be amazing if CE22-NE was ever released after Kodi22.0 is released, one can only hope :slight_smile:
