It’s connected via Denon X2300W to a Samsung UE60KS7090. The previous installed Odroid C2 with CoreELEC 9.2.5 had no such problems.
No, doesnt working and dont boot interface
http://ix.io/2PxV
http://ix.io/2PxW
@as_id please try this:
echo "modprobe aml_fe" > ~/.config/autostart.sh
Then reboot and test again.
No, nothing change, bootloop
That’s a different problem from mine. Mine is caused by dropped frames so there’s jerky movement in pans etc. Your problem seems more like an HDMI handshake or something like that. If you set the GUI to the same framerate as your source, does the issue occur?
No idea, I think DVB support ends here right now
try to remove support coreelec dvb, stay only last kernel and crazy cat
Yuk! Now the N2 drops the IP after some time as well :-/
I still think this issue is specific to my case and I don’t have time to keep searching for the cause.
I will just revert to cable.
Hi @all, i have a fresh install and all is good, but since the last two nightlies the “Skip” Button doesn’t work anymore. If I watched Series and the credits came, I used the “Skip” Button to play next episode. But the button does nothing anymore, the FF-Button to skip time is all ok. I put my other card with official CoreElec and the Skip-Button does his job. Can someone confirm this with actual nightly?! Thanks!
@as_id we feel very confident it is working now:
https://mega.nz/file/rGwmFb6R#ZA4nkgL171VT2K2GTg02bPZwS5MXDBlnHQAzv6vEcUE
Please confirm it working before new nightly is build (midnight, +1UTC), thank you!
I tried latest nightly on Vim 1 pro (S905x). Video playback from stream (premiumize) doesnt work. It starts and stops after 2-3 seconds. It is same for all resolutions and frame rates. Tried diferent streams. Same files work with no problem on stable Coreelec. Same settings aplied (HW decoding, etc). Any idea what might be the problem?
Premiumize is a banned kodi addon. No help with it
Well, of course I’ll check, I promised …
@Portisch @as_id
I can confirm that it is working! We are very grateful for your efforts and the entire team for making this possible, thanks.
@cdu13a Thank you for making this possible
YES, IT IS WORKING
http://ix.io/2PEp
http://ix.io/2PEq
CEC is perfect,
For me the problems with CEC have been solved.
Thank you for support CE and testing!
My pleasure
But, CoreElec default drivers dvb doesn’t work anyway. Either remove or fix them in release…
http://ix.io/2PF4
http://ix.io/2PF5
That’s normal, they are not updated or maintained.
Also this is the reason of crazycat/dvb-latest.
