Yes thats easy. ![]()
But in which skin?
In your modified Estuary for CPM builds.
(I don’t use any other builds any more, it even works perfect on my holiday place Kinhank G1 box ![]()
Show me which one… I made bunch ![]()
I think in default CE Estuary it would be useful, can also PR into my cpm.Estuary if you have time ![]()
This is a thread about stable 21.1. Please keep it clean. If we’re in the business of asking for PRs I also have some requests ![]()
Which requests? ![]()
Mine are for @cpm! ![]()
addon id=“skin.estuaryce” version=“4.0.2” name="EstuaryCE
And PR @cpm so he can include your solution in his “skin.cpm.estuary.A3” ![]()
Done. I will post that in other, relevant topic, as Vasco requested.
I finally tested a recent CE build, and the dwood.mkv clip still doesn’t work properly. The playback starts but pauses and continues sporadically, lots of blocking etc. Jumping forward and back won’t help much, very glitchy and jumpy playback even after that.
Enable Kodi video component debug and share Kodi.log.
The AV1 FB decoder limit must be 1080p instead 720p. Than it play fine.
Should be fixed within some next nightlies.
Do you know if the HW decoder detects interlacing correctly or is the ‘o’ menu just showing incorrect info? For HW decoded AV1, it shows for example 1280x720i. Software decoding shows correct information.
This is now working, thank you ![]()
All,
Is there a fix for the wifi issue?
If there is, I’m wondering if it may be in the 21.1.1 nightly builds.
Slow Wifi here too on 21.1.1 stable . Tested Ne and Ng . It always shows wlan0 and p2p0 at same. Both wifi interfaces are really slow. Ethernet and Bluetooth working fine. Which previous builds are recommend to choose to fix this Problem?
Specs are:
S905X4/ 4gb/ 64rom just 100mbit lan
It same like tanix x4 even all Ports. Mine is called Voncen n6 pro
Hope someone could help me because i am since beginning an big fan of Coreelec.
I tried everything but no success. Is it anyways helpfull to do an clean install to 21.0 stable? Could you share with me the working build Portisch?
I almost spend 5hours of reading threads.
Thanks in advance.
