Been using OpenELEC and LibreELEC for years on Intel and I’m excited and looking forward to testing CoreELEC on my new 4GB ODROID N2, eMMC 64GB.
My order was placed Friday evening and it was home waiting for me by the time I got out of work, Monday evening. So far, I have experienced nothing but great things with this box. Shipping was fast, putting it together was a breeze, and you guys could not have made the installation any easier! Kudos!
On the CoreELEC side, I installed the Stable version and all seems to be working great. The only thing I quickly glanced was that I showed no bluetooth connections, even though the Bluetooth toggle in Services was On. I guess I’m used to LibreELEC, where all the available connections auto show there without having to manually hit pair on the devices. It was very late last night and I didn’t get a chance to review it any further. However, I know the bluetooth dongle should work out of the box as it’s the Module 2 usiing CSR5810 A10 Chipset. I will dig deeper and fully test tonight. I will report more on the results.
Where can I inform myself of pending issues with CE on ODROID N2? Have most problems been resolve or are there many still outstanding? I’d like to make a decision on whether or not to install the Nightly version of CE.
With regard to Android on microSD:
I purchased the ODROID N2 CoreELEC version which came with CE pre-installed on microSD. Even though CoreELEC on eMMC will be my daily driver, I’d like to have a dual boot setup of android on microSD for whenever I need a specific app. I know the performance of android on microSD will probably be terrible, but android isn’t going to be my daily driver. It will be there solely for whenever I need it.
Is there a specific android image for ODROID N2 and where do I get it?
Also, do I flash this image in the same fashion I did CE using Rufus? It can’t be this easy, right? I mean, don’t I also have to install/configure a boot loader?
Thanks for your help and taking time in reading this.
BLUETOOTH UPDATE: NO issues with CoreELEC and the $5.95 USB Bluetooth Module 2 dongle I purchased from Ameridroid. All working flawlessly.
I have to say… this little box on eMMC feels really fast! Granted it’s bare bones right now as I don’t even have a custom skin or anything, but I’m really impressed on how it’s handling. My daily driver has always been Intel and I can’t feel a difference using it, yet. I’m very optimistic that I have found my next Kodi workhorse. Will continue further testing.
However, I did go thru hell trying to pair my Logitech Harmony Hub Companion, but it all stemmed with the Harmony device. I even reset the whole thing and still couldn’t achieve a successful pair. I even installed the Nightly Build thinking that may help… nada. But thankfully, I finally figured it out (hours later).
I will probably do a separate post to help anyone else in the future.
The flashing of android image seems pretty direct. But i’m confused about the next part titled “Reference boot.ini.”
this where I configure the boot loader and choose what OS (CoreELEC or Android) to boot from?
How do I access this?
And how do I select or switch operating systems going forward?
Do I need to buy the USB-UART Module Kit in order to achieve the dual boot setup I want?
The only other dual boot setup I’ve used before (on a streaming device) was on a Wetek Hub, but all the work has already been done for me. All I have to do is press Power during boot to choose Android or LibreELEC.
Forgive my ignorance on this, as I’ve never setup android from scratch as a dual boot. I can do Windows and Linux with my eyes closed, but that’s a whole different animal. lol
Forget about “Reference boot.ini”. Don’t change anything, just burn selected (latest) Android image (with Etcher) and install it; turn N2 off, remove any uSD card, attach eMMC module take care that SPI switch is on the right (eMMC) position and power on N2. Installation should start and finish without a problem. IIRC after the initial setup you have to turn N2 off and on to boot Android.
6. 7. 8. are separate topics and can be discussed when you have both systems (CE on uSD & Android on eMMC) up and running…
Simplest way to dual boot is: boot to CE with both uSD and eMMC inserted, and boot to Android when uSD is not inserted. There is another way (using SPI switch) but that takes more preparations…
Yes you can, but Android works best when installed on eMMC.
Or you can use both systems installed on eMMC, and choose which OS to boot, as @vpeter suggested.
Search the forum for instructions how to achieve that method.
Thanks for all your help. As of last night, Android is running fine on the SDcard.
Just to be safe, I formatted the SDcard using SD-Formatter because I used to have different operating systems on it.
I flashed the android image on my PC using Etcher.
Turned ODROID off
removed the eMMC card that has CoreELEC installed
inserted SDCard that was flashed
Made sure the SPI switch was on the right (eMMC) position
Turned ODROID on.
