Audio Sync Issue
Are you saying your box is not an N2+, or are you saying it’s not an N2 at all. If the later, what is your box?
X96 MAX Plus S905x3 4/64.
OK, so not hardware dependent.
Well that’s even more confusing as to why more people are not having the issue.
I had audio sync issues with X265 material, where I would have to have an audio offset of a delay of 0.250s but in the last couple of nighties all seems well with the default settings.
For me it is not related to just one type of playback. Can be x264/x265 Movies, TV Shows, Live FTA TV, Steaming app like Plex does not seem to matter.
And sometimes it is over a second out. So much so if you are watching a FTA TV game show the contestents buzzer would sound before their buzzer light would come on.
That’s interesting, however I wonder if that helps locating what the issue is with CE.
No one in the team is able to reproduce the “error” so we can’t search for a reason for it.
You might find a sample file where this issue can be reproduced on every play so we can debug it!?
I am installing now 19.4 from scratch , will report…
Definitely happening here too. N2+. Not specific files, and not all the time, but regularly…
this doesn’t help, here N2+, never happen
ok, how can we help? my sample video will be in German, maybe you do not recognize the gap
can I provide a log?
It won’t help as it will not be the same moment same time - in my opinion it is not file related. I bought new hdmi cable to try it.
A log does not help as we don’t know what to look for, so only a sample will help where it happen every play. And never happen on 19.3.
Deutsch ist ok, kein Problem
ok, today no issue
i installed Coreelec 19.4 from Scratch
before I had the RC3 and updated this to 19.4
i will keep an eye on it.
First of all thank you for the great work, using CoreElec for some years now!
With 19.3 CEC with my LG 55C7 was working perfectly. I never switch off the CoreElec device, and when I switch on the TV CEC works instantly. However with 19.4 now sometimes I have to switch HDMI channel back and forth for CEC start working again.
update: Today my box also froze with 19.4, had to hardreset the X88 King S922 box by removing power. I did not have this problem running 19.3 for months. Also some mkv are now stuttering when playing. Going back to 19.3 solved the stuttering.
Any ideas what it can be and what do you need for information so see what can be the underlying problem?
Full logs would be a great help to the devs!
Same here, on a S905X2 box I’m seeing freezes on suspend - I can ping it, but not ssh, it doesn’t react to anything from the outside either.
S905X3 also freezes coming out of suspend and only by cutting power it can restart.
I also noted a bug that has been intermittent between (some) versions, some times video stutters badly coming out of pause (it never happened with 19.3 version).
I have odroid n2 and version 19.4. After upgrading to 19.4 I have a problem, the video has a micro stuttering especially after pause and resume, voice begins to lose synchronization. After reverting to 19.3 everything is back to normal
https://wiki.coreelec.org/coreelec:troublesteps#before_posting_an_error
