CoreELEC 22.0-Piers_alpha1 Discussion
so, we can not run dolby vision on Am6b plus anymore?
Different dovi.ko than the one from NG
Can you help me get that dovi.ko please?
dovi.ko (429.9 KB) This is NO one :wink:
dovi.ko (2.1 MB) This one is NE
I bought a HK1 X50 with S905x5m
and I found only one problem in ce22.no.nightly.10.10
October 10th version of nightly has solved all the problems. At present, there is only one bug, that is, there is something wrong with the driver of the wired network card, and playing the network video is very stuck. But wireless is good.
hope you can solve this problem.THX
Thanks. I have noticed playback is good in NO but picture colors are too warm in dv and hdr
What is difference vet ween NE and NO
No idea, My pic looks the same on both.
Sorry to chirp in, will this DOVI.ko file be ok for for Ugoos SK1?
Of course it will.
when i go to CoreELEC nightly builds, i somehow see no nightlies. is this a bug?
There was an issue with today’s release. Wait until tomorrow
odroid n2+ / TVH client I went from version 19 directly to 22. I am satisfied. The new version even has a better picture. I noticed that the same problem persists. My hardware has 1 giga LAN but the transfers are not faster than 100 mega. And the Lan light is not blue but green. In general, I have not noticed any ineyproblems. The version is even stable and there are no unforeseen activities.
Hopefully you did a new clean install and not a upgrade.
For your LAN issue you will need to check your cables if they are CAT5e or higher qualified.
The LAN never had a blue LED, only green.
Today I discovered a problem with playing audio files.
The music is interrupted at approximately two-second intervals. (Simply put, it “chops”) .
TV playback (pvr hts) works without problems and movie playback is fine.
It seems like there is a problem with the higher quality of the audio (bitrate) some files work and some don’t.
The audio format in this case doesn’t play any role.
Another thing I noticed is that the visualization doesn’t show up at all. (in my case “spectrum”)
according to the info on the screen, live stream
44.1 kHz, 128kbps,32bit does not work.
48 kHz,128kbps,32bit works.
audio file. mp3:
44.1 kHz, 128 kbps, 32 bit does not work.
48 kHz, 128kbps, 32bit works.
Hi everyone,
will there be Odroid N2L builds like the 21.2 amlogic-ng builds?