Installation auto began and successfully completed.
One problem I did encounter after android showed its home screen was a flashing, bluetooth-error, pop-up, window in the middle of the screen that was persistent. I couldn’t dismiss it. Had no choice but to unplug the bluetooth dongle. It was too late to trouble shoot so I’ll do that tonight after work.
Tonight, I’ll continue working on android by installing gapps via the tutorial on the link you provided.
Then I’ll test to see what happens when both the eMMC (CoreELEC) card and SDcard (android) are inserted.
Which will boot by default?
And how will I switch between the two going forward?
The SPI switch idea you previously mentioned sounds great. I’d hate to have to open the box and remove cards simply to properly boot a corresponding OS.
I’d like to first segregate them completely by storage type. I’m keeping my CE Nightly build and I’d like to keep things completely separated to avoid any future headaches. I guess if all else fails, I can try dual booting both, android and CE, from eMMC. My eMMC is 64GB so I have plenty of space. Thanks for pointing this out too.
So far, everything’s going along well. I’m also waiting on delivery of my LG OLED C9 TV. Should be here in a couple of days. I’m excited about this box… can’t wait to fully test it!
When CE is on uSD card, then uSD has priority over eMMC, how it behaves with Android on uSD I don’t know. For boot priority in this case you have to use “Petitboot” program installed on internal flash memory. For this to work, you must put the SPI switch in left position.
UPDATE:
Odroid N2 was delivered on 12/16/19 and it came with Petitboot (dev.20190416) pre-installed. In order to update to the latest version, I followed the instructions on the link you provided above:
I flashed version (dev.20190417) the “Old Way”
Then proceeded to install incremental updates. First, Petitboot dev.20191020, followed by the latest version, dev.20191127.
So, using the latest Petitboot version, here’s the outcome of having this type of setup:
If the SPI switch is to the right (eMMC) and both the SDcard (Android) and eMMC card (CoreELEC) are installed, ODROID N2 by default selects the eMMC card (CoreELEC) to boot. However, CoreELEC does not boot up properly as it gets stuck on a constant boot loop. If the SDcard is removed, then CoreELEC boots fine. Android also boots fine, if the eMMC card is removed. To summarize, only once card can be installed with the SPI switch on the right. Either OS boots fine, just as long as only one card is present.
If the SPI switch is to the left (SPI), Petitboot (ver.20191127) is shown and I get the following two options to select from:
[Disk: mmcblk0p1 / 1812-5247]
CoreELEC
[Disk: mmcblk1p1 / 5DFE-F81F]
Android Pie (64Bit)
If you do not make a selection, ODROID N2 boots the eMMC (CoreELEC) by default. In this case, CoreELEC boots fine.
However, if I select Android, it doesn’t boot it properly. The bottom left of screen states the following… “Performing kexec reboot” and then the HARDKERNEL boot image is displayed and remains displayed. The only way out of this screen is to power cycle the box.
Anyone know why android won’t boot properly after selecting it?
Also, why does Petitboot have android listed as 64Bit when I know I installed the 32Bit version?
When I first saw this, I decided to re-download the 32bit android image and flash it one more time in case I did flash the wrong version by mistake. After making sure I flashed the 32Bit version, Petitboot still has the selection as 64Bit.
I just installed Android 9 ATV 64 bit version on uSD card and have CE on eMMC. With switch in SPI position I can choose which OS to boot. I configured latest Petitboot to automatically boot Android from uSD card, and it does that without a problem…
How did you install and setup your Android on uSD ? I did it with eMMC removed with SPI switch in eMMC position. When I finished with ATV installation and configuration on uSD, then I inserted my CE on eMMC and flipped the switch to SPI. Started Petitboot and configured it. After power off/on everything works as expected…
That’s exactly the same way I installed android, without the eMMC card and SPI switch to the right. I’m going to install android TV though to see if that version of android works. That’s the only difference from your setup to mine, the android version. Will report back.
BTW - I have a Harmony Hub via bluetooth that obviously doesn’t work on Petitboot to make OS selections… gotta figure out a permanent/alternate method to switch. Hate to have to use two different remotes, but that’s what I’m doing at the moment.
With all my boxes I use a small WiFi keyboard (Rii mini i8) and Harmony 650 remote. There are IR remotes with keyboard on one side but I prefer to have keyboard separate from remote command (which I use for all my other devices)
