Thanks that dovi.ko fixed the issue with PVR
Thank you very much for the answer. So I understand.
Unfortunately, with this new CE, it will lose its good property to work on cheap amlogic boxes.
Nexus and Omega remain, but unfortunately there are some strong mistakes that make the X4 simple boxes not to be used.
This will make the x3 a better choice.
That omega 32 bit is very good.
Unless there is any new Android for these boxers, but manufacturers donāt do it.
Yeah, else:
Remote.conf does not work again on the box X3 and X4. The left direction is not good.
It only impacts AV1 and VC1 playback. Do we really have to have these or are we happy with rock solid H264/5 playback? Personally I donāt get the feature chasing thatās going on at the moment.
Since it is crashing Kodi on start I need to remove it in Safe Mode from .FAILED since I donāt get an opportunity to disable any addon. Even installing from the repo directly in Safe Mode has the same crash with the new version.
Could you send me your compiled pvr.nextpvr.so.22.4.1 to see if it crashes on start up?
You wrote you already build it yourself and it works?
Right but since the the repo rebuild today didnāt work I want to see if there is something about my build system that is different.
Addons were not rebuild today. Sadly something were wrong on build server. Next time more luck ![]()
Then just remap using kodi keymap editor and your chosen remote.
Iāve had the odd key not working and this is a suitable fix.
Baz
CE-NO has been my daily driver for the last 4 months, been fantastic. Running on X96Max+ Ultra. No Bluetooth and AV1 or VC1 playback though, but plays everything else with perfect hardware decoding
Bugger. Cannot make the dtbās work on my H96max x2 ![]()
Did you try with g12a_s905x2_4g.dtb ?
Many times, I just get intermittent spinning wheel. Works good on NG though ā¦
Are you able to reproduce and generate a debug log?
I have seen this once or twice but no longer able to reproduce with latest nightly
I also had the problem with remote.conf in NO (left or right key doesnāt work).
I added the entry ā0x64 164 #test noā
That works for me.
Iāve decided to switch my two devices (Homatics R plus 4k and Beelink GT King) to the latest NO nightly.
Homatics is connected to a Philips 65OLED and GT King is connected to an older Sony TV
- Using VDR Vnsi client connect to a VDR headless server ā OK
- Playing all kind of media ā OK
- DV not tested, waiting for getting ATV 14 on my Homatics
- Shared media libary on a Synology NAS MariaDB ā Ok
What does not work:
In the past I had a share mounted by using NFS mount script and added the media from there.
With the latest nightly I cannot mount NFS shares anymore.
When I enable the mount service the Homatics start rebooting in circles.
I was waiting some time to see if Coreelec starts in safe mode but it doesnāt, so I cannot provide any crashlog.
As a workaround I was adding my media by using the ābrowse NFSā and loaded my media from there.
You asking re my H96 max x2?
Cant generate a log if you cant load program.
emveepee, all addons were rebuild today. Please check (uninstall and install again).
Hi, iām having an issue on both Vontar X4 and Tanix W2 that on my ancient TV using 480p / 720p / 1080i makes the screen all colorful but works fine with the other resolutions and with NE / NG i donāt have this issue, how can i fix this?
Thanks vpeter the repo version works now.
Amremote (remote.conf) issues should be maybe fixed tomorrow.
There was a incompatibility from kernel 5.4 to 5.15.
