OK, position “Bottom of screen” and Vertical margin" set to 0% is what I was looking for to have subtitles at very bottom of the screen.
And colour is missing in the skin I’m using but once selected in Estuary remain in my skin.
Issue with two lines of dialog being displayed very high is really annoying especially that it is happening only on some of these dialogs… I tried to see if something is wrong with these particular two lines on the last example I presented above but nothing found. Hope it will not happen too often.
Case closed.
I am new to using CoreELEC. This is the first time I have updated, going from 19.5 → 20.0. Can anyone tell me how to go about installing Inputstream Adaptive? I see that it was an issue with installing on rc1 but according to this it should have been fixed with an update. Has it been fixed and if so could someone please tell me how to install the update?
I’ve installed 20.1 nightly update, and also from coreelec repo the amiga emulator.
Something must have happened lately, because now it is too slow, and audio and video stutters everywhere, which was not the case before, when i tried the last time, 1 month ago.
On S905x4 generic device X96_X4.
I have problems with 3D switching with the Minix Neo U22-XJ Max. When I disable 3D mode, the picture distorts and the resolution is not correct anymore. With the Minix Neo U1 it works.
Not sure if the update was just released or something else was going on, but the inputstream adaptive addon just updated after a reboot. I did try clicking on check for updates several times and that didn’t work and I had also rebooted a couple times prior to this as well. But it fixed itself so all good.
In /.kodi/media/ make a folder and name it Fonts Then drop in this new /.kodi/media/Fonts folder any free/open_source .ttf font that you like. After Kodi reboot you’ll be able to choose that font.
It popup twice or 3 times since I have installed Nexus 20 on my Odroid-N2.
Every time it was popup I did a reboot but then few hours later it was again.
You will get this message one time when you change something in CE DTB settings.
When rebooted it should not come again until you change something else.
I just tried Nexus 20.0 amlogic-ng from a clean install to a SD card on my N2+. When I played back some BD ISOs I noticed some bad aliasing of the image.
When I disable the amlogic hardware decoder, the image is fine again. Am I missing something?
Go to Settings - Player - Subtitles. Enter Position on screen. Choose Manual.
Start Video. Enter Settings - Video Settings. Choose Video calibration. Set the short bar down to your choosing. Save calibration. Hit back. Enter Again Video Settings. Choose Set as default for all media.
