Amlogic S905X2
:crazy_face:
sorry gentlemen’s, I’m idiot lost 2 day on this stupid problem
Hey! first - Thx devs for great work! I have X96 Max 4/64 (CoreELEC-Amlogic-ng.arm-9.1-nightly_20190824-Generic.img.gz) booting ok, but something wrong with CEC - popup could not initialize cec adapter. Any ideas?
I have the same problem with my Magicsee n5 Max.
Ah I am going crazy. I had flac 24bit 96khz working on my x96 max s905x2, but suddenly no sound. I then booted into an old nightly I was sure it had been working, but no sound with spdif passthrough. Then I started up my old s812 device and flac 24 bit 96khz is working on my receiver. I start up the x96max again and be sure to use the same settings with best match, spdif passthrough, sample rate on 192khz but only 24bit 44.1khz sound or just 16 bit 44.1khz sound works.
Anybody any idea? I am on the latest nightly from 27 august. I don’t get any error, but there is no sound going to the receiver or something. And it really has been working also.
Try to switch to 2.0 in audio settings
Multichannel PCM is not implemented yet
@Fenom remove the power cable from the tv, put it back on and restart the tvbox
Sorry , sound like faulty optical out Omscar , also mine X96 Max have same problem
Thx, but same popup. (
My x96max 4/64 does not give sound by spdif. Same as your case
It’s a dtb configuration issue, unfortunately the devs have no way to test it and therefore fix it.
His case is that only 24bit and 16bit work, you’re saying that you have no output at all. So it’s not the same case as his.
No information about your setup means we can’t try to suggest anything to fix the issue.
I got this box Sawpy KM9 4x64GB LPDDR4 S905X2 Ethernet/100M
I assume it’s a Mecool KM9 Clone, I loaded nightly_20190829-Generic on a SDCard boot to CE without problem but Wifi and BT doesn’t work I used g12a_s905x2_4g.dtb and 1gbit with same results. Any advice?
Open it and check which wifi module inside.
Before opening it up, run the following command and post the url
udevadm info /sys/bus/sdio/devices/sdio* | paste
Connecting ethernet cable to it and ssh, this is the result:
http://ix.io/1TXq
Can anyone recommend me one of these S905x2 devices with wifi 5Ghz (ac) working ootb with CE?
This might help, dont know what hardware you have?
)H96 Max S905X2 working Coreelec
edit: saw the later post re Odroid, anyway anyone with same as in my linky may benefit.
UPD: I opened it and this is the wifi module:
wifi
http://ix.io/1TXq
Fix pushed (hopefully it’ll work), please try next nightly build.
