CoreELEC 22.0-Piers_alpha1 Discussion
I would be delighted if BT pairing worked automatically in CE, as it does with ATV. That would be great. At the moment, this is not the case; you have to do it via IR remote or manually with wirelles Mouse.
I have the same problem now.
I wanted to test CE 22 on my Homatics dune R 4k+. After first installation I got a warning that my android kernel version should be at least 5.15.137. So I installed the latest available in internet image - 14.8.4576, kernel 5.15.153 (higher than required). Then I installed the latest CE 22 build, but still the same message about missing kernel version requirement and no DV support. Moreover WiFi can not be connected – network IO error every time. And lastly with with firmware / android version of the box I can not install any other CE version anymore. Installation process does not start going in cycles just showing homatics logo for a couple of seconds. Any advice would be helpful.
Ok as I read other topics about Homatics Dune box, I see that ATV14 supports only NG and NO.
But it is a bit confusing though as NG is older than NE release. Also extra dovi.ko driver was mentioned to enable DV on NO release and ATV14.
No, CE-NG is EOL.
All get issues about video codecs,. colours or DV.
Use CE-NO, latest nightly and all will be solved!
4.9 CE-NG kernel was never finished for SC2, S905X4 SoC!
Yes I installed CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20251003-Generic.img.gz
At least this build was able to properly display the picture and with dovi.ko file also play DV.
But WiFi is not working for me and I can not configure IR remote the same way as I did on CE21.
Because when you read the forum you will find you need a new configuration file…
No log, no error.
Yes i know the policy :grinning_face: Trying cable ethernet now to transfer logs
Here is the log with the WiFi connection attempt to “Teufel” access point
Kodi.log (1.2 MB)
I’m not sure what is the problem described by that:
Oct 04 19:01:40.307186 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Trying to associate with SSID ‘Teufel’Oct 04 19:01:40.310789 Homatics-Dune-R-4K kernel: [dhd] do_iovar_aml_enable aml failed -23Oct 04 19:01:40.310985 Homatics-Dune-R-4K kernel: [dhd] CFG80211-ERROR) wl_set_multi_akm : Failed to set join_pref, error = -1
Oct 04 18:59:42.046792 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_run_escan : LEGACY_SCAN sync ID: 3, bssidx: 0Oct 04 18:59:55.449778 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: Input/output errorOct 04 18:59:57.023630 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 18:59:57.023734 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:00:01.027533 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 19:00:01.027643 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:00:10.027714 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 19:00:10.027821 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:00:26.039552 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 19:00:26.039659 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:00:51.026674 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 19:00:51.026772 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:01:27.047594 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 19:01:27.047690 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:01:28.023237 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] state is associationOct 04 19:01:28.023646 Homatics-Dune-R-4K connmand[595]: ipconfig state 2 ipconfig method 1Oct 04 19:01:28.038786 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_run_escan : LEGACY_SCAN sync ID: 4, bssidx: 0Oct 04 19:01:32.217080 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Trying to associate with SSID ‘Teufel’Oct 04 19:01:32.222802 Homatics-Dune-R-4K kernel: [dhd] do_iovar_aml_enable aml failed -23Oct 04 19:01:32.223084 Homatics-Dune-R-4K kernel: [dhd] CFG80211-ERROR) wl_set_multi_akm : Failed to set join_pref, error = -1Oct 04 19:01:32.223167 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_ext_set_chanspec : channel 5g-36(0xe02a 80MHz)Oct 04 19:01:32.226779 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_conn_debug_info : Connecting with d4:24:dd:a9:0b:88 ssid “Teufel”, len (6), channel=5g-36(chan_cnt=1), sec=2/0x0/mfpc/aes, rssi=-60Oct 04 19:01:32.354803 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_handle_assoc_fail : assoc fail Reason: WLC_E_SET_SSID from 00:00:00:00:00:00Oct 04 19:01:32.355102 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_ext_iapsta_link : connect failed event=0, reason=0, status=1Oct 04 19:01:32.355192 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_bss_connect_done : Report connect result - connection failedOct 04 19:01:32.355254 Homatics-Dune-R-4K kernel: [dhd] [wlan0] IAPSTA-ERROR) wl_ext_in4way_sync_sta : connect failed at 1Oct 04 19:01:32.355311 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_iw_event : [0 times] disconnected with 00:00:00:00:00:00, event 11, reason 8Oct 04 19:01:32.355364 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_ext_iapsta_link : [S] Link down with 00:00:00:00:00:00, WLC_E_DISASSOC(11), reason 8Oct 04 19:01:32.355885 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=d4:24:dd:a9:0b:88 status_code=13Oct 04 19:01:32.356134 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Added BSSID d4:24:dd:a9:0b:88 into ignore list, ignoring for 10 secondsOct 04 19:01:32.362351 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] error “connect-failed”Oct 04 19:01:32.362615 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] state is failureOct 04 19:01:32.362907 Homatics-Dune-R-4K connmand[595]: ipconfig state 7 ipconfig method 1Oct 04 19:01:32.497779 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] state is idleOct 04 19:01:36.034785 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_run_escan : LEGACY_SCAN sync ID: 5, bssidx: 0Oct 04 19:01:37.541693 