CoreELEC 21.1-Omega Amlogic-ne Discussion
Perfect, I’ll run the tests tomorrow and post the results.
Perfect, after doing tests with binary search, I finally found the one causing issues:
CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20240409.tar → OK
CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20240410.tar → OK
CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20240413.tar → KO
CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20240417.tar → KO
Device
G7 Max S905x4 1000m 4GB
Problematic nightly
Although I know it’s not necessary, here are the changes from the release notes:
udevadm info /sys/bus/sdio/devices/* | paste
https://paste.coreelec.org/DeceivedDepth
Please try with this test image if Wifi speed is normal again:
Yes, I just tested it, and the Wi-Fi works perfectly! :slight_smile:
s905x4, wifi now working.
@JSAURA @FedericoCZ please try again with this test image:
It’s not that it didn’t work for me before, it’s just that it was VERY slow, and with the patch I tested, the speed was correct, so the issue was resolved for me. Tonight, I’ll test the latest patch to see if everything remains the same as the previous one.
Again, both this one and the previous one work well for me. :slight_smile:
The file you are trying to download is no longer available
Will a stable version with this fix be released?
21.2? No due date.
Ok, perfect. Since it’s for a family member, I prefer to leave them with a stable version. However, is it possible to switch from nightly to stable directly from the CoreELEC options? They don’t have much technical knowledge, so I’d like to make it as ‘easy’ as possible for them
Not possible i think
If you enable in settings
Update to next stable
Your nightly would have to be older/predate the lasted Stable
Switch Auto updates to Manual
Or Clean install
Ok, understood. I’ll disable automatic updates, and when the stable version is available, I’ll tell them to enable the ‘update to next stable’ option
When trying to start playing several of my recent AV1 encoded videos, the Ugoos AM8 Pro crashes. If I disable AV1 hardware decoding, no problems.
Crash logs here: https://paste.coreelec.org/ActualLeprosy
Test clip here: brogers.mkv - Google Drive
Another issue with AV1 HW decoding is the HBO logo with heavy static noise. When starting playback, the screen stays black and audio continues normally. Then after a long time, video playback resumes. Video playback sometimes also starts to work when jumping back 10 seconds or so.
Test clip here: dwood.mkv - Google Drive (without audio)
One thing I noticed while testing this: when the playback starts and screen stays black, the ‘O’ menu shows 1280x720p video. If I jump back and video playback resumes, 1280x720i is what it shows. My clips are progressive so I don’t know where it gets the ‘i’ there.
Disabling hardware decoding also fixes this issue (and libdav1d shows 1280x720p).
What happens to me after installing the Nightly that fixes the slow Wi-Fi issue on my S905x4 is that now DAZN doesn’t work. The installation is OK, but the addon won’t start, whereas in the stable 21.1.1 version it works without issues.
I’ve read in other forums about people having similar problems where DAZN stopped working after an update, but reinstalling the image from scratch solved it for them. I just don’t understand…
2024-09-17 15:06:18.441 T:1160    debug <general>: FreeVisualisation() done
2024-09-17 15:06:18.443 T:1160    debug <general>: ------ Window Init (MyVideoNav.xml) ------
2024-09-17 15:06:18.455 T:1160    error <general>: Control 55 in window 10025 has been asked to focus, but it can't
2024-09-17 15:06:18.469 T:1160    debug <general>: CGUIMediaWindow::GetDirectory (plugin://plugin.video.dazn/)
2024-09-17 15:06:18.469 T:1160    debug <general>:   ParentPath = [plugin://plugin.video.dazn/]
2024-09-17 15:06:18.470 T:1862    debug <general>: Thread waiting start, auto delete: false
2024-09-17 15:06:18.479 T:1722    debug <general>: CAddonDatabase::SetLastUsed[plugin.video.dazn] took 9 ms
2024-09-17 15:06:18.479 T:1862    debug <general>: CScriptRunner: running add-on script DAZN('plugin://plugin.video.dazn/', '3', '')
2024-09-17 15:06:18.480 T:1863    debug <general>: Thread LanguageInvoker start, auto delete: false
2024-09-17 15:06:18.480 T:1862    debug <general>: [threads] name: 'LanguageInvoker' priority: '1'
2024-09-17 15:06:18.480 T:1863    debug <general>: initializing python engine.
2024-09-17 15:06:18.480 T:1863    debug <general>: CPythonInvoker(10, /storage/.kodi/addons/plugin.video.dazn/addon.py): start processing
2024-09-17 15:06:18.517 T:1863    debug <general>: -->Python Interpreter Initialized<--
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10, /storage/.kodi/addons/plugin.video.dazn/addon.py): the source file to load is "/storage/.kodi/addons/plugin.video.dazn/addon.py"
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10): full python path:
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):   custom python path:
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /storage/.kodi/addons/plugin.video.dazn
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /storage/.kodi/addons/script.common.plugin.cache/resources/lib/storage_server/
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /storage/.kodi/addons/script.module.inputstreamhelper/lib
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /storage/.kodi/addons/script.module.kodi-six/libs
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /storage/.kodi/addons/script.module.six/lib
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):   default python path:
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /usr/lib/python311.zip
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /usr/lib/python3.11
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /usr/lib/python3.11/lib-dynload
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):     /usr/lib/python3.11/site-packages
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10): adding args:
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):  plugin://plugin.video.dazn/
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):  3
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10):  resume:false
2024-09-17 15:06:18.517 T:1863    debug <general>: CPythonInvoker(10, /storage/.kodi/addons/plugin.video.dazn/addon.py): entering source directory /storage/.kodi/addons/plugin.video.dazn
2024-09-17 15:06:18.518 T:1863    debug <general>: CPythonInvoker(10, /storage/.kodi/addons/plugin.video.dazn/addon.py): instantiating addon using automatically obtained id of "plugin.video.dazn" dependent on version 3.0.1 of the xbmc.python api
2024-09-17 15:06:18.570 T:1160    debug <general>: ------ Window Init (DialogBusy.xml) ------
2024-09-17 15:06:19.309 T:1863    debug <CAddonSettings[0@plugin.video.dazn]>: trying to load setting definitions from old format...
