Amlogic S905X2
Does the CE release for S905X2 feature the SDR to HDR and HDR to SDR tone mapping settings as featured on the N2 version?
Install it and find out :wink:
Lol
I haven’t got a new box yet and it’s one of the factors that will get me to decide.
It should work the same as on S922X, so yes.
Thank you.
Thanks for your reply!
does fix was pushed on 20190902-Generic?
I tried that build but doesn’t work.
No, I made it today, so it would have been in the next nightly build - later tonight.
We had to revert the change because it wasn’t the right way to go.
Can you reboot the box and post output from this command?
dmesg | paste
This is the result in a clean installation.
http://ix.io/1UcP
Since nightly_20190904-Generic, IT6335 module is supported (Wifi + BT).
Thanks CE Team!!!
Please tell me img for cube x2 and dtb.img. Thanks.
Generic-ng.
DTB - s905x2 + RAM size and Ethernet speed.
Question for Beelink GT1 MINI owners , does CE working correctly on this device ?
Nope, still something like : CEC adapter not loaded correctly… I will really appreciate if this could be corrected, except this it is fine
No logs, no problem.
so if I understand corectly everything is fine expect this CEC problem mentioned above ?
Hi, remote.conf for cube x2 please
You can make your own, you don’t have to rely on others to do work for you.
Hello team. I have a x96max 4/64. My speed through 5G wifi is 105 down and 103 up (2 tests on android). When I do the speed test in coreelec nightly the results are 95 down and only 7 up. It is normal?
see
