CoreELEC 20.0-Nexus Amlogic-ng Discussion
Odroid-N2 with CoreELEC 20.0
When device is powered off then sending magic packet on port 9 doesn’t wake device.
Is it a known issue in CoreELEC 20.0?
I’m pretty sure it used to work in 19.5 or I’m wrong and device can be only waked up from suspend state but not from power off?
I run N2/20.0 and wol from suspend/off works fine
https://wiki.coreelec.org/coreelec:ce_addon_hardware#hardware
wake on LAN from suspend state works for me.
wake on LAN from power off state doesn’t work for me.
Of course I have wake on LAN enabled in CoreELEC settings.
Enable also USB power. Maybe the 5V are turned off?
I just tested on 2 of my n2’s, both wake from power off after sending a magic packet.
Only thing I did was enable wake on lan. All i can say it doesn’t seem to be a general issue.
Bingo!
That was the root cause.
When “USB Power” is enabled as well as “Wake-on-LAN” then wakeup from power off state works.
Thanks.
When can we expect an update to version 20.1?
Closed, please continue here:
