Best device for Coreelec in 2022/2023
Ugoos AM6B+
100M should be more than enough for 4K HDR/DV. I’ve also bitten. Mine is supposed to arrive in about a week.
Nope.
Do You remember: 640kb ought to be enough for anybody
100M could be enough in some cases, in some cases it´s not enough.
(own experience) with 100M boxes
Check this thread out ,some good reading there!!!
Yes box is 100 mb
Kinhank g1 user for last 3 months
Excellent Box!!!
This will always be debated
If 100 enough???
Box is wifi 6
Comes in arnd 97.5mb ??
On the Android side , no issues with certified Netflix 4K playback
With wired 100mb ethernet.
Same with Amazon Prime
With streaming, no problem, but with UHD remuxes for example, it might not be enough. Depends on the cache size and depends if the box can fill the cache fast enough to not cause buffering issues. I’d go for a very big cache size with adaptive speed just in case.
It’s got WiFi 6 so no problem with any remuxes; on a different box with WiFi 6 I get 150 Mbit/s streams (with peeks over 180 Mbit/s) without any problem or buffering, and all that with Cache completely disabled.
I guess “IF” 100Mbit/s wired is not enough (who knows yet) I can always use wifi :slight_smile:
FEL support works on the Homatics Box R 4k Plus and should probably work on other devices S905X4 devices! It’s early days, but official support should come soon.
Continue here:
