Just tried the latest Nightly release on my Mecool KM9 Pro (2+16G) with 2.4 Ghz WiFi and 100 Mbps Ethernet. Performance is good (I used a USB SSD as boot device). However, the WiFi Chip is not detected.
@leptdre
Which DTB file did you use?
Is your display working?
Thanks.
I also owned MeCOOL KM9 Pro (2+16G) and tested the latest build CoreELEC-Amlogic-ng.arm-9.1-nightly_20190808.tar, using g12a_s905x2_2g.dtb (tried g12a_s905x2_2g_1gbit.dtb but ethernet doesnât work). Result is the same as @leptdre, there is no WiFi connections listed under âConnectionsâ tag. WiFi chipset of the TV box is AP6236.
@leptdre @wkchick
We donât have drivers for the AP6236 in our repo just yet.
I see that they are available, so I think it shouldnât be much of a problem to add them, but @anon88919003 knows about this more than me.
@leptdre @wkchick
Hereâs a build that should have AP6236 support. Please give it a shot and report back whether it works or not.
link removed
Bingo, I just tested, WiFi is working. Iâm not sure that the AP6236 works with both 2.4 and 5GHz band but at least I can now connected through 2.4GHz band to the router and get two IP address (I kept wire Ethernet active).
Thanks so much.
Edit: I just checked, Bluetooth on the MeCOOL KM9Pro is working as well!
g12a_s905x2_2g.dtb
I will test it om my mecool Km9 Pro 2+16G. BRB
Great, thanks.
According to this page, the AP6236 is 2.4GHz only, so it looks like itâs working correctly.
I donât know. We have an AP6335 firmware already, but I donât know whether itâs compatible with the âIT6335â chipset you have in your box. Itâs likely not. From the limited results I could find on Google, this chipset will not work without the appropriate drivers/firmware. And I canât find anything about this chip.
Sorry, my bad. I have Mecool KM9 and KM9 PRO, KM9 have a AP6255 chipset and Wifi and BT are working. In KM9 PRO IT6335 chipset not working.
It woorks , bluetooth also works !! please merge these changes !!!
Done. It should be available in tonightâs build.
BTW, I am new to Coreelec and I have a small question. Where are the WiFi settings stored ? (config files path). I am used mostly to Ubuntu, Android and OpenWRT
an âlspciâ and âlsusbâ would be helpful to fine hardware IDs. The chip would mostly work with a bcm driver. I will do some research.
Team, WiFi now works with 5GHz!, Ethernet is slow, I donât know how to check if Iâm connected at 1Gbps instead of 100 Mbps, can we see this in KODI?
Another thing⌠How can I turn on my device with the remote control IR? I can turn it off but not on. Thanks!
The wake up will be fixed when I add the g12a CPU support: CoreELEC BL301 Wake-Up feature [inject_bl301]
I guess next weekâŚ
Check this out:-
These are PC commands for scanning PCI and USB bus, TV boxes do not have PCI and WiFi is attached via SDIO and not USB.
The command your looking for isâŚ
udevadm info /sys/bus/sdio/devices/sdio*