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] state is associationOct 04 19:01:37.541956 Homatics-Dune-R-4K connmand[595]: ipconfig state 2 ipconfig method 1Oct 04 19:01:40.305673 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Removed BSSID d4:24:dd:a9:0b:88 from ignore list (clear)Oct 04 19:01:40.307186 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Trying to associate with SSID ‘Teufel’Oct 04 19:01:40.310789 Homatics-Dune-R-4K kernel: [dhd] do_iovar_aml_enable aml failed -23Oct 04 19:01:40.310985 Homatics-Dune-R-4K kernel: [dhd] CFG80211-ERROR) wl_set_multi_akm : Failed to set join_pref, error = -1Oct 04 19:01:40.311055 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_ext_set_chanspec : channel 5g-36(0xe02a 80MHz)Oct 04 19:01:40.311111 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_conn_debug_info : Connecting with d4:24:dd:a9:0b:88 ssid “Teufel”, len (6), channel=5g-36(chan_cnt=1), sec=2/0x0/mfpc/aes, rssi=-60Oct 04 19:01:40.442780 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: CTRL-EVENT-ASSOC-REJECT bssid=d4:24:dd:a9:0b:88 status_code=13Oct 04 19:01:40.443180 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Added BSSID d4:24:dd:a9:0b:88 into ignore list, ignoring for 10 secondsOct 04 19:01:40.443416 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_ext_iapsta_link : connect failed event=0, reason=0, status=1Oct 04 19:01:40.443616 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_handle_assoc_fail : assoc fail Reason: WLC_E_SET_SSID from 00:00:00:00:00:00Oct 04 19:01:40.443796 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_bss_connect_done : Report connect result - connection failedOct 04 19:01:40.443921 Homatics-Dune-R-4K kernel: [dhd] [wlan0] IAPSTA-ERROR) wl_ext_in4way_sync_sta : connect failed at 1Oct 04 19:01:40.444009 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_iw_event : [0 times] disconnected with 00:00:00:00:00:00, event 11, reason 8Oct 04 19:01:40.444109 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_ext_iapsta_link : [S] Link down with 00:00:00:00:00:00, WLC_E_DISASSOC(11), reason 8Oct 04 19:01:40.449513 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] state is failureOct 04 19:01:40.449824 Homatics-Dune-R-4K connmand[595]: ipconfig state 7 ipconfig method 1Oct 04 19:01:40.660654 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] state is idleOct 04 19:01:44.030786 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_run_escan : LEGACY_SCAN sync ID: 6, bssidx: 0Oct 04 19:01:48.293148 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Removed BSSID d4:24:dd:a9:0b:88 from ignore list (clear)Oct 04 19:01:53.034792 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_run_escan : LEGACY_SCAN sync ID: 7, bssidx: 0Oct 04 19:02:15.964891 Homatics-Dune-R-4K sshd-session[1350]: Accepted password for root from 192.168.0.10 port 57784 ssh2Oct 04 19:02:16.040935 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 19:02:16.041057 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:02:20.034785 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_run_escan : LEGACY_SCAN sync ID: 8, bssidx: 0Oct 04 19:03:20.050397 Homatics-Dune-R-4K connmand[595]: No valid proxy with proxy auto-configuration (PAC) URL http://wpad.fritz.box/wpad.dat for eth0 [ ethernet ] online check URL http://ipv4.connman.net/online/status.htmlOct 04 19:03:20.050473 Homatics-Dune-R-4K connmand[595]: Interface eth0 [ ethernet ] IPv4 online check to http://ipv4.connman.net/online/status.html failed: no valid proxyOct 04 19:03:33.824116 Homatics-Dune-R-4K sshd-session[1414]: Accepted password for root from 192.168.0.10 port 57918 ssh2Oct 04 19:03:41.046933 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_run_escan : LEGACY_SCAN sync ID: 9, bssidx: 0
Oct 04 19:01:32.217080 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Trying to associate with SSID 'Teufel'
Full connection attempt log:
Oct 04 19:01:32.226779 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_conn_debug_info : Connecting with d4:24:dd:a9:0b:88 ssid "Teufel", len (6), channel=5g-36(chan_cnt=1), sec=2/0x0/mfpc/aes, rssi=-60
Oct 04 19:01:32.362351 Homatics-Dune-R-4K connmand[595]: Interface wlan0 [ wifi ] error "connect-failed"
Oct 04 19:01:40.307186 Homatics-Dune-R-4K wpa_supplicant[623]: wlan0: Trying to associate with SSID 'Teufel'
Oct 04 19:01:40.311111 Homatics-Dune-R-4K kernel: [dhd] [wlan0] wl_conn_debug_info : Connecting with d4:24:dd:a9:0b:88 ssid "Teufel", len (6), channel=5g-36(chan_cnt=1), sec=2/0x0/mfpc/aes, rssi=-60
So no fel on the Nokia 8010 then?
I would like to know too :slight_smile:
Maybe you find your answer in the hundreds of answers on the same question in the forum?
Yep, I’m searching and searching and searching and searching again :wink:
In fact, I’m really doing that, I’m surely missing the answer, it can’t be otherwise
But I’m pretty sure I will find it, thanks
With a Vertex2, CE should work as LLDV like it’s in setting but greyed out !
Yes, because your log only shows LLDV, nothing else. What should be selectable?
But makes it sense? Watching DV on non DV TV will not work without tone mapping.
It will show wrong colours.
Ok, So it’s what I want, now need to figure out why Kodi crash on some movie, I have one where I can’t reproduce all the time.
But with a Vertex2 with Custom DV, tone mapping works, at least, I can see that some DV sample (eagle one for ex) the brightness change, so it’s mean that DTM is working based on the sample played ?
Share the link when you find it. I’ve looked but helas.
What link you are talking about ?
Info on Nokia 8010+dv fel+ce no.
TY
The current version of CE21 lacks proper DVD-Video support. I hope that this will be fixed in the new version of Kodi. Right now, the Ugoos AM6B+ could be the perfect device for all video formats, but the inability to watch DVD-Video prevents it from being so.
Many thanks to Portisch for the work on WiFi driver.
WiFi supports now all security features and is able to connect on CE22 / ATV14.