2024-09-17 15:06:20.440 T:1863     info <general>: Skipped 11 duplicate messages..
2024-09-17 15:06:20.440 T:1863    debug <general>: [script.module.inputstreamhelper] Platform information: uname_result(system='Linux', node='CoreELEC', release='5.4.210', version='#1 SMP PREEMPT Sat Sep 7 15:04:47 CEST 2024', machine='aarch64')
2024-09-17 15:06:20.454 T:1863    debug <CAddonSettings[0@script.module.inputstreamhelper]>: trying to load setting definitions from old format...
2024-09-17 15:06:20.455 T:1863    debug <general>: [script.module.inputstreamhelper] Found system architecture arm64
2024-09-17 15:06:20.461 T:1863    error <general>: EXCEPTION: Unknown addon id 'inputstream.adaptive'.
2024-09-17 15:06:20.480 T:1863    error <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                    - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                                   Error Type: <class 'RuntimeError'>
                                                   Error Contents: Unknown addon id 'inputstream.adaptive'.
                                                   Traceback (most recent call last):
                                                     File "/storage/.kodi/addons/plugin.video.dazn/addon.py", line 73, in <module>
                                                       playable = plugin.start_is_helper()
                                                     File "/storage/.kodi/addons/plugin.video.dazn/resources/lib/common.py", line 206, in start_is_helper
                                                       return helper.check_inputstream()
                                                     File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/__init__.py", line 420, in check_inputstream
                                                       if self.drm == 'widevine' and not self._supports_widevine():
                                                     File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/__init__.py", line 146, in _supports_widevine
                                                       is_version = parse_version(addon_version(self.inputstream_addon))
                                                     File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/kodiutils.py", line 103, in addon_version
                                                       addon = xbmcaddon.Addon(addon_name)
                                                   RuntimeError: Unknown addon id 'inputstream.adaptive'.
                                                   -->End of Python script error report<--
2024-09-17 15:06:20.484 T:1863    debug <general>: onExecutionDone(10, /storage/.kodi/addons/plugin.video.dazn/addon.py)
2024-09-17 15:06:20.494 T:1160    debug <general>: ------ Window Init (DialogNotification.xml) ------
2024-09-17 15:06:20.753 T:1863    debug <general>: Python interpreter stopped
2024-09-17 15:06:20.753 T:1863    debug <general>: Thread LanguageInvoker 544948285120 terminating
2024-09-17 15:06:20.772 T:1862    error <general>: GetDirectory - Error getting plugin://plugin.video.dazn/
2024-09-17 15:06:20.772 T:1862    debug <general>: Thread waiting 546803019456 terminating
2024-09-17 15:06:20.775 T:1160    debug <general>: ------ Window Deinit (DialogBusy.xml) ------
2024-09-17 15:06:20.777 T:1160    error <general>: CGUIMediaWindow::GetDirectory(plugin://plugin.video.dazn/) failed
2024-09-17 15:06:20.777 T:1160    debug <general>: CGUIMediaWindow::GetDirectory ()
2024-09-17 15:06:20.777 T:1160    debug <general>:   ParentPath = [plugin://plugin.video.dazn/]
2024-09-17 15:06:20.782 T:1865    debug <general>: Thread waiting start, auto delete: false
2024-09-17 15:06:20.783 T:1865    debug <general>: Thread waiting 546803019456 terminating
2024-09-17 15:06:20.881 T:1866    debug <general>: Thread BackgroundLoader start, auto delete: false
2024-09-17 15:06:20.881 T:1160    debug <general>: [threads] name: 'BackgroundLoader' priority: '1'
2024-09-17 15:06:20.890 T:1866    debug <general>: Thread BackgroundLoader 545024372416 terminating
2024-09-17 15:06:23.226 T:1171    debug <general>: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 33ms
2024-09-17 15:06:23.226 T:1867    debug <general>: Thread Timer start, auto delete: false
2024-09-17 15:06:23.262 T:1160    debug <general>: Keyboard: scancode: 0x1, sym: 0x1b (escape), unicode: 0x1b, modifier: 0x0
2024-09-17 15:06:23.314 T:1867    debug <general>: Thread Timer 545058188992 terminating
2024-09-17 15:06:23.352 T:1160    debug <general>: Keyboard: scancode: 0x1, sym: 0x1b (escape), unicode: 0x1b, modifier: 0x0
2024-09-17 15:06:23.352 T:1160    debug <general>: HandleKey: escape (0xf01b) pressed, window 10025, action is Back
2024-09-17 15:06:23.352 T:1160    debug <general>: CGUIWindowManager::PreviousWindow: Deactivate
2024-09-17 15:06:23.675 T:1160    debug <general>: ------ Window Deinit (MyVideoNav.xml) ------
2024-09-17 15:06:23.695 T:1160    debug <general>: FreeVisualisation() done
2024-09-17 15:06:23.696 T:1160    debug <general>: CGUIWindowManager::PreviousWindow: Activate new
2024-09-17 15:06:23.696 T:1160    debug <general>: ------ Window Init (Home.xml) ------
Missing addon or wrong version?
