CoreElec HW monitor
You have to do this:
opkg install bash tc coreutils-timeout
and you’ll get this nice screen without data:
and this error:
2018-09-26 23:22:04: netdata INFO : PLUGINSD[charts.d] : Initializing file /opt/var/cache/netdata/sensors.temp_thermal_zone0_thermal_thermal_zone0/main.db.
2018-09-26 23:22:04: netdata INFO : PLUGINSD[charts.d] : Initializing file /opt/var/cache/netdata/sensors.temp_thermal_zone0_thermal_thermal_zone0/sys_devices_virtual_thermal_thermal_zone0_temp.db.
/opt/lib/netdata/plugins.d/charts.d.plugin: Cannot use current_time_ms_from_uptime() - new time 510 is older than the last 82256790 - falling back to current_time_ms_from_date().
/opt/lib/netdata/plugins.d/loopsleepms.sh.inc: line 22: 1537996924 * 1000 + %-N / 1000000 : syntax error: operand expected (error token is "%-N / 1000000 ")
2018-09-26 23:22:04: netdata ERROR : PLUGINSD[charts.d] : read failed
2018-09-26 23:22:04: netdata ERROR : PLUGINSD[charts.d] : ‘/opt/lib/netdata/plugins.d/charts.d.plugin’ (pid 22207) disconnected after 0 successful data collections (ENDs).
2018-09-26 23:22:04: netdata ERROR : PLUGINSD[charts.d] : ‘/opt/lib/netdata/plugins.d/charts.d.plugin’ (pid 22207) does not generate useful output but it reports success (exits with 0). Waiting a bit before starting it again…
I didn’t know, a bash installation was available in Entware.
That’s great…kind of…at least one step closer.
The main problem now seems to be this one (again executed charts.d.plugin with debug enabled):
2018-09-26 23:43:10: charts.d: INFO: main: started from '/opt/lib/netdata/plugins.d/charts.d.plugin' with options: debug 1
/opt/lib/netdata/plugins.d/loopsleepms.sh.inc: line 22: 1537998190 * 1000 + %-N / 1000000 : syntax error: operand expected (error token is "%-N / 1000000 ")
/opt/lib/netdata/plugins.d/loopsleepms.sh.inc: line 63: [: : integer expression expected
2018-09-26 23:43:10: charts.d: INFO: main: configuration file '/opt/lib/netdata/plugins.d/../../../../etc/netdata/charts.d.conf' not found. Using defaults.
This version of bash seems to have problems with calculations using $(( … )).
Furthermore it can’t find the file /opt/etc/netdata/charts.d.conf, though the path should be the right one.
EDIT: No, wait…the path to the charts.d.conf isn’t the right one, because it searches the file in /etc/netdata/ instead of /opt/etc/netdata.
At least, if I count the “…/” correctly, because my eyes begin to flicker, now. ^^
I got it working :slight_smile:
with a nasty hack. Replace /opt/lib/netdata/plugins.d/loopsleepms.sh.inc with this one and voilà
edit: Wrong file, use this instead:
loopsleepms.sh.inc (5.0 KB)
It works for me, too. :slight_smile:
Thank you for the hacked up file.
But I also changed line 125 in charts.d.plugin to the following one to get rid of the “configuration file not found” message:
myconfig="/opt/etc/netdata/charts.d.conf"
Unfortunately in my install of coreelec, glibc 2.27/28 seems to missing. I’m not sure if that’s the way it should be.
If you follow these steps, you shouldn’t have any problems:
Install Entware and reboot your box.
From ssh type this:
opkg install netdata bash tc coreutils-timeout
Unpack the attached file to /storage/.opt replacing the files.
netdata.zip (5.4 KB)
Now you can access the netdata dashboard from http://coreelec_box_ip:19999
Excellent write up @Uukrul :+1:
Excellent! @Uukrul
Entware Package Manager is the nicest thing added to CoreElec @anon88919003
Maybe I am being obtuse this am, but I am unsure whether some specific files or complete directories should overwrite existing directories/files.
Would it be possible to post a couple of commands to ensure the correct procedure is followed?
Thank you.
Here is a little script, which automates the installation:
entware_netdata.sh (649 Bytes)
After downloading it with wget, you need to add the execute flag:
chmod +x entware_netdata.sh
Thank you.
That cleared up my confusion.
Also very nice to have a script to do the job without having to decide on paths :slight_smile:
Appreciate the help :wink:
I’ve modified the System Overview to include the temperature:
netdata.zip (55.6 KB)
very cool. Is it possbile to move the items or you have to do it?
Nice to have temp up there with the rest! :smiley:
Thanks.
If you only want to do a quick hack moving around gauges, edit /storage/.opt/share/netdata/web/index.html (function headMain(os, charts, duration) at pos 1656)
I’ve added it to the install script I posted earlier:
@Uukrul:
Are your previous changes still included in the last zip you posted?
Yes, they are.
Thank you, it’s a great tool!
If you also want a graph of the CPU frequency, just uncomment “cpufreq = force” in /storage/.opt/etc/netdata/charts.d.conf
Damn, I should have checked that before writing one for the sensors section. At least I prefer it near the temperatures graph so it isn’t time wasted. Here is one image with a comparison for the different governors:
For the S912 cpu the built in tool even recognizes that there are two govenors:
