CoreELEC 21.2-Omega Amlogic-ng Discussion
Use search function to know that NG and whole CE-21 is not under development anymore.
And where is 21.3 Final, is it even coming?
Ask at Kodi?
From what I read on git they are still on the fence about it
Here is the response from the Kodi forum: We are not planning on one. v22 Alpha 2 will be the next release in a couple of weeks as soon as a couple of PR’s are merged.
What’s that about? First, the 21.3 should be finalised, and then something new should be started.
This is why CE-NG is EOL. TK ist done with Kodi 21.
So the nightly build from 2 October 2025 is the last one?
Portisch CoreELEC Team
3h
The End
Here’s the log in hopes that this issue gets fixed: https://paste.coreelec.org/LockingSkippy
I tried play my original CD medium which was played through KODI at identical device (external samsung dvd player and writer) cca 1 year ago. No i see error in dmesg at CE21NG:
[34325.473993@3]- scsi host0: usb-storage 1-1.3:1.0
[34326.499408@1]- scsi 0:0:0:0: CD-ROM            TSSTcorp CDDVDW SE-S224Q  TS02 PQ: 0 ANSI: 0
[34326.513618@1]- sr 0:0:0:0: [sr0] scsi3-mmc drive: 8x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[34326.516246@1]- sr 0:0:0:0: Attached scsi CD-ROM sr0
[34326.519752@0]- sr 0:0:0:0: Attached scsi generic sg0 type 5
[34326.701141@1]d scsi_io_completion: 243 callbacks suppressed
[34326.701161@1]d sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[34326.701176@1]d sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[34326.701193@1]d sr 0:0:0:0: [sr0] tag#0 Add. Sense: Illegal mode for this track
[34326.701206@1]d sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 02 9c f6 00 00 02 00 00 00
[34326.701212@1]d blk_update_request: 243 callbacks suppressed
[34326.701217@1]d blk_update_request: I/O error, dev sr0, sector 685016
[34326.702753@1]d sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[34326.702767@1]d sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[34326.702783@1]d sr 0:0:0:0: [sr0] tag#0 Add. Sense: Illegal mode for this track
[34326.702797@1]d sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 02 9c f6 00 00 01 00 00 00
[34326.702804@1]d blk_update_request: I/O error, dev sr0, sector 685016
[34326.702811@1]d buffer_io_error: 240 callbacks suppressed
[34326.702816@1]d Buffer I/O error on dev sr0, logical block 171254, async page read
[34326.704196@1]d sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[34326.704210@1]d sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[34326.704226@1]d sr 0:0:0:0: [sr0] tag#0 Add. Sense: Illegal mode for this track
[34326.704239@1]d sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 02 9c f7 00 00 01 00 00 00
[34326.704246@1]d blk_update_request: I/O error, dev sr0, sector 685020
[34326.704255@1]d Buffer I/O error on dev sr0, logical block 171255, async page read
[34326.705990@1]d sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[34326.706004@1]d sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[34326.706023@1]d sr 0:0:0:0: [sr0] tag#0 Add. Sense: Illegal mode for this track
[34326.706036@1]d sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 02 00 00 00
[34326.706043@1]d blk_update_request: I/O error, dev sr0, sector 0
[34326.707489@1]d sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[34326.707504@1]d sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[34326.707519@1]d sr 0:0:0:0: [sr0] tag#0 Add. Sense: Illegal mode for this track
[34326.707533@1]d sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 01 00 00 00
[34326.707540@1]d blk_update_request: I/O error, dev sr0, sector 0
[34326.707548@1]d Buffer I/O error on dev sr0, logical block 0, async page read
[34326.708945@1]d sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[34326.708959@1]d sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[34326.708975@1]d sr 0:0:0:0: [sr0] tag#0 Add. Sense: Illegal mode for this track
[34326.708988@1]d sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 00 01 00 00 01 00 00 00
[34326.708995@1]d blk_update_request: I/O error, dev sr0, sector 4
https://paste.coreelec.org/IssueCrawls
I tried this command which is not in coreelec:-sh: cd-info: command not found
Freedb is out. Local cddb would be better than nothing or this https://gnudb.org/, but need registration.
As default was set now nonfuctional freedb server. https://kodi.wiki/view/Advancedsettings.xml#cddbaddress
you need to use
cdda
VLC uses this protocol (or access module) to read data from a device or network. Usage: cdda://device@track
The module name to use at the command line is cdda, but you can also use cddasimple.
For Ubuntu, use vlc cdda:///dev/sr0
In ending CD is going play, but after 5 minutes of freezing.
https://paste.coreelec.org/FunnierNolan
Same situation at CE22NO: Amlogic-NO discussion - #2702 by atirage21
Closed, continue here:
