CoreELEC 20.3-Nexus (January 12th, 2024)
Hotfix Update
The Amlogic-ng-dv image was just re-uploaded.
If you installed Amlogic-ng-dv before January
17th, 2024 please update again with the same release.
CoreELEC 20.3-Nexus is now available. It was a rather short development cycle this time around, which saw the CoreELEC developers focusing on fixing the most common issues reported with the 20.2-Nexus release.
Special news: User land architecture of project Amlogic-ne did change from arm to aarch64.
This is the reason it’s highly recommended to make a clean fresh install.
Changes Since 20.2-Nexus
* Added S805X SoC h265 10bit 4k fallback
* Use Android media firmware and tools since SC2 (S905X4)
* Added support for LED BCT3236
* Introduced new device Amlogic-ng-dv
* librespot: fix running with cp15 barrier emulation
* Fixed distribution paste service
* Amlogic-ne: Updated Linux/arm64 5.4.210
* Amlogic-ne: switched default user land to aarch64
* Amlogic-ne: added support for PCI
* Amlogic-ne: enabled Joydev device driver
* Amlogic-ne: added Wifi module support for AP6330 AMPAK Tech
* Amlogic-ne: added Wifi module support for RTL8822CU
* Amlogic-ne: enabled multiple Wifi module in linux config
* Amlogic-ne: added support for DVB TBS5580, TBS5990 TBS5281
* Amlogic-ne: enabled /dev/mem module in linux config
Downloads:
- Click here
Before posting an error:
- Click here
Discussion thread Amlogic-ng:
- Click here
Discussion thread Amlogic-ne:
- Click here
