Without DV TV you cannot try, or get any DV options. Reboot to eMMC should be present, so there is something wrong with your installation…
Sorry for a dumb question but where can I download the latest -NG+FEL test image for Homatics DUNE containing the latest ethernet .dtb fixes (files posted on MEGA have been removed)?
Not sure whether " [CoreELEC nightly builds] / [Amlogic-ng] / ce-21" is the correct place…
afaik, latest -ng ce21 nightly is the correct place for it, unless there have been some non-commited experiments with DTBs for this box.
i flash USB pen using Balena Etcher and reset button, i will try flash with rufus software.
didnt work, the reboot option do not show, the event log only show kodi successfully started.
use - rufus sotware, CoreELEC-Amlogic-ng.arm-21.1.1-Omega-Generic.img,
usb3 port, dovi.ko OP.
i saw that post but i don´t have another skin, i did a fresh install and the option never show.
Balena Etcher should be fine, I use it all the time. I’m not sure if Rufus will yield a different result.
the result was the same, i post a photo with homatics software, kernel version, …, can that be the problem or the version i have is ok
Why do you show picture from Android screen? Android version is OK.
Show the picture from CoreElec when you press “Power” icon on top left in Home screen.
Why don’t you try it, it has nothing to do with the skin, it’s a bug of CE
ok, i will try
ng builds for SC2 is WIP. There are workarounds to boot to android. Search the forum please.
Strange, since it is present in CE-ng nightly/cpm builds on Nokia 8010 with Estuary skin…
Try to find which skin has this option for your box.
You can modify every skin to add this option
i install the reboottoandroid, i reboot twice with no problem, in the afternoon i will try with other skin, and i will report the result,
thanks all for the help.
Edited the post
. No banned addons/repos related stuff, please
S905X3-K,A311D-K confirmed that These SOC can playback FEL.
S905X3-K
A311D-K
https://paste.coreelec.org/JoanneHairs
Are these actual commercial devices? Or are these custom boards where the original SOC was removed, replaced by DV licensed SOC soldered in?
